pollution of jets against turbine aircraft
Old April 5th 07, 03:28 PM posted to rec.aviation.piloting
Default pollution of jets against turbine aircraft
With all the problem of the modern planes according to ecology (CO2,
white vapour trails, etc ...) I would like to ask a question :
-- does turbines and normal airscrew planes less pulluting aircraft
than pure jets one ??
-- does this aircraft use less petrol for a journey ( knowing that
they are 200 km/h slower than jets) ? If ies... how much less ?
tHanks for somebody "whoknows" to answer
Old April 5th 07, 04:24 PM posted to rec.aviation.piloting
cjcampbell
"Turbine" is just another name for "jet." All turbines, including
turboprops, pollute more than gas piston engines. Sort of. Remember
that a jet spreads its fuel costs and pollution among many more
passengers than a piston engine does. On a per-passenger basis, jets
and turboprops probably pollute less than a gas piston engine.
There is some evidence that the vapor trails from jet engines, while
they add smoke pollutants to the atmosphere, actually reduce global
warming by creating cloud cover.
A four passenger Cessna burns about 12 gallons per hour. It flies at
about 120 miles per hour.
A 747 burns 300 lbs per passenger for a 3450 mile flight. That would
be 60 gallons of fuel per passenger. To fly the same distance, if it
was full, the Cessna would burn a little over 86 gallons of fuel per
passenger. Typically, though, the Cessna will carry only two
passengers, so it works out to nearly 173 gallons of fuel per
passenger. Clearly the 747 is more fuel efficient per passenger.
Think of it this way: a bus gets much worse gas mileage than a car and
it pollutes more. But a bus carries the same number of people as many
cars (perhaps 30 cars), so if it pollutes less and uses less fuel than
30 cars, the bus is better for the environment.
The same rules hold true for cargo.
But it is not that clear-cut. Cessnas do not fly 3450 miles on a
normal trip. The typical Cessna journey is less than 500 miles,
usually much less. You cannot fly a 747 for such short trips -- it
would be horrendously expensive or, in other words, a horrendous waste
of resources. It would be a rare day indeed that you could find
upwards of 500 people all wanting to take the same 200 mile trip at
the same time, especially when you consider that the 747 requires a
huge airport and terminal and other support facilities that the Cessna
does not.
The Cessna gives you the flexibility to travel short distances at the
times you need to go.
Think of the difference between a bus and a car again. Buses have
regular stops and schedules and are pretty much structured to carry
only passengers and perhaps a handbag or briefcase. Obviously, it is
not going to stop at the grocery store, the day care, the hardware
store, and all the other places you may need to go during the day. The
bus is okay if all you are doing is going straight from the bus
terminal or park and ride to work and back. It does not work out so
well if you are a tradesman who must carry large quantities of tools
to many different work locations during the course of a day. With a
bus, you have to go where the bus goes. With a car, you go where you
want.
It is the same with a Cessna and a 747. With the 747, you are pretty
much relegated to flying wherever the airline goes on the airline's
schedule. Maybe you want to fly from Seattle to Chicago. In a Cessna,
you could fly straight to Chicago. But the big jet will fly to Phoenix
on the way. Or Dallas. Or some other hub. So where a Cessna can make a
1000 mile journey by flying 1000 miles, the jet makes a 1000 mile
journey by flying 2000 miles or more. Going back to our figures, now
we see that a fully loaded Cessna would burn about 30 gallons of fuel
per passenger for a 1000 mile trip. But the jet will burn 120 gallons
of fuel per passenger. Clearly the Cessna is much more fuel efficient
for this type of journey.
Old April 5th 07, 05:22 PM posted to rec.aviation.piloting
Andrew Sarangan
All great stuff which I agree with. But what's this obsession with
Cessna being equivalent to small airplanes? When I talk to the
nonflying public, they always refer to all GA airplanes as Cessnas. It
doesn't matter if it is a Piper, Mooney or Cirrus. They are all a
Cessna to them. But I would expect differently from a pilot. Another
thing that nonpilots do is refer to GA airports as "private
airports".
On Apr 5, 11:24 am, "cjcampbell"
does not.
want.
Old April 5th 07, 05:31 PM posted to rec.aviation.piloting
cjcampbell
airports".
does not.
want.
The Cessna was used as an example because I am more familiar with its
fuel consumption. You would have to ask someone else about fuel
economy in a Cirrus.
Old April 6th 07, 01:43 AM posted to rec.aviation.piloting
Newps
Better than any Cessna, it's simply a more efficient plane.
Old April 5th 07, 10:58 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
There are more Cessnas than there are Mooneys, Cirrus, etc...
It's not always Cessnas though. I've noticed that many in the general
public and news media, think all small aircraft are "Piper Cubs".
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200704/1
Old April 6th 07, 04:52 PM posted to rec.aviation.piloting
Matt Barrow[_4_]
"JGalban via AviationKB.com" u32749@uwe wrote in message
news:70447ca89a6e4@uwe...
I thought it was Cessna Cubs and Piper 172's?
Old April 12th 07, 05:19 PM posted to rec.aviation.piloting
cjcampbell kirjutas:
Not quite - turboprops are not quite regarded as jets. But they are
definitely turbines.
All turbines, including turboprops, pollute more than gas piston engines. Sort of. Remember
It´s just that there are few big piston airliners which are modern in
design as well.
snip
Precisely. Compare apples with apples, not oranges.
the same time,
It is not rare. It is actually so often that 747-s were designed and
built specifically for that purpose, or almost. What are the main
747SR routes in length? (Tokyo-Sapporo et cetera...)
And now, let us choose some apples and other apples to compare.
For turboprops, take ATR 72 and Bombardier Dash 8. Which can carry
about 70 people.
For jets, do not compare them with 500 seat 747. Compare them with
Bombardier Canadair Regional Jet. Which also has about 70 seats.
If you take a 70 seat jet and 70 seat turboprop flying the same
distance - how much longer does the turboprop take?
Which of them burns more fuel? How much?
Old April 6th 07, 01:52 AM posted to rec.aviation.piloting
You mean the CO2 that is a vital nutrient to plant life and key to
photosynthesis of food for those same plants? The CO2 that is
currently at 380ppm but has been at 3000ppm for most of the history
of
life on the planet? The same CO2 that at 1000ppm stimulates plants
to
grow 50% faster than they do at 380ppm? The same CO2 that is a minor
greenhouse gas when compared with water vapor, which is the dominant
greenhouse gas and absorber of infra-red radiation? The same CO2
that
you emit every time you exhale? The same CO2 that is the primary
source of carbon for carbon based lifeforms on this planet? The
same
CO2 that has to be in excess of 5000ppm to pose a respiritory problem
for animals and humans?
You talk about CO2 like it is some form of pollution, rather than a
key component of life on this planet. Hmmm, maybe in addition to
restricting CO2 emissions, we should restriction H20 vapor emissions,
the biggest greenhouse gas. You can buy Hydrogen offset credits at
my
website http:\\someonebuymeadrink.com
Minimum age to fly turbine aircraft? [email protected] Piloting 7 December 31st 06 12:28 AM
FA: One-Day-Left: 3 Books - JETS JETS and JETS - AIRPORT - 30 Seconds Over Tokyo Alan Aviation Marketplace 0 August 14th 05 01:11 PM
FA: 3 Books - JETS JETS and JETS - and Aviation Classics Millie Aviation Marketplace 0 August 9th 05 03:48 AM
turbine in microturbine generator for aircraft? Shin Gou Home Built 19 December 26th 04 02:19 PM
Future Turbine Aircraft Mike Schumann Owning 7 July 1st 03 10:00 AM
