Autogas Tips and Tricks
Old April 27th 07, 03:09 AM posted to rec.aviation.piloting
Al[_2_]
Default Autogas Tips and Tricks
With 100LL now creeping toward the $5 mark (or more), it's time to
take advantage of the Peterson autogas STC in our 172E. What are the
tips and tricks for operating with mogas. Different run-up
techniques? Taxiing, hi temperatures, vapor lock avoidance, winter
ops. You name it. Inquiring minds want to know.
Thanks in advance.
Al
1964 172E
KSFF
Old April 27th 07, 03:25 AM posted to rec.aviation.piloting
Thanks in advance.
Trick number 1, find autogas without alcohol in it these days.
Jim Pennino
Remove .spam.sux to reply.
Old April 27th 07, 06:02 AM posted to rec.aviation.piloting
Robert M. Gary
Thanks in advance.
All the folks driving the Rotax 100hp engine
are using 91 octane mogas with about 5% alcohol
with no issues. I have no idea whether or not
that would be acceptable in a Lycoming or Continental.
Watch out if you have fibreglass tanks! Boaters are finding out (the
hard way) that the alcohol decomposes the resins into goo that gums up
carburetors, filters and lines.- Hide quoted text -
- Show quoted text -
The FAA has never issued any STC's allowing for
Old April 27th 07, 11:24 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
Mike Isaksen wrote:
I was talking to the Rotax guys (Lockwood or similar) and they mentioned the
same "ethanol up to 5% is OK" number. I got distracted and never asked the
followed up question re the problem that most east coast states typically
blend at 10%. Anyone heard or has any actual experience of running 10%.
It's more than just the engine. One of the problems with running ethanol
is that it may react with fuel system components that were not designed to
handle it. The engine manufacturer has no control over what goes into the
hoses, tanks, fuel pump diaphrams, etc...
That's the big problem with ethanol in most older aircraft. Ethanol wasn't
a factor when the fuel systems were designed and built in the 60s and 70s.
Ethanol can melt or swell some of the components used in those systems.
When I started using ethanal mogas in my old '69 Merc, I had composite
floats that turned to goo, and a couple of 1/4" rubber lines swelled up like
hot dogs.
Message posted via http://www.aviationkb.com
Old April 29th 07, 11:17 AM posted to rec.aviation.piloting
Cubdriver
On Fri, 27 Apr 2007 22:24:33 GMT, "JGalban via AviationKB.com"
As it was told to me, this is the problem for the Cubs.
Old April 27th 07, 03:28 AM posted to rec.aviation.piloting
Newps
You operate exactly the same way.
Thanks in advance.
Al
1964 172E
KSFF
MoGas Tips, Tricks, Concerns, How To Al Gilson Owning 129 May 17th 06 08:20 PM
A List to add to your bag of tricks... jsmith Instrument Flight Rules 1 April 8th 05 07:13 PM
Pocket PC Tips & Glide Navigator II Tips Paul Remde Soaring 0 December 14th 04 08:21 PM
"Dirty Tricks" and "Both Sides Do It" Leslie Swartz Military Aviation 19 March 29th 04 06:11 PM
Stupid Pilot Tricks David Dyer-Bennet Piloting 3 October 19th 03 12:22 AM
