Do you have a test unit to check for error codes, some units use a LED test
lamp you can make yourself or get a tech to make for a six-pack. I'm from down under so we have holdens instead but most manuals give you the details. That gives you something to start with. Check all the connectors for corrosion as they can give problems. A lot of car ones are changed with no real fault. Do you have any spares to try against, or is one available from a wreckers? Is the spark timing controlled by the same unit or is it correct? One of my cars, a 1989 XF Ford Falcon had a failure on a level crossing one wet rainy night when water flooded the vent and wet the spark control box on the passenger foot wall. Removing the circuit board and flooding with a can of cheap brand water dispersing spray and draining before putting it back together and driving it home. Testing the unit was done with a paperclip shorting the connector for distributor setting allowing the spark to bypass the flooded box. A good switch to mount on your dash may be a test mode for the distributor to give you raw spark with no advance, and another to turn on the fuel pump feeding the extra nozzle in the inlet manifold giving you enough fuel for 80% power to get you home when your ecu dies. You could set this up on your test bench to help isolate your problem. Hope this helps, Peter |
Hi Barry
I'm not an expert on ECU's, but have had to find ways to get them to behave when running engines on a dyno without many of the bits that are fitted in the vehicle. If you definitely have no O2 sensors, you would need to rig the inputs (the second sensor) to indicate a Lambda 1 condition, since otherwise the ECU may continuously cycle the mixture to try to find the right operating point. I'm not sure it would be possible to achieve success without at least 1 sensor (closest to the manifold) since this sensor drives the basic mixture setting and the second the fine tuning The next problem is that once it finds a "failure", it may switch into a "basic strategy" mode, which may reduce the performance significantly. If this is the case you may need to have a dealer reset the ECU, then fix all the signal level issues before powering it up again. The best way to avoid these issues is to look at the signal levels of all the inputs in the car under normal driving conditions (engine hot, transmission in drive etc), then simulate these signal conditions at all the inputs that are not used in your application. You should also check if you are getting plausible signals from the accessories which you are using (massflowmeter, crankshaft & camshaft sensors at the very least) Be aware that full throttle will always result in a rich mixture. If you back off just slightly from full throttle the mixture will be leaner without a significant power reduction. Best of luck Keith "Barry Palmer" schrieb im Newsbeitrag ... Anyone out there work with EFI engines. I have a 4.3L Chevy V-6 that was removed from a car with its ECU and when operated with a propeller load does not want to get above 1500rpm, (should go to 4200rpm) while it hunts up and down for the correct mixture ratio. The transmission is removed, if there are any sensors on it they are caput. I hate to just blame it on the O2 sensor. Anyone have any suggestions as to newsgroups in the hot rod area that work with the ECU's? Barry Palmer, for Sevtec (http://members.aol.com/sevtec/sev/skmr.html) |
Barry,
You are going to get some advise that will possibly get the computer controller working correctly, for the most part, on your engine. Let's see if I can point out some things that would make you go a different route. Regardless of the dependability of these computers on automobiles, and I am going to use a cliché, you can't pull over to the side of the road when the system quits. Hundreds and hundreds of Subarus have been installed and flown with the automotive electronic controls. The failure rate of these installations has been a part of the problem with the reduced availability of insurance for auto-conversions. THe first problem is figuring out the sensors and settings just as you are finding right now. The next problem is redundancy. As dependable as you may think this computer control is, they are susceptible to vibration and in a few cases RF transmissions. There needs to be full redundancy with a complete second computer that can be switched into operation if a failure occurs on the primary system. One of the advantages of an automotive engine conversion has been simplicity; something that can be repaired in the boonies. Mechanical fuel injection can meet that requirement but is usually a high maintenance setup. Carbs have been the choice because they have a century's worth of refinement and by electronic fuel injection standards are dirt simple. There are few places in the world where you cannot get parts for a Holley. If your EFI is a throttle body type you will find that bolting on a mechanically operated unit like the Ellison "throttle body" retains the performance and simplifies operation. If your EFI is a direct injection setup you can find an aftermarket controller available from race car catalogs that is easier to back up with a second unit for redundancy. If you retain the OEM automotive computer, the minimum safe set up would be to obtain a second unit from a salvage yard and install it to allow easy switching when the primary unit fails. Salvage yard prices for the engine control computers is is usually in the range of $200 versus $2000 from the dealer. Backup should include a stand by coil and other parts of the ignition system depending on how inclusive are the components on the control computer. Barry Palmer wrote: Anyone out there work with EFI engines. I have a 4.3L Chevy V-6 that was removed from a car with its ECU and when operated with a propeller load does not want to get above 1500rpm, (should go to 4200rpm) while it hunts up and down for the correct mixture ratio. The transmission is removed, if there are any sensors on it they are caput. I hate to just blame it on the O2 sensor. Anyone have any suggestions as to newsgroups in the hot rod area that work with the ECU's? Barry Palmer, for Sevtec (http://members.aol.com/sevtec/sev/skmr.html) -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| *------------------------------**----* \(-o-)/ AIRCRAFT PROJECTS CO. \___/ Manufacturing parts & pieces / \ for homebuilt aircraft, 0 0 TIG welding |
I am doing this for another person remotely. It turns out that he never
installed an O2 sensor to start with. I think the engine may be too old for transmission inputs, but this is an avenue we will have to investigate. Thank you all, but there may be a round 2 after the O2 sensor gets installed, and transmission input possibility gets explored. Those race car-hot rod setups can be pricey, so I am trying to avoid that, along with redundance, since this is a surface vehicle without the high dollar costs of an aircraft. (although it can and they do get into areas well away from civilization where a breakdown will be very embarrasing and inconvenient.) Subject: Chevy 4.3 L V-6 and Misbehaving Engine Control Unit From: "Keith Olivier" Date: Sun, Aug 17, 2003 1:57 PM Message-id: Barry, are you running on leaded gas ? If so, why ? Modern engines are profoundly sensitive to stuck valves with leaded fuel. I don't think you will get the ECU to work without at least 1 oxygen sensor. Where you mount it is not important as long as you are absolutely sure that the exhaust system is absolutely gas tight until at least 200mm downstream of the sensor. If you have leaks, it will add O2 and force the mixture richer (same reason why manifolds and catalysts have to be gas tight). There are strong pulsations in the first part of the exhaust system, so there are standing waves which cane reach pressures below atmosphere in certain positions which change with the RPM. This is what causes air to be sucked in to the exhaust. If you need to simulate particular voltage levels, the best way is to use a resistor or one of the 3 legged regulators to the positive supply. It will generally live forever and not be forgotten about like a battery. Best bet would be to build a "black box" which produces outputs for all the inputs which you require. You have pots to set up all the individual voltages (and keep a nice log of what you did for each and why...) and when youre done you seal it up and forget it. I suspect that the ECU definitely needs some sort of input from the transmission if is was an automatic (very likely in the US), since there are shift modes (upshifts, downshifts etc) programmed with co-ordinated throttle actuation. It needs to think that you are in top gear and the switch at full throttle deflection (which triggers downshift) needs to be open/closed deending on how it is supposed to be set up. An ECU from a manual transmission model would be much simpler to impliment. Regards Keith "Barry Palmer" schrieb im Newsbeitrag ... The setup has an O2 sensor, and I suspect it is polluted. I do not have the error codes but can look them up after reading them. I suspect the 02 sensor. Has anyone noted the sensitivity of the 02 sensor when mounting it in the exhaust pipe away from the engine as opposed to near or on the exhaust manifold? Also, I suspect the signal voltage is very low, perhaps 1-2 volts. Has anyone tried to fake the ECU out with a alkaline, ni-cad or nickel metal hydride battery cell applied to the 02 sensor wires? The engine is on a sev, or hovercraft, pushing two belt driven 2 blade Power Fin propellers and a pair of 30 inch 12 bladed fans, all at once, and the load characteristic is rpm^3 = power, much different from an auto. Subject: Chevy 4.3 L V-6 and Misbehaving Engine Control Unit From: "Keith Olivier" Date: Sun, Aug 17, 2003 3:46 AM Message-id: Hi Barry I'm not an expert on ECU's, but have had to find ways to get them to behave when running engines on a dyno without many of the bits that are fitted in the vehicle. If you definitely have no O2 sensors, you would need to rig the inputs (the second sensor) to indicate a Lambda 1 condition, since otherwise the ECU may continuously cycle the mixture to try to find the right operating point. I'm not sure it would be possible to achieve success without at least 1 sensor (closest to the manifold) since this sensor drives the basic mixture setting and the second the fine tuning The next problem is that once it finds a "failure", it may switch into a "basic strategy" mode, which may reduce the performance significantly. If this is the case you may need to have a dealer reset the ECU, then fix all the signal level issues before powering it up again. The best way to avoid these issues is to look at the signal levels of all the inputs in the car under normal driving conditions (engine hot, transmission in drive etc), then simulate these signal conditions at all the inputs that are not used in your application. You should also check if you are getting plausible signals from the accessories which you are using (massflowmeter, crankshaft & camshaft sensors at the very least) Be aware that full throttle will always result in a rich mixture. If you back off just slightly from full throttle the mixture will be leaner without a significant power reduction. Best of luck Keith "Barry Palmer" schrieb im Newsbeitrag ... Anyone out there work with EFI engines. I have a 4.3L Chevy V-6 that was removed from a car with its ECU and when operated with a propeller load does not want to get above 1500rpm, (should go to 4200rpm) while it hunts up and down for the correct mixture ratio. The transmission is removed, if there are any sensors on it they are caput. I hate to just blame it on the O2 sensor. Anyone have any suggestions as to newsgroups in the hot rod area that work with the ECU's? Barry Palmer, for Sevtec (http://members.aol.com/sevtec/sev/skmr.html) Barry Palmer, for A HREF="http://members.aol.com/sevtec/sev/skmr.html"Sevtec BRBR Barry Palmer, for A HREF="http://members.aol.com/sevtec/sev/skmr.html"Sevtec/A |
