Mooney M20C Questions
Old April 18th 07, 04:10 PM posted to rec.aviation.owning
Greg Esres[_2_]
Default Mooney M20C Questions
On the hydraulic flaps, does the position of the silver pump handle
have any bearing on whether or not the hydraulic pressure leaks out of
the flap, once they are extended? (The POH doesn't say that it does.)
There is some mechanism underneath the instrument panel that has some
adjustment for the Positive Control. What does it do, exactly?
Old April 19th 07, 01:47 AM posted to rec.aviation.owning
Ron Rosenfeld
Yes. That's how you retract the flaps.
I don't recall anything at all like that in either the '68C or the '65E
models with which I have experience.
--ron
Old April 19th 07, 03:16 AM posted to rec.aviation.owning
Greg Esres[_2_]
No, the retraction mechanism is a little flap-like lever *above* the
silver handle. Lifting it up releases the hydraulic pressure. When
it's down, the pressure should remain.
The silver handle I'm talking about is the pumping handle.
The flaps are coming up some times when I'm not looking and I haven't
established a pattern yet. ;-)
--ron
Old April 19th 07, 04:03 PM posted to rec.aviation.owning
Ron Rosenfeld
Oh, I misread. It shouldn't make any difference, but I've always left it
fully down (out of the way). On occasion, during pre-flight, it might be in
an intermediate position, though. I'd suspect a leak in the hydraulic
system.
--ron
--ron
Old April 19th 07, 05:20 PM posted to rec.aviation.owning
Greg Esres[_2_]
Ron Rosenfield wrote:
I'd suspect a leak in the hydraulic system.
That's kinda what I was thinking. Thank you.
Old April 20th 07, 03:30 AM posted to rec.aviation.owning
Jim Carter[_1_]
If you're not having to add fluid, and you're probably not then the issue is the flap valve leaking through and relieving the pressure that keeps the flaps extended. We had that problem one year and a quick rebuild of the valve during the annual fixed the issue.
Jim Carter
Rogers, Arkansas
"Ron Rosenfeld" wrote in message ...
system.
--ron
--ron
Old April 19th 07, 03:34 AM posted to rec.aviation.owning
Jim Carter[_1_]
Although I have relatively little experience in this aircraft, the silver metal pump handle pumps the flaps down when the flap "lever" is in the down position, and the pump handle position didn't matter. (I always unconsciously pulled it back to the top stop whenever I used it however.) The flap "lever" is beside or immediately above the pump handle - I don't remember for sure.
I never saw anything labeled "Positive Control" on the bird I flew.
Jim Carter
Rogers, Arkansas
"Greg Esres" wrote in message ups.com...
Old April 19th 07, 04:27 AM posted to rec.aviation.owning
Greg Esres[_2_]
That's how I read the POH. However, the flaps seem to creep up
sometimes.
flew.
I thought they all had this? Probably no label....built-in wing
leveler.
Thanks
Old April 19th 07, 05:33 AM posted to rec.aviation.owning
Don Tuite
On 18 Apr 2007 20:27:36 -0700, Greg Esres
sometimes.
flew.
leveler.
brushed-aluminum pushbuttojn on left horn of yoke? extra knob on
turn-and-sllip?
Don
Old April 19th 07, 05:22 PM posted to rec.aviation.owning
Greg Esres[_2_]
Yes
extra knob on turn-and-sllip?
Hmmm, I don't think so. There is such a knob on the yoke itself that
is aileron trim. I don't think the system uses the panel turn & slip;
it has its own internal equivalent of a turn coordinator, according to
the documentation I've seen.
FS: 1965 Mooney M20C Ken Martin Aviation Marketplace 0 August 20th 05 03:09 AM
Mooney Down Teranews Piloting 0 February 17th 05 04:19 PM
64 M20C Turn/Slip replacement BellSouth.net News Owning 3 September 1st 04 03:07 PM
64 M20c Avionics Cover Sealing? BellSouth.net News Owning 2 August 23rd 04 03:42 AM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 06:06 AM
