Rationale behind vacuum instruments
Old April 9th 07, 04:17 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Rationale behind vacuum instruments
Can someone tell me why vacuum power is popular for certain instruments? I
cannot see any special reliability of a vacuum pump as opposed to an electric
motor. The only reason I can think of is historical, in that many small
aircraft have traditionally not had on-board electrical systems beyond what
was required by the engines themselves. However, a vacuum pump seems no more
reliable to me than an alternator. What are the reasons behind it all? I see
lots of descriptions of how the instruments work, but none that explain or
justify the choice of vacuum over electrical power. It also seems that vacuum
is subject to partial failures, whereas an electrical failure is usually much
more obvious.
Old April 9th 07, 04:24 PM posted to rec.aviation.piloting,rec.aviation.student
Robert M. Gary
more obvious.
If I tell you are you going to tell me I'm wrong??
-robert, CFII
Old April 9th 07, 04:45 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Robert M. Gary writes:
If it conflicts with other information I have, I may question it, but I don't
have much other information. If it sounds odd I may ask for further
explanation.
Old April 9th 07, 09:09 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
I don't have much other information. If it sounds odd I may ask for
further explanation.
Send me fifty bucks and I'll explain it to oyu.
bertie
Old April 10th 07, 04:43 AM posted to rec.aviation.piloting,rec.aviation.student
Roy Epperson
Robert,
You as a mere CFII are no match to Mxmanic the seer and no all...
Roy CFII, PGl
more obvious.
-robert, CFII
Old April 9th 07, 04:26 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Mxsmanic" wrote in message
I
electric
what
more
see
vacuum
much
more obvious.
In your case it makes no difference. The vacuum pump in your desk is
electrically driven.
Old April 9th 07, 04:35 PM posted to rec.aviation.piloting,rec.aviation.student
more obvious.
Because your head is an infinite source of vacuum...
Old April 13th 07, 06:02 AM posted to rec.aviation.piloting,rec.aviation.student
tony roberts
Robert M Gary wrote bs, bs, bs
Roy Epperson wrote bs, bs, bs
Deanwil wrote bs, bs, bs
What does it take for you people to understand that we are all sick and
tired of your pathetic attempts at humour/sarcasm/whatever you think it
is.
We are sick and tired of it.
Can you understand that?
You are not funny!
can we please please please have a respite from this crap?
Thank you
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old April 9th 07, 04:36 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Natalie
Driving gyros with air pressure is much simpler, cheaper, and
more reliable from the gyro point of view than using small electric
motors. Venturis and engine-driven wet pumps are real reliable
and not too expensive too. The major problem is engine-driven
dry pumps which have a nasty habit of failing unexpectedly.
I
motor.
Your vision is impaired. Spinning a free-in-space gyro (like the AI or
DH) with a motor is complicated. On the other hand, a restrained gyro
like the Turn and Bank is much easier (and these are typically electric).
The above is only partially true. While it certainly starts there, the
answer is really that electrical gyros are much more expensive and not
that much more reliable.
There are some real nice units coming on the market these days with
a electric Attitude Gyro with a battery backup. But they are still
MUCH more effective. You can actually have two engine driven vacuum
pumps for redundancy in many cases and two independent gyros for what
they cost.
However, a vacuum pump seems no more reliable to me than an alternator.
A wet pump driving a air gyro is MUCH more reliable than an alternator
driving the entire electrical system driving an electric gyro.
Anecdotally, I've had perhaps a half a dozen electrical failures in
several different aircraft over the years. I've had one dry pump
go on me.
Evaluating the options. I have the following:
A dry pump feeding the AI.
The vacuum guage prominently located next to the above.
A electric turn coordinator feeding the autopilot.
A real nice IFR GPS with fast update rates.
One major issue with the vacuum failure and transition to parital panel
is realizing that the gyros have failed. While IFR pilots are taught
to contantly verify the indications between the various instruments
a prominate failure flag or annunciator is a big help.
Frankly, the IFR GPS really makes partial panel a lot easier. Zoom
up the thing so you can instantly see any track changes and watch the
altimeter and you'll find it's not too rough maintaining flight.
Punching the autopilot on is almost cheating.
(See what happens when you ask a question nice rather than throwing
out bull****).
Old April 9th 07, 05:15 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Ron Natalie writes:
Which types of pumps are used in most modern small aircraft?
they cost.
How many small aircraft have redundant pumps and gyros?
Are any small aircraft using RLGs?
go on me.
How hard is it to spot a pump failure? I've gotten the impression from what
I've read here and elsewhere that vacuum pumps may fail gradually and
insidiously, whereas (presumably) an electric motor fails in a much more
obvious way.
Does a failure involve the gyro coming to a stop, or can it just slow down and
thereby cause problems?
But how does that help you if the AI has failed? The GPS wouldn't tell you
the attitude of your aircraft.
Wet vs Dry Vacuum Pump Fastglasair Owning 7 December 17th 04 11:46 PM
Wet Vacuum Pump smackey Owning 6 February 24th 04 07:03 PM
Reverse Vacuum Damging to Instruments? O. Sami Saydjari Owning 8 February 16th 04 04:00 AM
