F-14 squadrons removing refueling cover plate?
Old August 4th 03, 07:36 AM
dave999
Default F-14 squadrons removing refueling cover plate?
Why are the F-14 squadrons currently removing the plate covering the
refueling probe?
I'm assuming they're ripping off in the slipstream or something, but
wouldn't it make more sense, since they're employed by the Federal
Gov't., to have some type of really expensive beefing-up kit to bolt
them on stronger?
send replies to
GOT JETS?
http://www.rfsm.net/
Dave Stein - President
Red Flag Scale Modelers
Las Vegas, Nevada
YOU NEED A HOBBY!
GET SOME!
http://www.cheapesthobbies.com/
Old August 4th 03, 01:00 PM
John Carrier
Government employment has nothing to do with it. Parts availability does. If the panel in question isn't in the supply system, it doesn't get replaced. Considering the F-14 is to be retired soon, the Navy isn't investing much money in that aircraft's logistics effort.
R / John
"dave999" wrote in message news:w9nXa.1229$2g.1164@fed1read05...
Why are the F-14 squadrons currently removing the plate covering the refueling probe?
I'm assuming they're ripping off in the slipstream or something, but wouldn't it make more sense, since they're employed by the Federal Gov't., to have some type of really expensive beefing-up kit to bolt them on stronger?
send replies to
GOT JETS?
Las Vegas, Nevada
YOU NEED A HOBBY!
GET SOME!
Old August 4th 03, 02:39 PM
Drewe Manton
The cover plates are removed generally when the aircraft is going to be
refuelling from air force tankers on a regular basis. The short adaptor
hose which trails from the boom when the likes of KC-135's are modified to
refuel probe equipped aircraft causes the basket to whip around a lot and
was a frequent cause of Tomcats losing the cover on engaging or
disengaging. Easiest solution was to remove the cover. The problem doesn't
present itself with buddy refuelling from S-3s or cross force ops with RAF
VC-10s or Tristars because the longer hose makes the basket more stable.
Regards
Drewe
Artificial intelligence is no match for natural stupidity
Old August 4th 03, 03:09 PM
John Carrier
Interesting. Didn't know that. I never did a 135 from the F-14, although
I've had the pleasure a number of times in the F-4. The short
non-retractable hose made the effort a bit more challenging.
R / John
"Drewe Manton" wrote in message
. 4...
Regards
Drewe
Old August 4th 03, 09:30 PM
Errol Cavit
Drewe Manton wrote in message .4...
Likewise with other dedicated hose tankers like the RAAF 707s, I assume?
Cheers
Errol Cavit
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
FS: 1984 "The Nonsuch" (Sailing Vessel) Lim Ed Collector Plate in Ontario J.R. Sinclair Aviation Marketplace 0 February 15th 04 05:57 AM
