I went up today to practice crosswind landings. The wind was about down the
runway at my home airport so I went to Sky Manor (N40). This airport has a 2500x50 foot runway and requires vigilence in gusty winds. I did 2 landings and 1 go around (due to the gusty wind) using runway 25 at Sky Manor with a 90 degree crosswind of about 12-15 knots gusting to about 18-20kt. The landings here were pretty good. Well, I went back to my home airport and the wind was still mostly down the runway, but variable and gusty (in retrospect). Well, I built up too much speed (the approach is over trees and there was a bit of an updraft, plus I was a little high and probably subconsciously dove for the runway) and floated in the flare. The gusts caused the airplane to balloon and I was able to recover once, then it ballooned again and I should have gone around. However, I tried to save it and as I came down I added a bit of power to soften the landing, quickly began to balloon even higher and found myself very nose high, very little airspeed, and was heading off the runway due to a crosswind combined with low airspeed. I immediatly applied full power, lowered the nose to get some airspeed, and went around. Had I waited much longer to go around, the aircraft would soon have stalled 20 feet above the ground. Basically, I recovered from an imminent approach to landing stall 20 feet above the ground. This is not a good situation to get yourself in, to say the least. This scared me pretty good. I was complacent at my home airport because I am used to landing there, the runway is long, and the wind was basically down the runway. I fully expected variable gusty wind at Sky Manor and expected to go around resulting in me making a good early decision to go around when necessary, while I tried to recover from a poor approach at my home airport when I should have gone around earlier. In retrospect, I made some poor decisions, but ultimately had a safe outcome by making the right decision at the last second. |
am used to landing there, the runway is long, and the wind was basically down the runway. I fully expected variable gusty wind at Sky Manor... What's your home airport? I'm at Danbury, you too? Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
Jose wrote:
What's your home airport? I'm at Danbury, you too? Home of the coolest approach in CT on 35. G |
![]() "Jim Jones" wrote in message ... I went up today to practice crosswind landings. The wind was about down the runway at my home airport so I went to Sky Manor (N40). This airport has a 2500x50 foot runway and requires vigilence in gusty winds. I did 2 landings and 1 go around (due to the gusty wind) using runway 25 at Sky Manor with a 90 degree crosswind of about 12-15 knots gusting to about 18-20kt. The landings here were pretty good. Well, I went back to my home airport and the wind was still mostly down the runway, but variable and gusty (in retrospect). Well, I built up too much speed (the approach is over trees and there was a bit of an updraft, plus I was a little high and probably subconsciously dove for the runway) and floated in the flare. The gusts caused the airplane to balloon and I was able to recover once, then it ballooned again and I should have gone around. However, I tried to save it and as I came down I added a bit of power to soften the landing, quickly began to balloon even higher and found myself very nose high, very little airspeed, and was heading off the runway due to a crosswind combined with low airspeed. I immediatly applied full power, lowered the nose to get some airspeed, and went around. Had I waited much longer to go around, the aircraft would soon have stalled 20 feet above the ground. Basically, I recovered from an imminent approach to landing stall 20 feet above the ground. This is not a good situation to get yourself in, to say the least. This scared me pretty good. I was complacent at my home airport because I am used to landing there, the runway is long, and the wind was basically down the runway. I fully expected variable gusty wind at Sky Manor and expected to go around resulting in me making a good early decision to go around when necessary, while I tried to recover from a poor approach at my home airport when I should have gone around earlier. In retrospect, I made some poor decisions, but ultimately had a safe outcome by making the right decision at the last second. I had a rash of bad night landings and decided that I forgot what the hell to do and took an instructor with me a few days later. Made a huge difference and I got my confidence back and my night landings improved hugely. Try taking an instructor to the airport you are having troubles at and see if they can provide some insight, worked for me. ----------------------------------------------------------- DW |
am used to landing there, the runway is long, and the wind was basically down the runway. I fully expected variable gusty wind at Sky Manor and expected to go around resulting in me making a good early decision to go around when necessary, while I tried to recover from a poor approach at my home airport when I should have gone around earlier. In retrospect, I made some poor decisions, but ultimately had a safe outcome by making the right decision at the last second. I always approach a landing with the intent to go around... If I actually land I consider it a bonus. :-) The Ultimate BBS! Telnet://ubbs2006.synchro.net HTTP://ubbs2006.synchro.net:81 |
Jim Jones wrote:
I went up today to practice crosswind landings. The wind was about down the runway at my home airport so I went to Sky Manor (N40). This airport has a 2500x50 foot runway and requires vigilence in gusty winds. I did 2 landings and 1 go around (due to the gusty wind) using runway 25 at Sky Manor with a 90 degree crosswind of about 12-15 knots gusting to about 18-20kt. The landings here were pretty good. Well, I went back to my home airport and the wind was still mostly down the runway, but variable and gusty (in retrospect). Well, I built up too much speed (the approach is over trees and there was a bit of an updraft, plus I was a little high and probably subconsciously dove for the runway) and floated in the flare. The gusts caused the airplane to balloon and I was able to recover once, then it ballooned again and I should have gone around. However, I tried to save it and as I came down I added a bit of power to soften the landing, quickly began to balloon even higher and found myself very nose high, very little airspeed, and was heading off the runway due to a crosswind combined with low airspeed. I immediatly applied full power, lowered the nose to get some airspeed, and went around. Had I waited much longer to go around, the aircraft would soon have stalled 20 feet above the ground. Basically, I recovered from an imminent approach to landing stall 20 feet above the ground. This is not a good situation to get yourself in, to say the least. This scared me pretty good. I was complacent at my home airport because I am used to landing there, the runway is long, and the wind was basically down the runway. I fully expected variable gusty wind at Sky Manor and expected to go around resulting in me making a good early decision to go around when necessary, while I tried to recover from a poor approach at my home airport when I should have gone around earlier. In retrospect, I made some poor decisions, but ultimately had a safe outcome by making the right decision at the last second. You need a nastier home airport to keep you from getting complacent. At mine the 3 wind socks are usually pointed in three different directions. I can't count the times I was at the point of congratulating myself on a great landing when I suddenly found myself 10 to 20 feet back in the air or suddenly heading for a taxiway. I was bitching about how squirrely the air is to one of the local CFI's one day. He just laughed and said if I can land it there, everywhere else short of a rolling aircraft carrier should be a piece of cake. He's right. -- Jim Pennino Remove .spam.sux to reply. |
20 feet above the ground. This is not a good situation to get yourself in, to say the least. This scared me pretty good. I was complacent at my home airport You don't say how much experience you've got, but I think you did just fine. You came close to bending an airplane, and walked away unscathed -- the best possible outcome. This extra shot of adrenaline will serve you well down the road, trust me. In short, you will never, EVER be complacent while landing again. I know, because I (as, I'm sure, most pilots) have scared the crap outta myself on landing a few times, and I now approach every landing as a potential go-round. Honestly, looking back at my first couple of hundred hours, I'm amazed I didn't break something. Let's see, just off the top of my head I remember these two: - A landing in Rockford, IL, in a REALLY nasty crosswind, where I froze on the controls with full left rudder applied. This was my crosswind correction, but -- in a Piper -- the nosewheel and rudder are linked. When I lowered the nose, guess which way the plane headed, really fast? Oops.... - A landing at little bitty Sylvania Field (C89), in a Skyhawk, where I had to do a go 'round and chose to raise the electric flaps completely while low, slow, and out of ideas. Gosh, those trucks on the freeway (at the departure end of Rwy 8) sure got big! Ooops... I just asked Mary about her scary landings, and she replied that "We try to block those from our memory..." I'm sure there have been more, but you get the idea -- we all have them. Another thing you'll find -- you ALWAYS nail the tough landings. If I know the landing is going to be challenging (due to wind, or whatever) it's almost always a greaser -- while the ones I expect to be a "piece of cake" are usually the clunkers. --- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Mary's most scarry landing (as documented here)... AirVenture 200?
[This Oldtimers stuff is really something. One year seems like two, two seems like five...) Jay Honeck wrote: I just asked Mary about her scary landings, and she replied that "We try to block those from our memory..." I'm sure there have been more, but you get the idea -- we all have them. |
[This Oldtimers stuff is really something. One year seems like two, two seems like five...) True, but that was a situation-induced scary landing, not something caused by inattention or a sudden gust of wind, as is the spirit of this thread. She simply followed the guy ahead of us, and the instructions of the controller, and ended up with a safe-but-all-too-exciting landing. BTW: That was 2005. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Tue, 10 Apr 2007 23:08:25 -0400, "Jim Jones"
wrote in : This scared me pretty good. I was complacent at my home airport because I am used to landing there, the runway is long, and the wind was basically down the runway. I fully expected variable gusty wind at Sky Manor and expected to go around resulting in me making a good early decision to go around when necessary, while I tried to recover from a poor approach at my home airport when I should have gone around earlier. In retrospect, I made some poor decisions, but ultimately had a safe outcome by making the right decision at the last second. Thanks for sharing your honest introspection. You seem to blame your decisions for your difficulty, but because I didn't see you mention the word 'slip', I would guess your training lacked sufficient emphasis on the productive use of that maneuver. Applied vigorously, a forward slip will shed altitude rapidly, and it provides the pilot with authoritative control in terminating the descent almost immediately. In a cross wind approach, it's a natural. A truth I have discovered about gusty crosswind landings is, that there is a brief window of vulnerability during the flair and roundout whose duration needs to be minimized by a reduction in the approach speed within the limits of practicality. When the aircraft's attitude is nose-high, after the slip into the cross wind on approach must necessarily be terminated for fear of dragging a wing on the ground, the pilot has no good means of controlling lateral drift. If the wheels can be planted on the runway before sufficient lateral velocity and its inertia mount to unacceptable magnitude, all is well. But putting the wheels on the runway requires the aircraft to be stalled and no longer flying. |
++NEW++3 DVD SET 'ON LANDINGS' +Much More | Pilot Publications | Products | 0 | June 26th 04 03:42 PM |
++NEW++3 DVD SET 'ON LANDINGS' +Much More | Pilot Publications | General Aviation | 0 | June 26th 04 03:42 PM |
++NEW++3 DVD SET 'ON LANDINGS' +Much More | Pilot Publications | Aviation Marketplace | 0 | June 26th 04 03:42 PM |
Night landings vs. day landings | Gerald Sylvester | Piloting | 15 | February 12th 04 06:38 AM |
off airport landings | Stan Gosnell | Rotorcraft | 8 | September 13th 03 04:49 PM |
