It is time to upgrade the old laptop, was wondering if Window Vista is
compatible with the soaring software/hardware. So does the Edition of Vista matter? I think for my work needs [CAD and Desktop Publishing] I will end up with the Business edition, do these other versions cause any additional considerations? Ultimate Home Premium Home Basic SeeYou - seems like it has been tested ok WinScore ? StrePla - I think they issued a new compatible version. Winpilot 3D Winpilot Pro/Adv for PDA PDA hardwa I understand that Activesync is now called "Microsoft Windows Mobile Device Center" Sadly only Windows Mobile 2003 and Windows Mobile 5 are supported, older versions no longer: So old Compaq Aeros and many other Ipaqs cannot install new software upgrades since Active sync is not available. You may be able to connect and copy files but that is not the same as installing via activesync. SeeYou Mobile seems to have a workaround installing the contents of a zip onto the memory card. Since most new laptops do not include a serial port I plan to add a serial port adapter pcmcia card. [to be capatible with my Volkslogger, and Garmin as well as other peoples serial port stuff] Would appreciate feedback. Chris |
Are there not current work-arounds for Active-Sync available? Do we
really have to pitch our trusty Compaq Aeros? |
My question is, how can you have the need to upgrade your laptop's OS
but not need to upgrade your Compaq Aero platform? |
Er... Uh... It is not a matter of money or prestige. The Aero still
has the most readable screen in daylight out there. Period. I know people who are hoarding them. I have 3 or 4 myself ... just in case.... BTW, because of the built-in CF card slot, I _never_ use ActiveSync. Larry "zero one" USA "Tuno" wrote in message ups.com: My question is, how can you have the need to upgrade your laptop's OS but not need to upgrade your Compaq Aero platform? |
On Apr 10, 5:25 pm, "Tuno" wrote:
My question is, how can you have the need to upgrade your laptop's OS but not need to upgrade your Compaq Aero platform? My windows 98SE machine only has dial-up internet access, do I really need to say more? And my PDA has Windows Mobile 2003 SE. So I'm not worried about Aeros for myself - that was just brought up to make others aware of the issue of losing support. |
Hi,
If you are simply copying waypoints and soaring software you can use a CF card reader with your PC. There is no real need to connect the Aero 1500 to the PC. Paul Remde Cumulus Soaring, Inc. wrote in message oups.com... Are there not current work-arounds for Active-Sync available? Do we really have to pitch our trusty Compaq Aeros? |
On Apr 10, 6:08 pm, "Paul Remde" wrote:
If you are simply copying waypoints and soaring software you can use a CF card reader with your PC. There is no real need to connect the Aero 1500 to the PC. Paul Remde Maybe for Glidenav you just copy the file over. Other programs like WinPilot and others needed to be installed on the PDA via ActiveSync. |
On Apr 10, 4:43 pm, "chris" wrote:
It is time to upgrade the old laptop, was wondering if Window Vista is compatible with the soaring software/hardware. So does the Edition of Vista matter? Don't know. SeeYou - seems like it has been tested ok I've used this without problems on my Vista Home Premium. (But I still hate Vista. I don't need a nanny, and I've turned off all that user account control stuff.) StrePla - I think they issued a new compatible version. I've used StrePla with no problem. Winpilot 3D Winpilot Pro/Adv for PDA PDA hardwa I understand that Activesync is now called "Microsoft Windows Mobile Device Center" Sadly only Windows Mobile 2003 and Windows Mobile 5 are supported, older versions no longer: So old Compaq Aeros and many other Ipaqs cannot install new software upgrades since Active sync is not available. You may be able to connect and copy files but that is not the same as installing via activesync. I've been able to install Pocket StrePla fine on my Axim, which is a WM5 device. Since most new laptops do not include a serial port I plan to add a serial port adapter pcmcia card. [to be capatible with my Volkslogger, and Garmin as well as other peoples serial port stuff] Why wouldn't you use a USB serial port? Probably easier and cheaper, I would think. One thing about Vista is that it's a memory hog. The laptop you buy will probably have .5 or 1GB, but that's not enough. You will need to upgrade to 2GB to get performance like the same machine would give you with an XP machine and 1GB. And the builder will probably give you that 1GB by filling both slots with .5GB SODIMMs, which means that you will end up with two wasted chips. *******s! Ed |
I like the AERO....I can see it and I don't miss the pretty colors.
But my laptop is Windows98 and the motherboard is on its last legs...both of these I use for soaring only. So I suppose I can shop Ebay for a good price on an XP laptop. I fly a 20 year old Ventus with SNAV-GPSNAV and that works for me. So pitching a perfectly fine 8 year old PDA is not a priority if I can avoid it. Hell, I even have cracks on my gelcoat for that matter ![]() |
On 10 apr, 23:25, "flying_monkey" wrote:
One thing about Vista is that it's a memory hog. The laptop you buy will probably have .5 or 1GB, but that's not enough. You will need to upgrade to 2GB to get performance like the same machine would give you with an XP machine and 1GB. And the builder will probably give you that 1GB by filling both slots with .5GB SODIMMs, which means that you will end up with two wasted chips. *******s! Ed Which is nonsense. I've been running Vista (Premium) quite a while and with 1GB it runs fine, comparable with XP Pro. Only due to the intense need of memory, mainly from Pro/E and Catia, combined expecially I upgraded to 3GB. |
| Thread Tools | |
| Display Modes | |
| Q: Apple MAC Book (pro) with Intel core 2 duo running Windows XP plus soaring software | Ruud | Soaring | 1 | October 31st 06 02:02 AM |
| XM Weather for laptops? | Morgans | Piloting | 7 | August 4th 05 03:17 AM |
| Windows XP & soaring | C.Fleming | Soaring | 11 | February 13th 04 05:47 PM |
| FLIGHTSOFT and VISTA by RMS Technology | Marv Hamm | Products | 1 | August 11th 03 09:19 PM |
