Control Tower without class D
Old May 16th 07, 03:52 AM posted to rec.aviation.piloting
Danny Deger
Default Control Tower without class D
In another thread, I have just read that there might be controlled airports
without having class D airspace, and pilots are supposed to know this and
know to contact the tower and stay of their non-class D airspace if they are
not in contact with the tower.
Can anyone confirm this?
Danny Deger
Old May 15th 07, 04:08 AM posted to rec.aviation.piloting
Robert M. Gary
Danny Deger
That's what we had at Mather, California before the tower had ATIS
weather.
-Robert
Old May 15th 07, 04:33 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Danny Deger" wrote in message
airports without having class D airspace, and pilots are supposed to know
this and know to contact the tower and stay of their non-class D airspace
if they are not in contact with the tower.
There's one at FLD every summer.
Old May 15th 07, 03:40 PM posted to rec.aviation.piloting
Yes. Read 91.126(d) in CFR14 (used to be FAR's). It talks about
operating in vicinity of an airport in class G airspace. Scroll down
to (d) and it talks about communication with control towers.
A couple of examples are Fort Worth Spinks (KFWS) and Grand Prairie
(KGPM) on the south side of Dallas. There are other examples out
there.
You can view the sectional charts here http://skyvector.com/
And below is the relevant text from 14 CFR 91.126(d)
§ 91.126 Operating on or in the vicinity of an airport in Class G
airspace.
top
(d) Communications with control towers. Unless otherwise authorized or
required by ATC, no person may operate an aircraft to, from, through,
or on an airport having an operational control tower unless two-way
radio communications are maintained between that aircraft and the
control tower. Communications must be established prior to 4 nautical
miles from the airport, up to and including 2,500 feet AGL. However,
if the aircraft radio fails in flight, the pilot in command may
operate that aircraft and land if weather conditions are at or above
basic VFR weather minimums, visual contact with the tower is
maintained, and a clearance to land is received. If the aircraft radio
fails while in flight under IFR, the pilot must comply with §91.185.
[Doc. No. 24458, 56 FR 65658, Dec. 17, 1991, as amended by Amdt. 91-
239, 59 FR 11693, Mar. 11, 1994; Amdt. 91-282, 69 FR 44880, July 27,
2004]
Danny Deger
Old May 16th 07, 07:09 PM posted to rec.aviation.piloting
Danny Deger
there.
Does anyone know why the FAA doesn't just put class D airspace around these
airports? This would make for a nice blue dash line on the map to show the
point the local tower must be contacted.
Danny Deger
airspace.
top
2004]
airports
are
Danny Deger
Old May 15th 07, 07:49 PM posted to rec.aviation.piloting
Jose
Does anyone know why the FAA doesn't just put class D airspace around these airports?
It would change the VFR minima?
Jose
Quantum Mechanics is like this: God =does= play dice with the universe,
except there's no God, and there's no dice. And maybe there's no universe.
Old May 16th 07, 12:15 PM posted to rec.aviation.piloting
Steven P. McNicoll
these airports?
Probably because it would have an adverse effect on operations.
Aeroplanner.com shows 34 helicopters based at GPM. Put a Class D surface
area there and there'd be a lot of requests for SVFR whenever the weather
was below VFR minima. SVFR aircraft have to be separated from each other
and from IFR aircraft.
show the point the local tower must be contacted.
You're free to draw a nice blue dash circle around these airports on your
sectional.
Old May 17th 07, 01:16 PM posted to rec.aviation.piloting
WAYNE
there.
You can view the sectional charts herehttp://skyvector.com/
airspace.
top
2004]
Danny Deger- Hide quoted text -
- Show quoted text -
Old May 15th 07, 04:39 PM posted to rec.aviation.piloting
Newps
Class G towers are temporary in nature. When we set up fire towers
every summer they are most often in class G. I wouldn't worry about the
rules as we controllers are really lax at places like this. There are
no tapes and the level of traffic is low. The runway separation rules
are just a guideline. We're not sending someone around because we're a
mere 500 feet short on the separation. You're only going to know about
class G towers by notam.
know this and know to contact the tower and stay of their non-class D
airspace if they are not in contact with the tower.
Danny Deger
Old May 15th 07, 06:00 PM posted to rec.aviation.piloting
Robert M. Gary
As I recall the class G tower at MHR lived for at least 6 months
before it became class D. It did appear on the sectional as I recall.
-Robert
FAA Control tower Abandoned Blowinginthewind Instrument Flight Rules 44 May 23rd 06 03:01 AM
i didn't know an ILS brought you right to the control tower james Piloting 27 August 20th 05 04:05 AM
OSH to get new control tower jsmith Piloting 9 May 22nd 05 06:29 PM
Tower Enroute Control? Sam Jones Instrument Flight Rules 5 June 2nd 04 02:31 AM
