I have a mid time (1000 SFNEW) IO-360 Lycoming engine.
Recently oil consumption has increased from about 1 quart/10 hours to about 1 quart/ 5 hours. For a long time we've collected oil on the bottom #1 plug but it seems like its worse now. In addition, we've had high aluminum levels in our oil samples for several years but now showing high iron and other harder metals. Blackstone is saying that our oil sample indicates high blow by and seems to show that a piston pin plug is now rubbing on the cylinder. The oil filter is still showing only a small amount of metal. The IA at the A&P school says the amount of metal in the filter is expected for any midtime engine, not excessive. Since the last couple of Blackstone reports have indicated the pin plug may now be rubbing on a cylinder we've been doing a boroscope every 10-20 hours of flight. However, the boroscope is still coming up with nothing (we have Nitrite cylinders and the cross hatching still looks great). Compressions were all very high (enough that the A&P is always a bit suprised to see them so high all around for a midtime engine) So, I'm wondering where I should go from here. 1) How can I tell if the oil from #1 is coming past the valves or the rings? 2) Is there any reason to believe the oil in #1 cylinder and the oil analysis issues are related? 3) Other than the oil usage in #1 I really have nothing to suggest one cylinder over the other for making metal in the oil sample. Should I just address the oil in the #1 cylinder and ignore the sample report until there are other signs (filter, boroscope, etc)? Or, should I just start pulling all cylinders (I'm told its about 10 hours of labor per cylinder ) until I find a busted pin plug? 4) I spoke with Lycoming. Although they didn't have any suggestions on how to determine which cylinder has the bad pin plug, they did mention that if we find the issue before there is much scraping on the cylinder we should be able to simply put the cylinder back on (and avoid sending it to a cylinder shop, saving lots of $$$). So basically the sooner I find this, the less expensive it will be (well, I guess if I have to pull 4 cylinders before I find it, it might not be less expensive). 5) If I find a pin plug broken what should I do? Several A&Ps have told me that pin plugs just work loose on Lycoming engines and I should just replace the busted one and forget it. Others have said I should do something to the engine to prevent the next plug from working loose (not sure what). -Robert |
Are you using sythetic oil?
If yes, how many of those 1000 hours have you been running synthetic oil? |
On May 23, 4:09 pm, john smith wrote:
Are you using sythetic oil? If yes, how many of those 1000 hours have you been running synthetic oil? I'm running Elite right now but I previously had always run Aeroshell 15w50 |
On 23 May 2007 08:09:20 -0700, "Robert M. Gary"
wrote: I have a mid time (1000 SFNEW) IO-360 Lycoming engine. Recently oil consumption has increased from about 1 quart/10 hours to about 1 quart/ 5 hours. For a long time we've collected oil on the bottom #1 plug but it seems like its worse now. What is the pattern of oil consumption? How often do you change your oil? Assuming a 50 hr change interval, a "loose" engine is going to burn as much oil in the last 10 hours as it did in the first 40-typically. In addition, we've had high aluminum levels in our oil samples for several years but now showing high iron and other harder metals. Blackstone is saying that our oil sample indicates high blow by and seems to show that a piston pin plug is now rubbing on the cylinder. Please bear in mind that one of the two piston pin plugs on each piston pin is going to be in contact with the cylinder wall during normal operations. The piston pin "floats" in the small end of the rod and in the piston. The piston pin plugs "float" in the piston pin bore in the piston. If you can tell me why in some cases they "rub" harder on the cylinder wall, you are ahead of Lycoming, they are still trying to figure it out. The oil filter is still showing only a small amount of metal. The IA at the A&P school says the amount of metal in the filter is expected for any midtime engine, not excessive. Since the last couple of Blackstone reports have indicated the pin plug may now be rubbing on a cylinder we've been doing a boroscope every 10-20 hours of flight. However, the boroscope is still coming up with nothing (we have Nitrite cylinders and the cross hatching still looks great). Compressions were all very high (enough that the A&P is always a bit suprised to see them so high all around for a midtime engine) Again, the piston pin plug is a relatively soft alloy, it may transfer to the cylinder wall like a crayon, but it is not going to disturb the material of the cylinder wall. So, I'm wondering where I should go from here. 1) How can I tell if the oil from #1 is coming past the valves or the rings? It is more likely to be coming from the valve guides at 1000 hours. 2) Is there any reason to believe the oil in #1 cylinder and the oil analysis issues are related? No idea. Only way to know for sure is to tear down the engine and physically inspect all the components. 3) Other than the oil usage in #1 I really have nothing to suggest one cylinder over the other for making metal in the oil sample. Should I just address the oil in the #1 cylinder and ignore the sample report until there are other signs (filter, boroscope, etc)? Or, should I just start pulling all cylinders (I'm told its about 10 hours of labor per cylinder ) until I find a busted pin plug? Better than half of "typical" Lycoming engines will have excessive valve guide clearance after 1000 hours of operation. Unless an increase in oil consumption is noted, a "wet" plug is found, or the e-valve starts leaking, it is not a notable occurence. Heard of the "wobble test"? 4) I spoke with Lycoming. Although they didn't have any suggestions on how to determine which cylinder has the bad pin plug, they did mention that if we find the issue before there is much scraping on the cylinder we should be able to simply put the cylinder back on (and avoid sending it to a cylinder shop, saving lots of $$$). So basically the sooner I find this, the less expensive it will be (well, I guess if I have to pull 4 cylinders before I find it, it might not be less expensive). Lycoming has a history of telling people that you can slide a cylinder off and on and "save money". Speaking from personal experience, if you remove a cylinder partially, and re-use it without a hone job and a new ring set, it is likely to pump oil (increased blow-by). You will have disturbed the working relationship between the rings and the cylinder wall, and in-service rings often "sack" or loose some of the spring tension that hold them "out" against the cylinder. Not sure how gambling on another R/R, where you will be doing the job properly (hone & ring set) is "less inexpensive". On most engine installations, getting all the garbage out of the way (and putting it all back on) is a much larger share of the labor cost than the actual cylinder R/Repair. 5) If I find a pin plug broken what should I do? Several A&Ps have told me that pin plugs just work loose on Lycoming engines and I should just replace the busted one and forget it. Others have said I should do something to the engine to prevent the next plug from working loose (not sure what). There is nothing to "work loose". There are two types of pin plugs in service. One locates on the piston pin bore in the piston, the other locates on the inner "hollow" in the piston pin itself. They can wear slightly and be "loose", but show no other signs/symptoms, and have no real affect on engine performance/engine life. They also can in service begin to rub excessively on the cylinder wall, with no other apparent faults. They can have the radiused end that butt into the cylinder wall worn flat, and still not be "loose" in either the piston or pin bore. Piston pin metal is relatively easily identified in this case by hairs in the suction screen or oil filter element. TC |
Maybe there's something funny going on in the connecting rod small end
bushing - like maybe the bushing is also floating in the con rod bore? The presence of (hard?) iron in the analysis is bothersome. |
On May 24, 4:03 am, wrote:
On 23 May 2007 08:09:20 -0700, "Robert M. Gary" wrote: Please bear in mind that one of the two piston pin plugs on each piston pin is going to be in contact with the cylinder wall during normal operations. The lab analysis is relative. They show my AL vs. other IO-360's and mine has been 2-10 times higher than all others for the last 3 years. Again, the piston pin plug is a relatively soft alloy, it may transfer to the cylinder wall like a crayon, but it is not going to disturb the material of the cylinder wall. That's why I ignored the issue for the first 3 year. Now that we're making harder metals the thinking is that pin plug is gone and harder metals are rubbing. -Robert |
On May 24, 3:38 pm, "Robert M. Gary" wrote:
On May 24, 4:03 am, wrote: On 23 May 2007 08:09:20 -0700, "Robert M. Gary" wrote: Please bear in mind that one of the two piston pin plugs on each piston pin is going to be in contact with the cylinder wall during normal operations. The lab analysis is relative. They show my AL vs. other IO-360's and mine has been 2-10 times higher than all others for the last 3 years. Again, the piston pin plug is a relatively soft alloy, it may transfer to the cylinder wall like a crayon, but it is not going to disturb the material of the cylinder wall. The pins wear when the rings leave a ridge in the cylinder wall at the bottom of their travel. In engines that do not have rings beneath the pison pin as well as above it, the pin plugs ride over the ridge and get shaved, creating those aluminum hairs you see in the filter. If an engine has rings below the pin, the ridge will be below the pin plug's travel and it won't get shaved. The ridge will form much quicker on engines that run too cold or get flown too little. The blowby gases contain water vapour, which condenses in the case and can also form on cooler parts of the cylinder walls, such as those exposed to the incoming cooling air. Corrosion forms wherever moisture collects, and a corroded cylinder wall will wear at an astonishing rate and will form a ridge more quickly. So now we have aluminum AND iron in the oil analysis. We've had this trouble with an O-235 that just runs way too cold, even in summer. The oil temp seldom gets far of the peg, and in the winter it won't warm up much at all, even with the cooler blocked off. I was able to isolate the bad cylinder with a sharpened piece of welding rod, feeling the cylinder walls and finding the roughness, but ended up taking them all off anyway. The danger with an ignored failing pin plug is that it can end up rattling around in there and jamming things, or leave altogether and rip up the piston or let the pin end take the cylinder wall apart. Bronze pins are available for some engines. They're more resistant to the shaving, but the engine still has to come apart and the cylinders fixed up. It's false economy to let it go. Dan |
On May 23, 8:09 am, "Robert M. Gary" wrote:
I have a mid time (1000 SFNEW) IO-360 Lycoming engine. Recently oil consumption has increased from about 1 quart/10 hours to about 1 quart/ 5 hours. For a long time we've collected oil on the bottom #1 plug but it seems like its worse now. Robert, Oil is cheap compared to finding the problem, however if I was wearing your sneakers......... I'd say you have a broken oil control ring on that cylinder. It will still show good compression, but just burns more oil. I would pull that jug and inspect it. option 1 $: put a new oil control ring and go fly option 2 $$: hone it and re-ring the piston, If the piston is messed up from the broken ring, replace it as well. option 3 $$$$: bebuild that jug. In regards to the piston plug idea. all you know is that you have had some alumimun in your oil, and now some iron, and a lab "thinks" it might be a piston plug. however It might be an oil control ring eating it's ring grove. It might be a small bur in your oil pump eating the oil pump housing. it might be one of many things. |
cylinder replacement | [email protected] | Owning | 12 | February 16th 06 09:03 PM |
O2 cylinder | HL Falbaum | Soaring | 26 | February 9th 06 05:35 PM |
bad cylinder | blanche cohen | Owning | 25 | February 2nd 06 05:15 PM |
Bad cylinder | Denny | Owning | 17 | September 12th 05 06:04 PM |
WTB: A65-8 Cylinder | Juan Jimenez | Aviation Marketplace | 0 | June 10th 05 04:38 AM |
