Quick Claim OLC
Old April 14th 07, 10:15 AM posted to rec.aviation.soaring
Mal[_3_]
Default Quick Claim OLC
http://www.onlinecontest.org/olc-2.0...aimType=glider
Try the quick claim link.
Mal
www.mals.net
Old April 14th 07, 11:29 AM posted to rec.aviation.soaring
Mal[_3_]
"Mal" wrote in message
Mal
www.mals.net
snip
Quite often competitors receive error message from the OLC while uploading
flight information and IGC files because of using software programs with
older release versions, or software, not approved for use by the OLC (the
server problems which appeared during the Easter weekend have no connection
with that issue). That is annoying for users and in particular it does not
have to be.
Therefore we want to kindly inform You, that the easiest and safest way for
claiming flights in the OLC is the direct claim method, including the upload
of Your IGC file.
If You are logged in, before starting the claim, a number of data is already
set automatically in the claim form and does not have to be entered once
again. Attention: Donīt forget to set a LOGIN name of Your choice in Your
personal data, otherwise You cannot LOGIN.
The absolutely perfect claim is possible, if Your logger contains already
the correct flight info concerning type of aircraft and call sign in exactly
the spelling, used in the OLC data base, because then the claim form does
not even appear during the claim, but the flight is scored correctly,
without any further action needed.
As You see, You dont need any software to claim Your flights in the OLC.
Give this direct claim method a chance and You will see, ist works
perfectly, not to say ingeniously.
Your OLC team
AMAZING OLC CLAIM [email protected] Soaring 6 March 1st 07 04:15 AM
SSA OLC Region for Flight Claim Jack Soaring 35 July 23rd 06 07:15 PM
PZL 62 Aircraft Claim robert arndt Military Aviation 10 January 8th 04 09:47 PM
My Plane Almost Became an Insurance Claim JimC Owning 17 September 30th 03 12:05 AM
My Plane Almost Became an Insurance Claim JimC Piloting 17 September 30th 03 12:05 AM
Copyright Đ2004-2025 AviationBanter.
