Changing LC2 Battery
Old June 17th 07, 11:30 PM posted to rec.aviation.owning
Steve - KDMW
Default Changing LC2 Battery
I need to change the battery in my Astrotech LC2 clock. I've never
done this before and I can't find anything about it on line. Do I have
to pull the whole darn thing out to change the battery?
Steve
PA28-151
KDMW
Old June 18th 07, 01:06 AM posted to rec.aviation.owning
Ron Natalie
I believe so. If yo have the back light, you pull that off the back.
Remove the screws and pop the thing out. There is one screw on the back
that opens the case and you can replace the AAA battery within.
One of the annoying features of this thing is that as the battery
starts to go, it runs almost 1/2 real time.
Old June 18th 07, 01:29 AM posted to rec.aviation.owning
Jim Burns
If you're under 200 lbs, part monkey, and not the least bit claustrophobic,
you can do it from behind the panel. There is a square cover with one screw
to remove, this exposes the AAA battery. We've got the same clock in our
Aztec, changing the battery isn't my favorite behind the panel job.
"Steve - KDMW" wrote in message
Steve
PA28-151
KDMW
Changing Logbooks Steve Foley Piloting 21 April 12th 07 03:04 PM
Changing Of The Guard Grantland Military Aviation 3 March 14th 04 05:36 PM
Changing from VFR to IFR hawk_spring Simulators 6 October 18th 03 09:41 PM
Changing Magnetos? smf Home Built 2 September 1st 03 01:48 AM
changing names Idrmitch2 Simulators 0 August 8th 03 03:26 AM
