History question: homebuilt pushers
Old May 1st 07, 02:27 AM posted to rec.aviation.homebuilt
Default History question: homebuilt pushers
I was just looking back through the EAA Modern Mechanix Flying and
Gilder Manuals. None of the aircraft depicted were pushers -- except
for the Wright Flyers and some early Curtiss. In poking around for
old flying boat designs, I've found lots of pushers.
Does anyone know of any home built pushers from that era (1929-1932)?
I'm just curious.
Thanks.
Old May 1st 07, 10:27 PM posted to rec.aviation.homebuilt
wright1902glider
(1929-1932)?
I'm just curious.
Thanks.
That period isn't really my specialty, but I'd be surprised if you
find many, if any, pusher land aircraft. A pusher prop with or without
a chain-drive PSRU (sp?) has advantages on a flying boat because it
allows you to position the prop in an area that minimizes spray and
wave interference. On a large flying boat like a Sikorsky, Martin, or
Boeing its not so much of an issue since the wing and engines are well
above the water. However on something like an early Supermarine or
many of the Italian planes, it could matter. Pushers more or less
disappeared altogether between 1930 and 1945, then reappeared briefly
on the B-36. The jet era again forced them into obscurity and onto
Dick's drawing board.
FYI: Wilbur Wright preferred the pusher design for two reasons. First,
it minimized the number of aerodynamic factors he had to design for in
1903 since the airframe was not subject to prop wash. Second, it
worked in 1903 and continued to work, so the basic Wright powertrain
was never really modified or improved.
Harry Frey
Wright Brothers Enterprises
Old May 2nd 07, 02:59 PM posted to rec.aviation.homebuilt
Well, there's one homebuilt pusher from the era by extension, at least. The
Curtiss Junior was a production plane from the '30s...
http://www.oldrhinebeck.org/collecti...s%20Junior.htm
....and an all-wood homebuilt version was introduced in the '60s, called the
Woody Pusher.
http://www.sun-n-fun.org/content/interior.asp?section=museum&body=planes/woodys_pusher
Old May 3rd 07, 03:51 PM posted to rec.aviation.homebuilt
Woody Pusher.
That's the kind of thing I expected to see in the Flying and Glider
manuals! It just seemed odd that there were no pushers in the
manuals. (Okay, there's an airboat depicted at the end of one of the
books, but that article is about making propellors.) I wanted to see
the plans to a pusher of the era.
On to the next quest ...
Thanks, all.
M
Old May 2nd 07, 05:56 PM posted to rec.aviation.homebuilt
John[_9_]
On May 2, 2:28 am, Richard Riley wrote:
On 1 May 2007 14:27:21 -0700, wright1902glider
In WW2 there were several pusher fighters that never made it past the
drawing board or prototype stage. Blohm und Voss P.207/2 ,Dornier
P.247/6 Borovkov-Florov "D", Curtis P-55 Ascender, Kyushu J7W1
Shinden. My favorite (and probably the most whimsical) was the
Daimler-Benz Jaeger. Don't know if it's a pusher or not.
Don't know of any homebuilt pushers from that era.
There was at least one pusher fighter that made past prototype stage.
The SAAB J21 was a twin boom tricycle gear single engine pusher. It
was later modified into a jet with some success.
John Dupre'
Old May 2nd 07, 07:40 PM posted to rec.aviation.homebuilt
Go He http://www.wwiaviation.com/framer/pl...ish/index.html
and look up (click on Select An Aircraft):
Airco DH-2
RAF F.E.-2d
RAF F.E.-8
Go to http://www.spartacus.schoolnet.co.uk/FWWpusher.htm to see
the Breguet M5.
And if you Google "Pusher Aircraft" images you'll get a bunch more.
There have been a heap of pusher airplanes all through aviation
history.
Dan
homebuilt glider question Stealth Pilot Soaring 9 July 10th 06 09:40 PM
Medical Question - History Pudealee Piloting 6 August 27th 04 09:59 PM
virgins (was: Question - Regarding Canard Pushers...) RobertR237 Home Built 1 August 10th 03 11:06 PM
Question - Regarding Canard Pushers... Tilt Home Built 33 August 10th 03 11:07 AM
question on intercoms for my new homebuilt w b evans Home Built 1 July 23rd 03 12:57 AM
