Which Corvair engine
Old August 9th 03, 01:34 PM
JSoar
Default Which Corvair engine
I am thinking about trying a one third Corvair engine in my
ultralight. I found a 1965 140 hp Corvair car and a 1964 turbocharged.
Or maybe the 110 hp would be best. Does anybody know which of the
Corvair engines would be best to start with? Thanks.
Old August 9th 03, 05:28 PM
James R. Freeman
110 hp
"JSoar" wrote in message
om...
Old August 9th 03, 06:17 PM
Rich S.
"James R. Freeman" wrote in message
110 hp
om...
Yup. Stay away from the 140 hp heads - they easily drop valve seats. The '64
turbo is a hermaphroditic engine - some unique parts.
Rich S.
Old August 9th 03, 07:30 PM
Jerry Springer
Yup sure do...none of them.
Old August 9th 03, 07:59 PM
Jerry Wass
Good thing you're only thinking about it.---You can't shorten the
crankshaft, or
crankcase, the crank throws are 60deg apart--to get 180deg firing(or
360deg)
you have to pick a pair that are offset at least one full cyl distance
apart-(from
front to back) this gives you a rocking couple--(horizontal twisting
motion)---
I was gonna use a 3 cyl -all on one side for a generator power plant--It
won't
work either.---The best engines are the 110 hp, '65 to '69--the Turbo Exh
valves are much better than std. Jerry
Old August 9th 03, 08:20 PM
BD5ER
crankshaft, or
crankshaft, or
It will still run. Just shake like one of those large American made scooters.
Kind of a waste of a 'vair.
Old August 9th 03, 09:38 PM
Barnyard BOb --
William Wynne is your man @
http://www.flycorvair.com/
IMHO...
It would seem you are not only re-inventing
the wheel... but possibly making your ultra-light
heavier than legal in the process.
Barnyard BOb --
Old August 9th 03, 10:41 PM
Scott
Why would you want to use a 1/3 Corvair? Why not the better half VW by
Len Milholland? A lot less weight than a whole corvair case with only
two active jugs on it...or do you plan to cut down the case? Check out
Len's VW at http://www.betterhalfvw.com/
It's about 80-85 pounds and approximately 30-35 HP according to Len.
Scott
http://corbenflyer.tripod.com
http://groups.yahoo.com/group/ParasolAirplanes
Building RV-4
Gotta Fly or Gonna Die!
Old August 10th 03, 07:15 PM
BD5ER
Check out
http://www.ultravair.com/
Nice looking, and the 'vair does have a fairly good track record. Don't know
why I fell for the 60 deg thing on an earlier post as I have a 'vair crank
setting on the floor in the shop. (the rod throws are 180 for each pair). I
also happen to have a 110 head with a bad center hole...........
Maybe my 1/2 VW is going to be history?
Thanks for the link.
Old August 13th 03, 08:12 PM
George A
I wouldn't throw that 1/2VW away just yet.
The 1/3'vair looks neat but it has less cubic inches then the 1/2VW.
That equals less power. And is heavier.
George Allen
Harrisburg, PA
(Peitenpol builder)
"BD5ER" wrote in message
Check out
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
Continental A65 engine Philippe Vessaire Home Built 0 July 10th 03 05:49 PM
mercedes engine Joa Home Built 1 July 8th 03 12:26 PM
