Trip from F70 to L00 Thoughts?
Old April 19th 07, 02:00 AM posted to rec.aviation.piloting
Mike 'Flyin'8'
Default Trip from F70 to L00 Thoughts?
I am planning a short hop from F70 to L00 via KSBD at 7500. L00 is 16
miles west of Edwards AFB and just on the hairy edge of the Isabelle
MOA. However, I think I am safe since the MOA is not active on
Saturday, and it look like L00 is under a ring that is clear of the
MOA up to 1500AGL. Other than flying over some Class D South East is
there anything else that I am missing? In particular around Edwards
AFB. I do not want to be on the news. :-)
I would be very grateful if you of you more experienced flyers could
take a peek at Skyvector and give me a rundown on your thoughts or
concerns? Do I have all my bases covered?
Mike Alexander
PP-ASEL
Temecula, CA
See my online aerial photo album at
http://flying.4alexanders.com
Old April 19th 07, 02:12 AM posted to rec.aviation.piloting
Aluckyguess
Its no big deal. I have been there. Its a short flight from french valley.
Old April 19th 07, 02:47 AM posted to rec.aviation.piloting
Marc J. Zeitlin
Which pass are you going through?
.... However, I think I am safe since the MOA is not active on
MOA up to 1500AGL.
All true, but active or not, you can always fly through an MOA. I fly
out of KTSP and KMHV all the time, and there's rarely any military
traffic down low. Just keep your eyes open, which you should be doing
all the time anyway.
... Other than flying over some Class D South East is
Just stay out of the restricted airspace R-2515 - the MOA is no
problem. Talk to Joshua Approach (124.55 from your direction) once
you get past the San Gabriels and get flight following - they'll tell
you where everyone is (if anyone's even around). On weekends, the
restricted area is usually cold and you can fly through at or above 6K
ft., if you feel like getting a good look at Edwards' 15K ft. long,
300 ft. wide Shuttle landing runway.
Marc J. Zeitlin
http://www.cozybuilders.org/
Copyright (c) 2007
Old April 19th 07, 02:54 AM posted to rec.aviation.piloting
Mike 'Flyin'8'
I plan on flying through the Cajon Pass along the I15.
MOA up to 1500AGL.
Gotcha. I am scared of the UAVs and have never been comfortable with
MOA's.
So If I am above 6000 I can go right through the R-2515 area? I get
way freaked out with the MOA & Restricted stuff... I am gonna go dig
up my AIM/FAR and see what is says.
Mike Alexander
PP-ASEL
Temecula, CA
Old April 19th 07, 03:05 AM posted to rec.aviation.piloting
Mike 'Flyin'8'
Guess I should have added that I can go through after Jashua says I
can go through since they are the controlling agnecy.
Mike Alexander
PP-ASEL
Temecula, CA
Mike Alexander
PP-ASEL
Temecula, CA
Old April 20th 07, 04:23 PM posted to rec.aviation.piloting
Aluckyguess
Stop by KRAL and pick me up. I will go wth you. I will even buy lunch.
If you are interested email me. You can get my email @ kevinandrews.com
Old April 20th 07, 04:55 PM posted to rec.aviation.piloting
Flyin'[email protected]
Full flight this time. Maybe next time?
Mike Flyin'8
PP-ASEL
Temecula, CA
Old April 19th 07, 06:13 PM posted to rec.aviation.piloting
Steve Schneider
MOA up to 1500AGL.
MOA's.
From Fallbrook (L18) I'll normally fly to POM then V197 direct to PMD.
Going through Cajon Pass and then over towards Palmdale would actually
increase your exposure to potential UAV activity near Adelanto. See my
recent post under 'high winds in Palm Springs' regarding UAV activity
in the area. Personally, I have yet to spot one -- but that doesn't
mean they aren't on my six. :-) If you do overfly Palmdale (what
was that suggestion for knowing when your over a point? Roll inverted
and look up?) take a moment to scan the ramp. On various flights in
the past I've seen SR71s and U2s sitting on the tarmac there.
Calling Joshua Approach is excellent advice. Although I've yet to
be lucky enough to get permission to transit any of their restricted
airspace, they will help you avoid hazards in and around their
airspace.
If you're flying by pilotage, the 'shore' of the bone dry Rosamond Lake
is pretty well defined when viewed from the air, so you can easily
thread between Palmdale, Fox and and the restricted/MOA areas if you
are flying low -- just aim for the south west point of the lake.
You definitely want to talk to Joshua Approach -- do not just
'go right through' R-2515.
Not that one should count on this in general, but in the 'Midair
Collision Avoidance Handbook' provided by the Edwards test pilot
referenced in the Palm Springs thread, it says:
"Additionally, to avoid spilling out the lateral boundaries
of R-2508 Complex (the FAA frowns on such transgressions),
military pilots often give themselves a 3-5 mile buffer
along all boundaries."
For good reason, R-2508 itself is not depicted on the sectional since
it extends from FL200 on up. But the footprint matches basically all
of the Edwards resticted and MOA airspace depicted on the chart, hence
the entire collection of Edwards special use airpsace is referred to as
the R-2508 Complex.
So if the MOA is cold, a hot R-2515 should have a nice safety buffer
on the inside of the restricted area boarder. A comforting thought,
although it isn't guaranteed.
Have a safe flight.
Steve
Old April 19th 07, 11:46 PM posted to rec.aviation.piloting
Mike 'Flyin'8'
Ah. Good info. Thanks. I will certainly take a look at the POM
V197 and see what that does for me. The SR71 ain't got nothing on my
warrior. :-)
airspace.
It sound as if I don't fly over the lake and I should be ok. I was
actually thinking of skirting along mountain headed NW, and then when
clear of the Delta airspce head more northerly and intercept Rosemond
heading East. Flying at 6500/7500 and clearing the Delta and
decending for a direct in would be a fast descent. (My rambling
thoughhts...)
the R-2508 Complex.
Have a safe flight.
Steve
Thans for the info Steve, that is very helpful.
Mike Alexander
PP-ASEL
Temecula, CA
Thoughts on Oshkosh Jim Carter Piloting 0 August 1st 06 08:26 PM
My OSH thoughts Hilton Piloting 6 August 4th 05 10:03 PM
What are your thoughts on..... Ben Owning 46 March 23rd 04 03:50 PM
What are your thoughts on..... Ben Piloting 55 March 23rd 04 03:50 PM
Your thoughts on this 150 please Paul Folbrecht Owning 8 March 19th 04 02:14 AM
