i have an old Stinson with a Cessna 300 nav-com in it.
surprisingly, the radio works OK, but i can't hear myself talk on 2 different headsets. but, i can transmit and hear others calling me OK. what gives? is it a function of this early radio that it has no sidetone---or a wiring problem? thanks for any input. email me pls? |
On Apr 8, 3:20 pm, (Gary R.) wrote:
... is it a function of this early radio that it has no sidetone---or a wiring problem? I have flown older Cessnas that had the 300 series NavComs, and they had sidetone. Sidetone is generated inside the COM by sampling the audio from the transmitter modulator and routing it out through the "headphone" output pin, so you should hear it when you transmit. Either the radio has an internal problem, or possibly the "sidetone level adjust" pot got turned down. Most COMs have a "sidetone level adjustment", usually visible only when the radio is out of its tray... |
Does an intercom interfer with this? If I shut my intercom off, I get no
sidetone. I've got an old Collins. That leads me to believe that the radio is not providing any - whether blocked by the intercom or by design or failure of the radio, I'm not sure. With the intercom on, I get sidetone which I presume is being generated by the intercom. When you use the handheld mic and speaker, clearly there shouldn't be any feedback. I could believe that the headset output doesn't provide sidetone. Why bother with the expense and extra parts? -- ------------------------------- Travis Lake N3094P PWK "mikem" wrote in message oups.com... On Apr 8, 3:20 pm, (Gary R.) wrote: ... is it a function of this early radio that it has no sidetone---or a wiring problem? I have flown older Cessnas that had the 300 series NavComs, and they had sidetone. Sidetone is generated inside the COM by sampling the audio from the transmitter modulator and routing it out through the "headphone" output pin, so you should hear it when you transmit. Either the radio has an internal problem, or possibly the "sidetone level adjust" pot got turned down. Most COMs have a "sidetone level adjustment", usually visible only when the radio is out of its tray... |
On Apr 9, 9:07 pm, "Travis Marlatte"
wrote: Does an intercom interfer with this? If I shut my intercom off, I get no sidetone. I've got an old Collins. That leads me to believe that the radio is not providing any - whether blocked by the intercom or by design or failure of the radio, I'm not sure. With the intercom on, I get sidetone which I presume is being generated by the intercom. When you use the handheld mic and speaker, clearly there shouldn't be any feedback. I could believe that the headset output doesn't provide sidetone. On older radios, I'm not sure if it is the radio, or the audio switching panel which generates the sidetone. On the other hand, I've worked on old 90 channel tube-type radios which did generate sidetone internally. I know for a fact that Narco Mark12D, King/Bendix/ Honywell radios like a KX170 & KX155, Garmin SL30/40, ICOM 200, & ValCom all generate headphone sidetone internal to the radio, regardless of what the audio switching panel or intercom does. Most intercoms have a strapable option which enables/disables the generation of sidetone inside the intercom... I agree that you do not want sidetone through the cabin speaker, only through the headsets. |
| radio squeal question. | Stealth Pilot | Home Built | 5 | November 6th 06 06:00 PM |
| Radio sidetone problem | Marty from Florida | Owning | 4 | April 2nd 05 10:36 PM |
| TKM MX-11 Sidetone | Rohit Fedane | Owning | 0 | January 22nd 04 05:59 AM |
| TKM Michel MX-170B Sidetone | Mike | Owning | 0 | December 30th 03 01:44 PM |
| Radio Question | Wizardo | General Aviation | 4 | July 25th 03 02:24 PM |
