I've been reading about oral exams for a private pilot license (in the U.S.),
and two questions have come to mind. Where does this exam take place? Is it in a classroom, or in a testing center, or is it actually in the aircraft? When you are asked math-type questions, are you expected to answer with just a ballpark figure or an exact answer? In the latter case, can you use a calculator, or pencil and paper, or must you do it in your head? If I'm asked how long it will take to go 84 nm at 120 kts, I know that it's about 40 minutes, but if an exact answer is required I don't see how I could practically provide that without a calculator. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Where does this exam take place? Is it in a classroom, or in a testing center, or is it actually in the aircraft? It's usually done at the point of the checkride, inside the FBO in some convenient place where you go over the paperwork and then outside in the vicinity of the aircraft, typically the candidate being asked questions while demonstrating the checkride. When you are asked math-type questions, are you expected to answer with just a ballpark figure or an exact answer? In the latter case, can you use a calculator, or pencil and paper, or must you do it in your head? You're not typically asked math-type questions. Generally questions are asked about aircraft systems and your preflight planning is examined. In flight, you might be asked to compute some things as part of your normal cross country navigation. Accuracy to what you can get on the whizwheel is accceptable. If I'm asked how long it will take to go 84 nm at 120 kts, I know that it's about 40 minutes, but if an exact answer is required I don't see how I could practically provide that without a calculator. Whizwheels were the classic, calculators are acceptable. |
Ron Natalie writes:
Whizwheels were the classic, calculators are acceptable. A whizwheel being like the small E6-B I got at the pilot store? I still haven't studied it very much, although I used to be very good with a slide rule. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Ron Natalie writes: Whizwheels were the classic, calculators are acceptable. A whizwheel being like the small E6-B I got at the pilot store? that's the one. Though whizwheel is a more generic term for circular slide rules and can also refer to different variants like the Jeppesen CR-5 (the main difference is how the wind triangle is computed on the backside) --Sylvain |
On Apr 9, 5:54 pm, Ron Natalie wrote:
Mxsmanic wrote: Where does this exam take place? Is it in a classroom, or in a testing center, or is it actually in the aircraft? It's usually done at the point of the checkride, inside the FBO in some convenient place where you go over the paperwork and then outside in the vicinity of the aircraft, typically the candidate being asked questions while demonstrating the checkride. When you are asked math-type questions, are you expected to answer with just a ballpark figure or an exact answer? In the latter case, can you use a calculator, or pencil and paper, or must you do it in your head? You're not typically asked math-type questions. Generally questions are asked about aircraft systems and your preflight planning is examined. In flight, you might be asked to compute some things as part of your normal cross country navigation. Accuracy to what you can get on the whizwheel is accceptable. If I'm asked how long it will take to go 84 nm at 120 kts, I know that it's about 40 minutes, but if an exact answer is required I don't see how I could practically provide that without a calculator. Whizwheels were the classic, calculators are acceptable. Traditionally the students were told what calculations to do ahead of time and would arrive with a flight plan, W&B, performance, balanced field, etc asked for by the DE the night before the ride. However, the FSDO is now asking the examiners to throw those out and make the student do another one right there to ensure the CFI isn't doing it for them. Usually the DE will ask the student to plan some sort of cross country (complete with runway requirements, performance, etc), then go get coffee and 1/2 watch the process but then go over the results. A great DE sets aside the entire day for the checkride to avoid rushing the student, although 1/2 a day is probably the most common. -Robert, CFII |
![]() "Robert M. Gary" wrote in message oups.com... On Apr 9, 5:54 pm, Ron Natalie wrote: Mxsmanic wrote: Where does this exam take place? Is it in a classroom, or in a testing center, or is it actually in the aircraft? It's usually done at the point of the checkride, inside the FBO in some convenient place where you go over the paperwork and then outside in the vicinity of the aircraft, typically the candidate being asked questions while demonstrating the checkride. When you are asked math-type questions, are you expected to answer with just a ballpark figure or an exact answer? In the latter case, can you use a calculator, or pencil and paper, or must you do it in your head? You're not typically asked math-type questions. Generally questions are asked about aircraft systems and your preflight planning is examined. In flight, you might be asked to compute some things as part of your normal cross country navigation. Accuracy to what you can get on the whizwheel is accceptable. If I'm asked how long it will take to go 84 nm at 120 kts, I know that it's about 40 minutes, but if an exact answer is required I don't see how I could practically provide that without a calculator. Whizwheels were the classic, calculators are acceptable. Traditionally the students were told what calculations to do ahead of time and would arrive with a flight plan, W&B, performance, balanced field, etc asked for by the DE the night before the ride. However, the FSDO is now asking the examiners to throw those out and make the student do another one right there to ensure the CFI isn't doing it for them. Usually the DE will ask the student to plan some sort of cross country (complete with runway requirements, performance, etc), then go get coffee and 1/2 watch the process but then go over the results. A great DE sets aside the entire day for the checkride to avoid rushing the student, although 1/2 a day is probably the most common. -Robert, CFII I had only ever heard of the 1/2 day scheduling--so now I'm curious: Does a geate DE actually use the entire day, or just have it available? Peter |
On Apr 10, 6:47 am, "Peter Dohm" wrote:
"Robert M. Gary" wrote in ooglegroups.com... On Apr 9, 5:54 pm, Ron Natalie wrote: Mxsmanic wrote: Where does this exam take place? Is it in a classroom, or in a testing center, or is it actually in the aircraft? It's usually done at the point of the checkride, inside the FBO in some convenient place where you go over the paperwork and then outside in the vicinity of the aircraft, typically the candidate being asked questions while demonstrating the checkride. When you are asked math-type questions, are you expected to answer with just a ballpark figure or an exact answer? In the latter case, can you use a calculator, or pencil and paper, or must you do it in your head? You're not typically asked math-type questions. Generally questions are asked about aircraft systems and your preflight planning is examined. In flight, you might be asked to compute some things as part of your normal cross country navigation. Accuracy to what you can get on the whizwheel is accceptable. If I'm asked how long it will take to go 84 nm at 120 kts, I know that it's about 40 minutes, but if an exact answer is required I don't see how I could practically provide that without a calculator. Whizwheels were the classic, calculators are acceptable. Traditionally the students were told what calculations to do ahead of time and would arrive with a flight plan, W&B, performance, balanced field, etc asked for by the DE the night before the ride. However, the FSDO is now asking the examiners to throw those out and make the student do another one right there to ensure the CFI isn't doing it for them. Usually the DE will ask the student to plan some sort of cross country (complete with runway requirements, performance, etc), then go get coffee and 1/2 watch the process but then go over the results. A great DE sets aside the entire day for the checkride to avoid rushing the student, although 1/2 a day is probably the most common. -Robert, CFII I had only ever heard of the 1/2 day scheduling--so now I'm curious: Does a geate DE actually use the entire day, or just have it available? Peter- Hide quoted text - - Show quoted text - As a CFI I appreciate it when a DE only does one checkride per day because it puts less time pressure on the student. Sometimes things don't work out right and extra time is needed. If the checkride is at 9am and the DE has another at noon, the DE will be more pressured. About 1/2 the DEs will only schedule one per day because of this. However, at $400 a pop, I can see why someone would want to do more than 1 per day. Around here the DEs are scheduled pretty far out. Many schedule 40 days out (which is REALLY hard as a CFI to ensure the student "peaks" at the right time, accounting for illness, maintenance, etc). Other DEs will only work out of certain airports (simply because they dont' want to drive far from their house). We have a great bunch of DEs out here (don't get me wrong) but the more flexibility they give the student, the easier it is for me to make the stars align at the right time. -Robert |
![]() Traditionally the students were told what calculations to do ahead of time and would arrive with a flight plan, W&B, performance, balanced field, etc asked for by the DE the night before the ride. However, the FSDO is now asking the examiners to throw those out and make the student do another one right there to ensure the CFI isn't doing it for them. Usually the DE will ask the student to plan some sort of cross country (complete with runway requirements, performance, etc), then go get coffee and 1/2 watch the process but then go over the results. A great DE sets aside the entire day for the checkride to avoid rushing the student, although 1/2 a day is probably the most common. -Robert, CFII I had only ever heard of the 1/2 day scheduling--so now I'm curious: Does a geate DE actually use the entire day, or just have it available? Peter- Hide quoted text - - Show quoted text - As a CFI I appreciate it when a DE only does one checkride per day because it puts less time pressure on the student. Sometimes things don't work out right and extra time is needed. If the checkride is at 9am and the DE has another at noon, the DE will be more pressured. About 1/2 the DEs will only schedule one per day because of this. However, at $400 a pop, I can see why someone would want to do more than 1 per day. Around here the DEs are scheduled pretty far out. Many schedule 40 days out (which is REALLY hard as a CFI to ensure the student "peaks" at the right time, accounting for illness, maintenance, etc). Other DEs will only work out of certain airports (simply because they dont' want to drive far from their house). We have a great bunch of DEs out here (don't get me wrong) but the more flexibility they give the student, the easier it is for me to make the stars align at the right time. -Robert Thanks, that's a lot of good information that I never knew. Peter |
Robert M. Gary wrote:
Traditionally the students were told what calculations to do ahead of time and would arrive with a flight plan, W&B, performance, balanced field, etc asked for by the DE the night before the ride. Really? I don't remember that tradition. I took my ride in '88 and at that time, the DE would (maybe) tell you where the pseudo cross country was going to go. On the day of the examination, you were required to do the flight plan right there in front of the DE. As I recall, the PTS had a requrement that the flight plan must be completed in 30 min. Later on (in the rule overhaul of '96, IIRC), they dropped the 30 min. time limit. However, the FSDO is now asking the examiners to throw those out and make the student do another one right there to ensure the CFI isn't doing it for them. That's probably not a bad idea. More likely than a CFI doing the plan for the student, is the student just having a computer do the whole thing for him in advance. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200704/1 |
JGalban via AviationKB.com writes:
As I recall, the PTS had a requrement that the flight plan must be completed in 30 min. Later on (in the rule overhaul of '96, IIRC), they dropped the 30 min. time limit. Why was there ever a time limit? Presumably you prepare flight plans in advance, and it's not a race against the clock, but something you do deliberately and carefully, however long it takes. -- Transpose mxsmanic and gmail to reach me by e-mail. |
CFII oral exam guide questions? | Robert M. Gary | Instrument Flight Rules | 27 | June 14th 06 04:42 PM |
Oral Exam Prep -- recommendations and recollections | Nicholas Kliewer | Instrument Flight Rules | 0 | November 15th 04 05:00 PM |
Commercial Pilot FAA Knowledge Exam - Includes Gleim TestPrep & Commercial Pilot FAA Knowledge Exam book | Cecil Chapman | Products | 1 | November 15th 04 04:22 PM |
Private Pilot Oral | Pete | Piloting | 9 | December 2nd 03 05:41 PM |
CPL/IR/MULTI ORAL | Ian Leslie | Piloting | 2 | July 11th 03 09:32 PM |
