I note that the Baron (and presumably other twins) has a prop sync switch that
somehow synchronizes the prop speeds on both engines. From recordings I've heard of the interior noise of the aircraft, it does sound as though props that are just slightly out of sync can produce a very irritating intermittent noise as they move in and out of phase. Is it very bothersome in real life? Also, how does the prop sync work? Does it actually move pitch or throttle levers or something? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Also, how does the prop sync work? I don't fly something fancy enough to have an automagic sync thingy; so I go by ear. It is a bit like tuning a guitar really, but fiddling with the throttle (you can't rely on either the throttle position nor the rpm indicators, not precise enough). --Sylvain |
I was taught and always used the prop control for sync.
Sylvain wrote: It is a bit like tuning a guitar really, but fiddling with the throttle --Sylvain |
RomeoMike wrote:
I was taught and always used the prop control for sync. Sylvain wrote: It is a bit like tuning a guitar really, but fiddling with the throttle you are right, I was wrong. Ooops. what was I thinking? going to hide myself under a rock for the next few hours... --Sylvain |
On 2007-05-21, Sylvain wrote:
I don't fly something fancy enough to have an automagic sync thingy; so I go by ear. It is a bit like tuning a guitar really, but fiddling with the Probably more like tuning a piano, since you're listening for the beat frequency (or lack thereof). -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
Mxsmanic wrote:
I note that the Baron (and presumably other twins) has a prop sync switch that somehow synchronizes the prop speeds on both engines. From recordings I've heard of the interior noise of the aircraft, it does sound as though props that are just slightly out of sync can produce a very irritating intermittent noise as they move in and out of phase. Is it very bothersome in real life? Also, how does the prop sync work? Does it actually move pitch or throttle levers or something? If you type in prop synch multi-engine planes into the google search window the first hit you will see is this The AVSIM Forums - Viewing topic #736 - Prop sync Out of synch propellers will not be as obvious or as annoying in a simulator as in a real plane. In most aircraft with prop synch, you first manually ... forums.avsim.net/dcboard.php?az=show_topic&forum=189&topic_id=736&m ode=full - 56k - Cached - Similar pages Go there , read it and you will know all you want to know. |
John Theune wrote:
Mxsmanic wrote: I note that the Baron (and presumably other twins) has a prop sync switch that somehow synchronizes the prop speeds on both engines. From recordings I've heard of the interior noise of the aircraft, it does sound as though props that are just slightly out of sync can produce a very irritating intermittent noise as they move in and out of phase. Is it very bothersome in real life? Also, how does the prop sync work? Does it actually move pitch or throttle levers or something? If you type in prop synch multi-engine planes into the google search window the first hit you will see is this The AVSIM Forums - Viewing topic #736 - Prop sync Out of synch propellers will not be as obvious or as annoying in a simulator as in a real plane. In most aircraft with prop synch, you first manually ... forums.avsim.net/dcboard.php?az=show_topic&forum=189&topic_id=736&m ode=full - 56k - Cached - Similar pages Go there , read it and you will know all you want to know. OMG - you want MX to actually *research* his trolling questions???? All by his little self???????? What fun is that?? |
John Theune writes:
If you type in prop synch multi-engine planes into the google search window the first hit you will see is this The AVSIM Forums - Viewing topic #736 - Prop sync Out of synch propellers will not be as obvious or as annoying in a simulator as in a real plane. In most aircraft with prop synch, you first manually ... forums.avsim.net/dcboard.php?az=show_topic&forum=189&topic_id=736&m ode=full - 56k - Cached - Similar pages Go there , read it and you will know all you want to know. Thanks. I guess people in the AVSIM forums actually answer questions rather than just point people to Google. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
John Theune writes: If you type in prop synch multi-engine planes into the google search window the first hit you will see is this The AVSIM Forums - Viewing topic #736 - Prop sync Out of synch propellers will not be as obvious or as annoying in a simulator as in a real plane. In most aircraft with prop synch, you first manually ... forums.avsim.net/dcboard.php?az=show_topic&forum=189&topic_id=736&m ode=full - 56k - Cached - Similar pages Go there , read it and you will know all you want to know. Thanks. I guess people in the AVSIM forums actually answer questions rather than just point people to Google. I had you blocked for a long time but took you off recently and see I made a mistake. Your still as much of a ass as before. Try to do a just a little bit of work yourself. |
Mxsmanic wrote in
: John Theune writes: If you type in prop synch multi-engine planes into the google search window the first hit you will see is this The AVSIM Forums - Viewing topic #736 - Prop sync Out of synch propellers will not be as obvious or as annoying in a simulator as in a real plane. In most aircraft with prop synch, you first manually ... forums.avsim.net/dcboard.php?az=show_topic&forum=189&topic_id=736 &mode =full - 56k - Cached - Similar pages Go there , read it and you will know all you want to know. Thanks. I guess people in the AVSIM forums actually answer questions rather than just point people to Google. Ooow 1Teh big flying circle jerk! you must be so happy there.. Bertie |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Piloting | 26 | January 13th 07 12:06 AM |
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Instrument Flight Rules | 15 | January 13th 07 12:06 AM |
CompaqAero1530 sync question | Stewart Kissel | Soaring | 0 | February 21st 05 03:15 AM |
Prop noise vs. engine noise | Morgans | Piloting | 8 | December 24th 03 03:24 AM |
