Hi,
Trying to run Glide Navigator II on an Aero 1550, and at the bottom of the screen there's a bar showing program name, clock, and keyboard button. This bar obscures a critical part of the screen showing wind direction, etc. I can't find the way to hide this bar, but believe it can be done. Anyone know how to hide it? Many thanks, Paul |
Are you sure you are running the correct version of the program?
There is a different version for models prior to the 1550 such as 1530 and 1520. If you are running the correct version, the status bar will be removed on startup. If, while running GNII, some other application is started by pressing a function key, etc., the status bar will also display. To get rid of this, just "restart" GNII by using the start menu. -Tom |
Hi,
One additional suggestion. If you are using the 1520 or 1530 version on a 1520 or 1530, you will also need to enable the taskbar to "autohide". Go to Start/Settings/Taskbar and check the "Auto hide" checkbox. The taskbar will then hide. The bring it up you need to touch the very bottom edge of the screen with the stylus. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "5Z" wrote in message oups.com... Are you sure you are running the correct version of the program? There is a different version for models prior to the 1550 such as 1530 and 1520. If you are running the correct version, the status bar will be removed on startup. If, while running GNII, some other application is started by pressing a function key, etc., the status bar will also display. To get rid of this, just "restart" GNII by using the start menu. -Tom |
| Compaq aero question | quietman | Soaring | 3 | January 25th 06 04:47 PM |
| Compaq 1550 Aero -w- POCKET-NAV Software For Sale | Guy Byars | Soaring | 0 | September 19th 05 11:19 AM |
| FS: Aero 1550 | GH | Soaring | 1 | September 24th 04 03:59 AM |
| FS Aero 1550 | Ed Hollestelle | Soaring | 0 | July 12th 04 09:10 PM |
| USB to Compaq Aero 1550 Cable | Ira Blieden | Soaring | 1 | April 23rd 04 04:12 PM |
