In another online forum, it has been claimed that on the F-18, F-14,
F-4, and possibly F-8, A-7, A-6, and A-4, all the landing gear doors stay open when the gear are extended. While typically (or at least in most other military jets), some of the landing gear doors open only during extension/retraction, and are closed while the gear are extended. Can anyone comment on the extent to which this is true? If so, there's an obvious pattern of this characteristic appearing in fighter/attack jets which were originally designed for the Navy. Is this due to Navy "culture" or somehow related to a safety/reliability issue for carrier-based operation? Or generally, is there some reason that some jets are designed with gear doors that stay open, while others have doors that close after the gear are extended? (The only reasons I've seen that make sense are simplicity versus air drag and, in some cases, ground clearance.) Many thanks in advance. --Elliot Wilen |
Elliot Wilen wrote: Or generally, is there some reason that some jets are designed with gear doors that stay open, while others have doors that close after the gear are extended? Apart from what's already been mentioned I can add that the gear bay can contain things which you want to access during normal handling on the ground. On Draken for example the ground crew data entry panel is in the nose gear bay. That's why they open almost 180 deg. And speaking of air brakes, Gripen's front nose gear door doubles as one -- but only on the single seat version. -- Urban Fredriksson http://www.canit.se/%7Egriffon/ 1) What is happening will continue to happen 2) Consider the obvious seriously 3) Consider the consequences - Asimov's "Three Laws of Futurics", F&SF, Oct 74 |
"Urban Fredriksson" a écrit dans le message de ... In article , Elliot Wilen wrote: Or generally, is there some reason that some jets are designed with gear doors that stay open, while others have doors that close after the gear are extended? Apart from what's already been mentioned I can add that the gear bay can contain things which you want to access during normal handling on the ground. On Draken for example the ground crew data entry panel is in the nose gear bay. That's why they open almost 180 deg. And speaking of air brakes, Gripen's front nose gear door doubles as one -- but only on the single seat version. -- snip The same on F-18 ... Maintenance Codes Panel is in nose wheel well and air pressure indicator for APU in right main wheel well and associated hand pump in case of pressure lost (good work-out for tech if pressure drops regularly). There are also assorted pressure gauges and humidity indicators visible ... without having to open panels. Although having open wheel wells on landing does occassionaly (very occasionally) allow FOD to strike inside where there are a lot of small hydralic lines. A good post-flight inspection can help prevent a problems in this area. From what I have seen, other fighters seems to be built in the same way. I would assume cargo & civilian a/c are similiar. Pat |
| Thread Tools | |
| Display Modes | |
| Cessna landing gear legs Reserve MET! | Bill Berle | Home Built | 1 | February 23rd 04 01:31 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
