Is it colder at the approach end of the runway?
Old April 2nd 07, 08:43 AM posted to rec.aviation.piloting
Chris W
Default Is it colder at the approach end of the runway?
My dad drives along the south side of OKC to work every day and his OAT
in his car always goes a few degrees colder around the where the
extended centerline for the runways would intersect the road. Then it
goes right back up after he is through that area. He thinks this is
because the airplanes are descending from very cold air and bringing
down some of it with them. He has noted that this isn't always the case
but it often is. You would think most of the traffic would be landing
from the north since our winds are mostly from the south, but it seems
like I see a lot of traffic coming in from the south, maybe because it
is easier for the traffic from DFW to just come strait in.
Anyway, any one here think it is really the case that the planes are
causing the temperature to be lower on the approach end of the runway?
I guess if he monitored the ATIS frequency to find out which runway was
active when he drives by every day, he would have a better idea.
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Old April 2nd 07, 08:47 AM posted to rec.aviation.piloting
Chris W
Chris W wrote:
maybe because it
Make that "straight"
Chris W
KE5GIX
Old April 2nd 07, 10:37 AM posted to rec.aviation.piloting
Mxsmanic
Chris W writes:
I would not have thought of that, but it's certainly plausible. Aircraft
produce a massive downwash of air behind them that (at least in theory) drifts
downward until it encounters the ground. In the case of aircraft very near
the surface (as during landing and take-off), it's entirely possible that they
might produce gentle downdrafts of colder air that reach the ground. I think
it would take fairly constant traffic using the runway to make a clear
difference, though.
It's a bit like the constant wind that one often feels by the side of a
highway or major city street, always in the direction of traffic. Moving
vehicles do displace a lot of air.
Things like noise abatement and other concerns might obligate the airport to
work against the wind, at least if the wind speed is low enough (less than 10
knots or so).
I think it's plausible.
Also, if the extended centerline is mostly open area (not buildings or roads),
that could make a difference as well. An open field is often colder than a
large building, because it absorbs solar energy less rapidly and retains it
less efficiently, and because it doesn't generate any heat of its own.
Old April 2nd 07, 12:21 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
Chris W writes:
OAT in his car always goes a few degrees colder around the where the
it goes right back up after he is through that area. He thinks this
is because the airplanes are descending from very cold air and
bringing down some of it with them.
Aircraft produce a massive downwash of air behind them that (at least
in theory) drifts downward until it encounters the ground. In the
case of aircraft very near the surface (as during landing and
take-off), it's entirely possible that they might produce gentle
downdrafts of colder air that reach the ground. I think it would take
fairly constant traffic using the runway to make a clear difference,
though.
a highway or major city street, always in the direction of traffic.
Moving vehicles do displace a lot of air.
landing from the north since our winds are mostly from the south, but
it seems like I see a lot of traffic coming in from the south, maybe
because it is easier for the traffic from DFW to just come strait in.
airport to work against the wind, at least if the wind speed is low
enough (less than 10 knots or so).
runway?
You would, fjukktard.
Bertie
Old April 2nd 07, 01:36 PM posted to rec.aviation.piloting
Jim Macklin
It is farther away from the built-up areas of the town, so
it is cooler. Houses make heat and so do factories.
| Chris W writes:
day and his
the where the
road. Then
He thinks this
air and
plausible.
that (at least
ground. In the
landing and
produce gentle
it would take
difference,
| though.
by the side of
of traffic.
would be
the south, but
south, maybe
come strait in.
obligate the
speed is low
the planes are
of the
| runway?
Old April 2nd 07, 01:57 PM posted to rec.aviation.piloting
Maxwell
"Chris W" wrote in message
My dad drives along the south side of OKC to work every day and his OAT in
his car always goes a few degrees colder around the where the extended
centerline for the runways would intersect the road. Then it goes right
back up after he is through that area. He thinks this is because the
airplanes are descending from very cold air and bringing down some of it
with them. He has noted that this isn't always the case but it often is.
You would think most of the traffic would be landing from the north since
our winds are mostly from the south, but it seems like I see a lot of
traffic coming in from the south, maybe because it is easier for the
causing the temperature to be lower on the approach end of the runway? I
Which airport in OKC???
Old April 2nd 07, 04:18 PM posted to rec.aviation.piloting
Marco Leon
Maybe an active localizer/glideslope signal is affecting the thermometer
components. Air does not "stick" to an airframe enough to change the ambient
temperature of a given area no matter how small.
Marco
Old April 2nd 07, 10:33 PM posted to rec.aviation.piloting
Vaughn Simon
"Marco Leon" wrote in message
Air does not "stick" to an airframe enough to change the ambient temperature
No, but everyone who has ever studied for their Private written knows that
the wake of an aircraft is accelerated down. So the passage of an aircraft
would cause a very temporary downward flow of air. Would the effect be enough
to noticeably change local temperatures? I doubt it; but who the hell am I?
Old April 3rd 07, 04:18 AM posted to rec.aviation.piloting
John Halpenny
On Apr 2, 5:33 pm, "Vaughn Simon"
What time of day does he go by? I could see the downwash mixing up
the air, and if there is a hot surface layer this could cool it.
As an example of downwash changing the temperature, I have heard
helicopter pilot stories about 'frost flights' at strawberry farms.
The task is to spend the night at the farm, and if the frost alarm
goes off in the wee hours you have to fly low over the fields in the
dark until the air is stirred up and the frost danger goes away. It
apparently is very effective in preventing frost damaged berries.
John Halpenny
Old April 4th 07, 12:25 AM posted to rec.aviation.piloting
m...
John Halpenny
This has been done with fixed-wing airplanes, too. An airliner
on approach can't help but drive down air from a couple hundred feet
up. Problem with that, of course, is that the OP says his dad notices
this on the drive to work, presumably in the morning, and the air
aloft will be warmer rather than colder at that time. The nocturnal
inversion is still in play in the morning, before the surface heats
up. It's that warmer air the helicopters or other craft are driving
down at night into the orchards or vineyards or citrus groves.
Dan
A WHAT Ran off the End of our Runway?? Marco Leon Piloting 10 May 17th 06 02:46 AM
Runway ID Lakeview Bill Piloting 55 October 18th 05 12:53 AM
Runway needs of F4U and F-4 ???? vincent p. norris Naval Aviation 8 October 6th 05 07:18 PM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
Runway in Use Sniper@SDU Simulators 11 October 8th 03 10:57 AM
