BD-5 crash in Australia
Old May 23rd 07, 03:31 PM posted to rec.aviation.homebuilt
wright1902glider
Default BD-5 crash in Australia
You may have finally made a positive point for hot-dogging. Anyone think of
a down side?
Jim in NC
Impact with unusual terrain or obsticles maybe. If there was enough
weather, such as windshear, microburst downdrafts, or severe
crosswinds I'd keep that rollerskate on the ground.
Thanks for the update Stealth. The last BD-5 I saw was a Corky
Forneau's (sp?) back in the mid 80's (the James Bond ship). I don't
remember a lot of the interior details, but the fuze did remind me of
a few dragsters that I've sat in. Not much between your backside and
the world. I've been considering an pioneer-era plane that has a very
low seating position and I've often thought about how to prevent
injury from spinal compression. I've thought about EPS foam like the
kind used in helmets as a way to absorb some of the energy. I know
that paraglider pilots have some sort of protection built into their
harnesses, but I've never seen exactly what its made of. Anyone ever
do any testing in this area?
Harry
Old May 23rd 07, 04:12 PM posted to rec.aviation.homebuilt
Paul Tomblin
It doesn't matter what sort of foam you've got if you haven't got
distance. You've got to get from the speed you impact at to zero in the
distance your butt is above the ground at impact, and the only way to make
it safer is to make raise your butt to give you more distance and fill the
gap with something that will use the whole distance to decellerate.
Paul Tomblin http://blog.xcski.com/
'Vegetarian' -- it's an old Indian word meaning 'lousy hunter'.
-- Red Green
Old May 24th 07, 02:29 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Wed, 23 May 2007 15:12:00 +0000 (UTC),
soft foam padding actually adds to the damage by delaying the onset of
deceleration of your body.
I read of a vertical slide tester that was set up to thest just this
problem and calibrated with the dummy sitting on a block of white
polystyrene just to get it in position.
then the various seats were put in place and tested for crash
worthiness.
the testers were surprised that none of the seats performed as well as
the polystyrene block.
If you look at a corby starlet plan the pilot is sitting on a six inch
block of polystyrene for just this reason.
Stealth Pilot
Old May 24th 07, 03:27 PM posted to rec.aviation.homebuilt
jerry wass
worthiness.
Stealth Pilot
I came to this conclusion 5 or 10 years ago & found some Urethane foam
that has more density & NO resilience than styrofoam & it's not
flammable either I have about 7" of room..Jerry
Old May 24th 07, 04:35 AM posted to rec.aviation.homebuilt
cavelamb himself
a down side?
Jim in NC
Harry
Harry, If you ever get a chance, take a look at the seats in a Helio
Courier. The legs are not straight tube, but curved so that they will
do a controlled collapse when over stressed.
Having broken my back in helicopters (twice actually), it has become
sorta important to me to protect what's left...
Richard
BD-5 crash in Australia Doug Gray Home Built 56 May 28th 07 08:43 AM
vampire or venom crash pic - wx904 crash.jpg (1/1) [email protected] Aviation Photos 4 January 1st 07 06:30 PM
vampire or venom crash pic - wx904 crash.jpg (0/1) [email protected] Aviation Photos 0 December 30th 06 04:57 PM
Australia Badwater Bill Home Built 18 January 3rd 05 03:57 AM
Casa, Australia anon Piloting 0 December 1st 03 01:47 AM
