OLC posting of EW Model D files
Old April 23rd 07, 12:10 AM posted to rec.aviation.soaring
Default OLC posting of EW Model D files
The time has arrived to start posting flights.
I am using SeeYou version 3.7 to download EW files from my Model D and
convert them to IGC format.
My attempts to post an April 20 flight have all failed to validated. The
flight is scored; however, there is an error message that states "Security
code in file does not match computed value." I have attempted post the
flight using the SeeYou utility to connect and upload the file; the "Direct
Claim (IGC-file)"; and, the "Prepared Claim (OLC-file)" options. However,
all yield the same unsatisfactory results.
Last year the EW Model D - SeeYou - OLC flow worked flawlessly.
Have other EW Model D users been having a similar problem making claims to
OLC-2007?
Any assistance in resolving this problem will be greatly appreciated.
HP-14 "6F"
http://www.soaridaho.com/
Old April 23rd 07, 12:44 AM posted to rec.aviation.soaring
Dan[_6_]
OLC-2007?
HP-14 "6F"http://www.soaridaho.com/
Hi Wayne;
I've had no problems with uploading to OLC lately.
I just go directly to OLC and claim the flight. It seems to go faster
than going through SeeYou. It's really easy now.
Hope that helps,
Dan Rihn
Old April 23rd 07, 02:54 AM posted to rec.aviation.soaring
JS
Welcome to the club!
Old April 23rd 07, 03:34 AM posted to rec.aviation.soaring
JS
But seriously Wayne,
Try again (including transferring files from the logger). And again
until it works. Something may have got corrupted in between. Took me
11 tries with WinPilot and 302 files last night and this morning, but
it may have worked.
Old April 23rd 07, 04:31 AM posted to rec.aviation.soaring
"JS" wrote in message
ps.com...
it may have worked.
So what you are telling me is that I need to download the file from my
recorder then make an OLC declariation. If it doesn't pass verification,
delete it and then repeat the process until it passes. Is that correct?
HP-14 "6F"
Old April 23rd 07, 04:04 PM posted to rec.aviation.soaring
In addition to the OLC-2007 failures I have been experience with files
transferred to my laptop using SeeYou, I am having the same problem using
the IGC approved EW Windows Uploader.
Has anyone had success making an OLC-2007 flight claim of a flight recorded
on an EW Model D? If so, send me an email describing the process you are
using.
I have emailed describing my problems and am waiting
for their reply.
Thank you,
HP-14 "6F"
"Wayne Paul" wrote in message
ps.com...
it may have worked.
HP-14 "6F"
Old April 23rd 07, 04:41 PM posted to rec.aviation.soaring
5Z
Wayne, after downloading your flight, does it pass the VALI-xxx.exe
check? If so, then the error is being introduced during the upload to
OLC. If not, then there is a problem with downloading from the FR to
your computer.
The impression I have based on the above comment is that the problem
is during transfer from the FR to your computer. If that is indeed
the case, then you must fix that problem before submitting to the OLC
unless you just want to set a placeholder for the flight prior to the
Tuesday deadline. Then the transfer issue must be resolved and
finally you can upload the valid file.
-Tom
Old April 23rd 07, 05:39 PM posted to rec.aviation.soaring
"5Z" wrote in message
your computer.
Tom,
Thank you for your suggestion; however, to the best of my knowledge a
separate VALI-xxx.exe program no longer exists for the EW Model D. My last
attempt was using the EW Windows Uploader found on the FAI site.
(http://www.fai.org/gliding/gnss/freeware.asp) This program produces an IGC
file which requires the download and conversion of the EW data file. It
would be a shame if this manufacture's product skips the validation process.
The process runs smoothly without any indication of a problem.
Again, thank you for taking the time to assist me.
Old April 26th 07, 10:40 AM posted to rec.aviation.soaring
Basil
Check that the Garmin that feeds your EWD is set to WGS84. If it
isn't then all records will be marked as invalid. I would imagine
this makes it fail the security check.
On Mon, 23 Apr 2007 09:04:16 -0600, "Wayne Paul"
using.
for their reply.
Thank you,
HP-14 "6F"
ps.com...
it may have worked.
HP-14 "6F"
Old April 26th 07, 01:46 PM posted to rec.aviation.soaring
"Basil" wrote in message
Basil,
EW Avionics has a copy of the problematic file. On initial evaluation they
have not been able to determine why it isn't passing their validation
software.
I have borrowed a friends EW Model D. Files transferred using EW Windows
Uploader, SeeYou and ConnectMe pass the EW IGCshell validation utility.
My Garmin 12xl is set to WGS 84.
Thank you for your suggestion.
HP-14 "6F"
http://www.soaridaho.com/Schreder
Posting Trouble Cody Dawg Piloting 3 November 29th 06 08:06 PM
OLC Posting Problem jcarlyle Soaring 4 September 28th 06 02:45 AM
and, since I am posting.... Dave Piloting 9 November 21st 05 01:36 AM
Ad posting help Newps Aviation Marketplace 0 August 16th 05 04:07 PM
Import/export AeroFly Pro models from/to other standard 3d model files such as *.3ds, *.x, *.lwo,... etc Simulators 0 March 27th 05 08:30 AM
