Diana-2 - master-piece or flop?
Old June 16th 07, 07:55 AM posted to rec.aviation.soaring
BlueCumulus[_2_]
Default Diana-2 - master-piece or flop?
I have read very good critics about Diana-2
but as well very bad news about it.
The good news are from the people who seem to have flown the first two
Prototypes. The bad rumors I heard about number-3 of Diana-2.
Obviously the main difference is, that the wing position was shifted some
centimeters to the front. The glider appeared in Australia last November,
flew with experimental permit, but never got the airworthiness approval from
the Australian Airworthiness Authorities.
The gossip mentions problems like:
- airbrake movements being asynchronous
- flap handle unlocking in flight and shifting to full positive
- too high flap handling forces (more than JAR22 limits)
- weak aileron control at take off until tail wheel is off the ground
- glider is stalling while thermaling over inner wing at speeds CLmax with
- aileron control not good enough to keep bank when circling 30deg
- glider was in general instable to fly in yaw and pitch
Did anyone fly serial planes of Diana-2 with manufacturing numbers 3?
Old June 16th 07, 02:24 PM posted to rec.aviation.soaring
I'm curious. How can flaps self-deploy to full positive given in-
flight airflow? Are they somehow balanced?
This one seems to contradict the first one. If it takes a lot of force
to deploy the flaps, how can they self-deploy to full positive?
Old June 16th 07, 10:44 PM posted to rec.aviation.soaring
BlueCumulus[_2_]
it is not contradictory
- it needs much force to push the flaps to negative position
- when you fly fast through a thermal or turbulence the handle unhooked
and comes fully back into positive position, unless you hold it
permanently
in your hand.
- a former world champion who flew the glider said: The plane unfortunately
can not be flown to its full performance, because as long as it behaves so
badly.
many modern gliders even accept the flaps to be in intermediate positions
without being in a locked position and the flaps will not move.
Old June 17th 07, 12:06 AM posted to rec.aviation.soaring
GK[_1_]
permanently
in your hand.
badly.
- Strangely enough Mr.Johnosn did not publish these "revelations".
Old June 17th 07, 05:22 AM posted to rec.aviation.soaring
Yeah, I'm curious too. I have an old Speed Astir, and had some trouble
with the flap lock becoming disengaged. It usually happened turning
base to final, and went from full positive to full negative in blink
of an eye. There is considerable force at all airspeeds and conditions
(except a negative "G" push) exerted on the flap control toward the
negative flap setting.
Old June 18th 07, 12:36 AM posted to rec.aviation.soaring
BlueCumulus[_2_]
Maciek wrote: If one of your ailerons pins out, or your flaps aren't
locked at their position - they will all deploy up. It is impossible that
the flaps are balanced that much ....
I do not agree with that.
It depends on the aerodynamic and kinematics design of the flap system.
The ASW27 does not show any tendency to change flap settings between
+2 and -1 which covers a speed range of 80-180km/h. The same I was
told to be the case for the ASW26. You can have the flaps in any inter-
mediate position and it will stay there. you can move the flaps to any
setting with two fingers (except -2 and Landing position).
As said before the prototypes of the Diana-2 have the wing position about
5cm (2") more tailward than this first "Serial Machine". Why the wing-
position was moved forward is not clear but confirmed. After such a
significant change I would rather call it a prototype as well. The handbook
as well did not show the new drawings and figures for the CG calculations.
The glider was month too late in production and delivered in a hurry after
just one test flight. This Diana-2 with production number 3 seems to be a
different plane in regards of flying behavior than the prototypes.
That's why I was wondering if anyone might have flown number 4.
__________________________________________________ ______
"Maciek" wrote in message
finally someone imaginative... There is a pressure difference betweene the
upper and the bottom surface of the wing, thanks to whitch our gliders can
fly (if there is enyone who doesn't know that...). If one of your ailerons
pins out, or your flaps aren't locked at their position - they will all
deploy up. It is impossible that the flaps are balanced that much, to
overcome the pressure difference and deploy to positive - especially in a
glider weighting 185 kg.
Mat
Old June 18th 07, 01:48 AM posted to rec.aviation.soaring
Tuno
snip they will all deploy up /snip
My Ventus 2C won't do that. The flap system is integrated with the
horizontal stab trim; when weight and balance are correct and trim is
set, the flap handle, when not locked, will gently try to go to the
position most appropriate for the current speed.
2NO
Old June 18th 07, 02:22 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Same for the ASW-20.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old June 17th 07, 01:06 AM posted to rec.aviation.soaring
Paul Hanson
'revelations'.
I am not taking any sides in the Dianna 2 debate, as
it seems like a hot ship, with a not too shabby track
record to back that up and I do not have rounded enough
info to pass judgment on it. I do want to point out
however, that this thread is about s/n 3 or higher;
Johnson tested s/n 2, the personal Dianna 2 of the
US dealer. I am curious to hear more, both good or
bad (hopefully good though). One can never be too cautious
about believing hype on any product, especially sailplanes,
but I do want to point out that the Poles have a very
good track record when it comes to their ship's performances
and their claims about them. In general they tend to
be very objective, scientific, and accurately stated,
as confirmed by many other Johnson (and other's) tests,
including s/n 2 Dianna II. But lets not stifle further
discussion on the subject.
Paul Hanson
"Do the usual, unusually well"--Len Niemi
master warning Kevin Simulators 1 July 27th 06 08:28 PM
unported flop tube jasonlee Aerobatics 1 June 1st 06 04:23 PM
Master Buss Bar? ccwillwerth Home Built 18 January 20th 06 03:32 AM
Master Switch Lakeview Bill Piloting 23 July 20th 05 02:46 AM
Master Jet Base MICHAEL OLEARY Naval Aviation 24 April 22nd 05 08:00 AM
