While doing some preliminary planning for a June trip from KLOU to
KWWD ( Cape May, NJ), my "direct" path would take me right over the center of DC ( in the Prohibited area). I have reviewed the articles and AOPA advice on travelling in and arround the ADIZ, and know the procedures. Most of that advice seems to be focused around navigating through it - but only on a North-South axis. Any ideas on how to plan? A northerly or southerly transition ? It's all busy space... Thanks |
Larry
Why not take a short detour around the south of the ADIZ? A quick calculation shows that you will lengthen your trip by only 10 miles which is hardly noticeable on a 500 mile trip. On Apr 6, 3:33 pm, "Larry R" wrote: While doing some preliminary planning for a June trip from KLOU to KWWD ( Cape May, NJ), my "direct" path would take me right over the center of DC ( in the Prohibited area). I have reviewed the articles and AOPA advice on travelling in and arround the ADIZ, and know the procedures. Most of that advice seems to be focused around navigating through it - but only on a North-South axis. Any ideas on how to plan? A northerly or southerly transition ? It's all busy space... Thanks |
Any ideas on how to plan [a flight through the ADIZ area]?
A northerly or southerly transition ? It's all busy space... I would plan on avoiding the class B airspace and the FRZ. You can get through the ADIZ fine, but they often don't want flights through the Bravo. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
On Fri, 06 Apr 2007 20:08:31 GMT, Jose
wrote: I would plan on avoiding the class B airspace and the FRZ. You can get through the ADIZ fine, but they often don't want flights through the Bravo. It is pretty had to find a path through the center of the ADIZ above 1500' feet without going through B airspace. I agree that the best method is go around. |
ArtP wrote:
On Fri, 06 Apr 2007 20:08:31 GMT, Jose wrote: I would plan on avoiding the class B airspace and the FRZ. You can get through the ADIZ fine, but they often don't want flights through the Bravo. It is pretty had to find a path through the center of the ADIZ above 1500' feet without going through B airspace. I agree that the best method is go around. I'll cut through the ADIZ, but I'm located on it's fringe. You are right, it's usually not worth the effort. |
![]() "Larry R" wrote .... While doing some preliminary planning for a June trip from KLOU to KWWD ( Cape May, NJ), my "direct" path would take me right over the center of DC ( in the Prohibited area). Why don't you do like the old timer did a year or so ago, and motor right on through the middle of it? ggg -- Jim (ducking and running) in NC |
"Larry R" wrote in news:1175888007.225210.138450
@l77g2000hsb.googlegroups.com: While doing some preliminary planning for a June trip from KLOU to KWWD ( Cape May, NJ), my "direct" path would take me right over the center of DC ( in the Prohibited area). I have reviewed the articles and AOPA advice on travelling in and arround the ADIZ, and know the procedures. Most of that advice seems to be focused around navigating through it - but only on a North-South axis. Any ideas on how to plan? A northerly or southerly transition ? It's all busy space... Thanks No real reason to avoid the Class B. Just make sure you have your squawk and all with Potomac. They'll want you to file your ADIZ flight plan with one of several specific starting points outside the ADIZ. So you'll fly to the western entry point, and ask them to open your ADIZ flight plan. If you have flight following the whole way, they'll probably do it implicitly if they can get the handoff... Otherwise they will tell you they can't hand you off and you'll need to use the frequency they gave you at WX-BRIEF and try to get squawked before you have to start circling. ![]() From my experience in that area (although limited), you'll probably want to transition the ADIZ using MRB BAL AGARD or maybe MRB BAL ENO It adds about 5 miles to your trip... I am not certain of the Easterly waypoint because I am usually North or West of the ADIZ in my travels, but you can ask the briefer. As you approach MRB, if you don't have flight following, call up and get your squawk, and they'll clear you through the ADIZ and give you any heading changes or what not. It's really not too bad or scary. Just don't screw up. ![]() |
Judah wrote:
No real reason to avoid the Class B. Just make sure you have your squawk and all with Potomac. ADIZ clearance is NOT authorization to enter the class B. Even coming out of VKX (one of the FRZ airports) they aren't real friendly about the class B these days. I'm fingerprinted, on what is in effect an IFR plan, with special notification to the secret service, but I gotta stay at 1400 feet until I get clear of the National arrivals. |
Ron Natalie wrote in news:4617ace9$0$10042
: Judah wrote: No real reason to avoid the Class B. Just make sure you have your squawk and all with Potomac. ADIZ clearance is NOT authorization to enter the class B. Even coming out of VKX (one of the FRZ airports) they aren't real friendly about the class B these days. I'm fingerprinted, on what is in effect an IFR plan, with special notification to the secret service, but I gotta stay at 1400 feet until I get clear of the National arrivals. Thanks for clarifying my omission. Yes, you do need to be cleared into the Bravo. I've never had trouble with it, but like I said, my experience is limited. |
"Larry R" wrote in message
oups.com While doing some preliminary planning for a June trip from KLOU to KWWD ( Cape May, NJ), my "direct" path would take me right over the center of DC ( in the Prohibited area). I have reviewed the articles and AOPA advice on travelling in and arround the ADIZ, and know the procedures. Most of that advice seems to be focused around navigating through it - but only on a North-South axis. Any ideas on how to plan? A northerly or southerly transition ? It's all busy space... I'm based at KJYO (Leesburg, VA) well within the ADIZ and have been dealing with it ever since its inception. Just to reiterate what you know already (but just in case somebody else is interested in such a flight), the rules are simple: 1. File a flight plan via landline or DUAT(S). 2. Maintain 2-way comms with ATC. 3. Use a unique transponder code while in the ADIZ. 4. If transponder fails, exit the ADIZ via most direct route. With that said, the FRZ (Flight Restricted Zone) within the ADIZ is a different beast and your route would indeed take you right through it. It is possible to get access to that airspace, but it requires a visit to security folks for a briefing and fingerprints for the background investigation. I have two recommendations for your flight: 1. File IFR. This takes care of all the requirements above (except #4 which is an exceptional situation in any circumstance); - OR - 2. Alter your route slightly to KLOU-KGAI-KWWD or KLOU-MRB (VOR)-KWWD or KLOU-BAL (VOR)-KWWD. The controllers at Potomac Consolidated TRACON are very good and have shown themselves to be quite helpful, but the ADIZ frequencies can get rather busy. Keep your transmissions short and to the point. Some other notes of interest: a. Call PCT when you're about 5 minutes out. b. You do not need a clearance to enter the ADIZ. (However, the Class B inside still uses the same rules as other Class B areas.) c. Expect to hear "N123, transponder observed" after initial contact and entering your squawk code. d. If you're VFR, do not expect to receive radar services - especially if you are in the ADIZ on a good flying day. e. You may be "asked" to fly certain vectors. This is usually the result of the controller trying to keep his scope clear for arrival/departure corridors into KIAD/KBWI/KDCA. If you (or anybody else contemplating such an ADIZ flight) have any IFR experience or are comfortable dealing with ATC, the ADIZ procedures aren't terribly fearsome. -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
Flying Magazine's Instrument Flying 1973 | Steven P. McNicoll | Instrument Flight Rules | 16 | January 12th 04 03:50 PM |
Flying Magazine's Instrument Flying 1973 | Steven P. McNicoll | Aviation Marketplace | 9 | January 4th 04 02:24 AM |
Flying Magazine's Instrument Flying 1973 | Steven P. McNicoll | General Aviation | 9 | January 4th 04 02:24 AM |
Flying Magazine's Instrument Flying 1973 | Steven P. McNicoll | Products | 9 | January 4th 04 02:24 AM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
