Does anyone know if the cigarette lighter plug that comes with the
Garmin 396 can be used on a 24-volt system (assuming it would physically fit) The manual is vague on this. --Dan |
Is the 24Volt system stepped down to 12Volt for the Cig lighter?
Check the auto/aircraft manual for that one. There are not too many appliances that are ready to plug into 24Volt systems. Could always "smoke check" with a cheaper appliance. BT "Dan" wrote in message oups.com... Does anyone know if the cigarette lighter plug that comes with the Garmin 396 can be used on a 24-volt system (assuming it would physically fit) The manual is vague on this. --Dan |
In my 28 volt plane the cigar lighter jack was wired in series with a low
ohmage power resistor. This was undoubtedly to allow the use of a standard car-type 12 volt heater element in the lighter. With a GPS plugged into the jack, I got 28 volts. "BT" wrote in message ... Is the 24Volt system stepped down to 12Volt for the Cig lighter? |
![]() Quote:
Yes it can.
What is vague about "Power source: 11-35 VDC"
Karl "Dan" wrote in message oups.com... Does anyone know if the cigarette lighter plug that comes with the Garmin 396 can be used on a 24-volt system (assuming it would physically fit) The manual is vague on this. --Dan |
That is for the unit. Garmin calls the cigarette lighter adaptor the
"12-volt" adaptor. Sounds like it should be called the "11-35V adaptor". Perhaps ambigous would be a better word than vague. --Dan On May 9, 9:57 pm, "karl gruber" wrote: What is vague about "Power source: 11-35 VDC" Karl "Dan" wrote in message oups.com... Does anyone know if the cigarette lighter plug that comes with the Garmin 396 can be used on a 24-volt system (assuming it would physically fit) The manual is vague on this. --Dan- Hide quoted text - - Show quoted text - |
Volt/Ammeter | ccwillwerth | Home Built | 0 | January 19th 06 02:38 AM |
WTB: Power or cigarette lighter cable for Garmin GPS195 | Larry Rachman | Aviation Marketplace | 1 | December 22nd 04 08:47 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
5 volt DC power converters | John Ferguson | Soaring | 6 | February 28th 04 07:15 AM |
24/12 volt DC converter | Victor J. Osborne, Jr. | Products | 1 | February 18th 04 02:11 PM |
