http://www.gorillaglue.com/theglue/
Any opinions? Is a two-part epoxy like T-88 inherently superior to a one-part catalyzed polyurethane? Why? |
One thing is the level of craftsmanship required.
Polyurethane glues need exceptionally tight joints to develop any strength. Where there is any air space the glue will "foam" up. The foam has very little strength... T-88 is more of a gap filling glue, and much more consistant. Richard Corrie wrote: http://www.gorillaglue.com/theglue/ Any opinions? Is a two-part epoxy like T-88 inherently superior to a one-part catalyzed polyurethane? Why? |
On Mon, 18 Aug 2003 16:36:46 GMT, Richard Lamb
wrote: One thing is the level of craftsmanship required. Polyurethane glues need exceptionally tight joints to develop any strength. Where there is any air space the glue will "foam" up. The foam has very little strength... T-88 is more of a gap filling glue, and much more consistant. Richard Not only that T-88 cures slowly. It's best for gluing wood. You lay some on a scarf joint and it will migrate into the wood over a period of hours before it cures. This gives you a real strong bond once it cures. Experiment with it. I've made but joints with it using spruce and Canadian white pine, let them cure for two days, and tested them. I've put them in a vise and smashed them with a hammer, the wood almost always fails somewhere other than the glue joint. In other words, the T-88 joint is stronger than the surrounding wood. Of course that's a problem in some cases because the added strength of the glue joint actually concentrates the stresses at that strong point. Most people don't understand that but here's a simple example: Take a yard stick and clamp one end of it to a table. Put a 50 pound weight on the other end and watch what happenes. The whole yard stick will bend like a willow and support that load. Now go out to about 30 inches on the yard stick and put a support at that point near where you are going to place the load. Put the load on it and the stick will snap at the support point. What you did was concentrate all the stress at the point where you beefed it up. You need the whole stick to take the load, not just one tiny little point. The problem wood builders have is that many of them don't follow the plans and they beef up a certain area using T-88. All they do is concentrate the stresses at those strong points and can actually cause a failure because of it. Same thing with T-88 itself. The stuff is so good, the scarf joint won't be the point of failure but the loads will concentrate there and cause the wood just outside the scarf joint to fail. Be careful. Follow the plans. I saw a guy add extra drag braces to his Minimax wings once. Later on they caused him problems because of this. The wings didn't flex enough to take the turbulence loads. They were too rigid. He had to cut them out and destroy a perfect fabric job to do it. Badwater Bill |
Does T-88 cure to a flexible state or a brittle state?
How much flexing can it take when cured? I know it is poor craftsmanship to glue different materials together, but how well would it handle gluing two layers of different material together, with the materials having different rates of expansion. For example, plastic glued to aluminum, two different thicknesses of aluminum glued together, fiberboard and spruce, etc. Thanks for any info. |
Gyro,
I have read about aluminum bonding as told by I believe jack lambe (spelling?) and the consensus is that unless you are able to etch, prime and then bond with a high quality control then bonding aluminum to aluminum is not recomended. The cause for failure of the bond is that the bond line is to the aluminum oxide that forms rather quickly on the surface of the aluminum and not the base metal. therefore a weak bond and one that most likely will fail. As to wood to aluminum I have not a clue, I have seen aluminum plates bonded to wood as a bearing plate and as such would really not be adversely effected by a failure of the bond line as the bolt would hold in place at any rate. Fiberboard I can reasonable say will fail before t-88. as to the flexibility the flexural modulus of t-88 is 375,000 and that would compare with nylon at 380,000 or abs plastic at 405,000, stiff but not really brittle. all the best Sean "dusting off the sawdust" Trost "gyrobob" wrote in message om... Does T-88 cure to a flexible state or a brittle state? How much flexing can it take when cured? I know it is poor craftsmanship to glue different materials together, but how well would it handle gluing two layers of different material together, with the materials having different rates of expansion. For example, plastic glued to aluminum, two different thicknesses of aluminum glued together, fiberboard and spruce, etc. Thanks for any info. |
This is some good stuff - the aluminum will fail before the joint...
http://www.hernonmfg.com/categories/charts/react.htm http://www.hernonmfg.com/tds/td-761.pdf -- Dan D. .. "seantrost" wrote in message m... Gyro, I have read about aluminum bonding as told by I believe jack lambe (spelling?) and the consensus is that unless you are able to etch, prime and then bond with a high quality control then bonding aluminum to aluminum is not recomended. The cause for failure of the bond is that the bond line is to the aluminum oxide that forms rather quickly on the surface of the aluminum and not the base metal. therefore a weak bond and one that most likely will fail. As to wood to aluminum I have not a clue, I have seen aluminum plates bonded to wood as a bearing plate and as such would really not be adversely effected by a failure of the bond line as the bolt would hold in place at any rate. Fiberboard I can reasonable say will fail before t-88. as to the flexibility the flexural modulus of t-88 is 375,000 and that would compare with nylon at 380,000 or abs plastic at 405,000, stiff but not really brittle. all the best Sean "dusting off the sawdust" Trost "gyrobob" wrote in message om... Does T-88 cure to a flexible state or a brittle state? How much flexing can it take when cured? I know it is poor craftsmanship to glue different materials together, but how well would it handle gluing two layers of different material together, with the materials having different rates of expansion. For example, plastic glued to aluminum, two different thicknesses of aluminum glued together, fiberboard and spruce, etc. Thanks for any info. |
You could start here. http://www.thistothat.com/index.shtml
"Jimmy Galvin" wrote in message ...
You could start here. http://www.thistothat.com/index.shtml No offense, but I don't think I'm gonna use Elmer's yellow glue for my spar caps. |
| Glue | Adair | Home Built | 3 | July 18th 03 11:15 PM |
| Glue | David | Home Built | 1 | July 16th 03 06:51 PM |
