transponder check?
Old August 11th 03, 06:48 PM
Russell Duffy
Default transponder check?
Greetings,
I'm expecting to make the first flight of an RV-3 later this month, and am
trying to figure out exactly what needs to be done about the transponder.
Does anyone know for sure? Since the plane is day VFR only, I'm pretty sure
I don't need to have the pitot static system tested.
Lots of people don't have any sort of certification done on experimentals,
but I think something is probably required. It seems like I've seen a
statement that says the manufacturer of the aircraft (that's me) is
responsible for verifying the operation of the transponder. If I call up
ATC from outside their airspace, and ask for a readout, isn't that verifying
the operation.
The minimum that I imagine, is having the transponder bench tested, which is
stupid, since it's a new unit, and was certainly tested at the factory.
More likely, the encoder (also factory new) should be tested with the
transponder on the bench to verify altitude readings, but that doesn't test
my wiring, which is the only real variable. No local avionics shop will come
to the airport to do a field test either.
FWIW, I called AOPA, and they didn't seem to really know. I have a call
into the EAA, and hope to get a reply later today. Naturally, the avionics
shops tell you that you need "the works". What do I really need?
Rusty
Turbo Mazda 13B powered RV-3 (zoom, zoom, zoom)
Old August 11th 03, 10:48 PM
Ken Sandyeggo
"Russell Duffy" wrote in message ...
Greetings,
the operation.
Rusty
Rusty,
What you really need is to stop asking questions at this point. I
agree with you that as the manufacturer, we are allowed to verify its
operation as stated in the FARS. I'm constantly in radar coverage and
a quick "whats my readout?" gets you the info you need. The FAR
addicts will jump in here about now and quote dozens of regulations of
why this is not allowed, but I say phhhhhht. Works for me.
Ken J. - Sandy, egg ho
Old August 11th 03, 11:21 PM
Russell Duffy
The FAR
Yeah, that worked for about a year and a half on my RV-8, until the POS
Narco transponder crapped out. The guy at the avionics shop was the one who
pointed out that I needed to get it re-certified. Of course my response was
"what do you mean RE-certified" :-)
Thanks for the comments. Maybe I won't call the FSDO about this :-)
Rusty
Old August 11th 03, 11:46 PM
Gerry Caron
news
Greetings,
sure
verifying
the operation.
The following are from Part 91 which covers all operations not under Parts
121 or 135. It doesn't matter whether you are flying an experimental, a
C172, or a Citation.
Part 91.413 for transponder checks applies regardless.
You're correct in that 91.411 for altimeter systems (incl: static system)
only applies if you want to fly IFR. But even VFR you may want ATC services
and if your altitude reporting is off, you may get a request to stop
altitude squawk.
Don't know what the reaction might be if you're in a Mode C required area
with a continually bad Mode C. But from a practical point of view; if
you've got Mode C, make sure it's working right. If it isn't working, it
certainly doesn't contribute much to safety and at worse could be a hazard
(If somebody else thinks you're at a given altitude when you're really at a
different altitude--think TCAS.)
The rules spell out the verification and who may do them. The tests are in
Appendix E and F of Part 43.
Old August 12th 03, 01:26 AM
Russell Duffy
in
First, I should point out that I DO care that the altimeter, and mode-C
agree, and are correct. That's actually more important to me than whether
it's legal, and there are simple ways to verify this, without having a
signature from an avionics shop.
I've been reading through appendix E and F, and the best I can tell, I can
take the transponder and encoder to an avionics shop, and have them bench
tested. This should be legal, though still absolutely meaningless, since my
wiring and antenna are still unknowns. Realistically, the only thing that
matters is having ATC confirm the readout, and having a formation aircraft
confirm my altimeter.
I'll call the avionics shop tomorrow and see if they agree to this plan.
I'd already be willing to wager that they won't.
Thanks,
Rusty
Old August 12th 03, 03:25 AM
Ken Sandyeggo
It's all so nebulous. There's one section on transponders and
altitude reporting equipment requirements that says it applies to
"airplanes and helicopters." An "experimental" is neither, it's an
"experimental" aircraft period. A gyroplane is not an airplane or a
helicopter. The FARS are such a general can of worms, if you ask 5
FAA employees for an interpretation, you'll usually get at least 3
differing answers. I'se keeps me mouf' shut, don't axe questions an'
goes about me bidniss.
KJSDCAUSA
"Gerry Caron" wrote in message . com...
news
Greetings,
sure
verifying
the operation.
altitude squawk.
Old August 14th 03, 02:53 AM
Dave
It's the 91.411 and 91.413 deal. Legally only the transponder check
(91.413) is required for VFR every 24 months.
But to use your encoder you also have to comply with part 43 appendix e
paragraph C, or anytime work has been done that could effect the mode c
output.
If your looking for someone to do this work in the DFW area I'll be
available in the next couple of weeks.
I'm just getting my repair station up and going for doing the VFR and
IFR system inspections.
Dave
Dallas tx
KJSDCAUSA
news
Greetings,
sure
verifying
the operation.
altitude squawk.
Old August 14th 03, 02:08 PM
Russell Duffy
"Dave" wrote in message
et...
output.
Thanks. I've talked to another shop, and have been told that they can come
to the airport for at least part of the check. They want to check the
transponder on the bench, then put it in the plane to check the system. I'm
trying to talk them into skipping the bench check, since it's a brand new
Garmin transponder. Unfortunately, the owner of the shop is the one I need
to talk to, and he's failed to return my call twice now.
How hard is it to get started as a repair station :-) (only half kidding)
Thanks,
Rusty
Old August 14th 03, 03:55 PM
Dave
et...
output.
Thanks,
Rusty
There is no real reason to bench check then check it in the airplane
except to verify the transponder works prior to a new installation or if
it is a mode "s" transponder, he may only have bench equipment to test it.
A bad antenna or antenna connection can swing a transponders frequency
out of range to pass the test.
He may be trying to get a baseline to validate the installation.
If he isn't charging more for the bench check and it's not a mode "s" go
for it. If he is charging lots more and your confident that the
installation is sound, make a few more calls.
Since your static system is new, it should be checked for leaks. That
can be done by an A&P, manufacturer or the guy who does your transponder
check.
You as the manufacutrer of the aircraft who installed the transponder
can also test and inspect the transponder installation, but it still
needs to comply with appendix f.
dave
Check this out! [email protected] Aerobatics 0 November 30th 04 12:58 AM
FS: Becker ATC-4401-175 Transponder, EA-401A ARC Servoed Encoding Alt Juan E Jimenez Home Built 0 August 6th 03 04:21 AM
check your tachometer Robert Scott Home Built 0 August 4th 03 05:05 PM
Recommendation for Radio, transponder and Altimeter Ron Natalie Home Built 0 July 8th 03 03:40 PM
