How exactly does a synchrophaser work?
What is it measuring to make its adjustments? Why does it have to be off for takeoff and landing? What voodoo is contained therein (and what's the difference between a mechanical and electronic version)? TheSmokingGnu |
On Apr 6, 12:50 am, TheSmokingGnu
wrote: How exactly does a synchrophaser work? An engine or engines are slaved to a master engine, in order to reduce noise, usually by getting their propeller / turbofan beats to cancel each other. What is it measuring to make its adjustments? Depends on type, but figure a set of position sensors. Super advanced models also use noise sensors to dynamically adjust phase offsets in flight. Why does it have to be off for takeoff and landing? Depends on model. Some don't. Older ones work by reducing engine speed rather than boosting it, thus you could get into a downward spiral, which is dangerous at T/O. Kev |
wrote: [...] Der Synchrophaser! Fellow old timers, remember this warning? Alles Lookenpeepers! Dies Machine is nicht fur gefingerpoken und mittengraben. Is easy schnappen der springenwerk, blowenfusen und poppencorken mit spitzensparken. Is nicht fur gewerken by das dummkopfen. Das rubbernecken sightseeren keepen Cotten-pickenen hands in das pockets - relaxen und Watch Das Blinken Lights. :-) |
"Kev" wrote in message
oups.com... On Apr 6, 12:50 am, TheSmokingGnu wrote: [...] Der Synchrophaser! Fellow old timers, remember this warning? Alles Lookenpeepers! Dies Machine is nicht fur gefingerpoken und mittengraben. Is easy schnappen der springenwerk, blowenfusen und poppencorken mit spitzensparken. Is nicht fur gewerken by das dummkopfen. Das rubbernecken sightseeren keepen Cotten-pickenen hands in das pockets - relaxen und Watch Das Blinken Lights. :-) That was nailed to a floor joist above my father's train set in the basement. Did you ever see this one? PARKING VIOLATION This is not a ticket, but if it were within my power, you would receive two. Because of your Bull Headed, inconsiderate, feeble attempt at parking, you have taken enough room for a 20 mule team, 2 elephants, 1 goat and a safari of pygmies from the African interior. The reason for giving you this is so that in the future you may think of someone else, other then yourself. Besides I don't like domineering, egotistical or simple minded drivers and you probably fit into one of these categories. I sign off wishing you an early transmission failure (on the expressway at about 4:30 p.m.). Also may the Fleas of a thousand camels infest your armpits. WITH MY COMPLIMENTS |
Steve Foley wrote:
That was nailed to a floor joist above my father's train set in the basement. Did you ever see this one? PARKING VIOLATION This is not a ticket, but if it were within my power, you would receive two. Because of your Bull Headed, inconsiderate, feeble attempt at parking, you have taken enough room for a 20 mule team, 2 elephants, 1 goat and a safari of pygmies from the African interior. The reason for giving you this is so that in the future you may think of someone else, other then yourself. Besides I don't like domineering, egotistical or simple minded drivers and you probably fit into one of these categories. I sign off wishing you an early transmission failure (on the expressway at about 4:30 p.m.). Also may the Fleas of a thousand camels infest your armpits. WITH MY COMPLIMENTS I used to have a book of those I carried in the car, looked just like traffic tickets, probably back in the 70's! Loved to put one under some nimrods wiper blade when they parked in two stalls at once... d:-)) Cheers'n Beers.. [_]) Don |
![]() "Kev" wrote in message oups.com... On Apr 6, 12:50 am, TheSmokingGnu wrote: [...] Der Synchrophaser! Fellow old timers, remember this warning? Alles Lookenpeepers! Dies Machine is nicht fur gefingerpoken und mittengraben. Is easy schnappen der springenwerk, blowenfusen und poppencorken mit spitzensparken. Is nicht fur gewerken by das dummkopfen. Das rubbernecken sightseeren keepen Cotten-pickenen hands in das pockets - relaxen und Watch Das Blinken Lights. :-) Probably posted in the window of just about every TV stations' Master Control in the country. Jay B |
![]() "Jay Beckman" wrote in message ... "Kev" wrote in message oups.com... On Apr 6, 12:50 am, TheSmokingGnu wrote: [...] Der Synchrophaser! Fellow old timers, remember this warning? Alles Lookenpeepers! Dies Machine is nicht fur gefingerpoken und mittengraben. Is easy schnappen der springenwerk, blowenfusen und poppencorken mit spitzensparken. Is nicht fur gewerken by das dummkopfen. Das rubbernecken sightseeren keepen Cotten-pickenen hands in das pockets - relaxen und Watch Das Blinken Lights. :-) Probably posted in the window of just about every TV stations' Master Control in the country. Jay B Perhaps. It was very common at radio and tv transmitting sites. Peter |
On Thu, 05 Apr 2007 21:50:24 -0700, TheSmokingGnu
wrote: How exactly does a synchrophaser work? On a piston-pounder it is changing the propeller blade angle/engine RPM via the prop governor. Some use a coil on the slave engine to vary the spring pressure on the flyweight governor, some use a step motor and a jack screw to change the OAL of the prop control cable to the slave governor. Have worked on turbo-prop and turbojet systems that use the same step motor and jackscrew assy. On the jets, it varies the length of the "throttle" cable... What is it measuring to make its adjustments? Again, on a piston-pounder there is typically a small pick-up coil on the base of the governors, or in some cases sensing units inline in the tachometer shafts. On one set-up that I am familiar with the units on the tach shafts are aligned with the propellers in a specific relation ship to each other, I would assume to reduce "drumming" on the fuselage. Why does it have to be off for takeoff and landing? It has the potential to reduce the RPM slightly on the slave engine if the master has an RPM sag. Again, on the systems I am familiar with, the total "authority" of the system is only around 100-150 rpm, so it isn't going to reduce it much. What voodoo is contained therein (and what's the difference between a mechanical and electronic version)? Have no idea, AFAIK all the box is doing is trying to match the frequency output of the pickup coil on the master engine to the output of the slave engine by tweaking the blade angle/RPM of the slave engine. TC |
