I thought I had this compressor power thing down to a pretty good science
until they started screwing around with "rated watts" and "peak power" and all that crap that makes their compressor look really good until you go to use it. Back when we were using "real" horsepower I used a figure of 750 (to make it easy to calculate, I believe 746 is the actual number) watts per horsepower and an efficiency factor of 85% so that a one horse motor would take 860 watts to do the actual work. But then you multiplied that times two for "starting" wattage for a couple of seconds to give 1725 watts under start and then times three for starting under some volume of air left in the compressor reservoir or about 2600 watts. That presses my 2200 watt continuous duty (2800 watts peak) fairly close to the load limit, but certainly gives a margin for error that seems reasonable. Before I tell elebendy bazillion Kitplanes readers that the Harbor Freight Subaru 2200 watt generator will drive the Sears 1 horse compressor (and even worse, buy the Sears compressor only to not have it work), will somebody please do a reality check on me for horsepower/watts for this lashup. (Note ... convert watts to amperes by dividing watts by 120 volts). 860w=7a 1725w=14a 2600w=21a Sears and Harbor Freight are damned near clueless about this sort of stuff. If anybody has a source I can reference for running/starting/starting under load for air compressors it would be well received. I'd LIKE to buy a 3/4 horse compressor but they go from the kiddie's 1/4 horse toy straight to one horse with darned little in between. Jim -- "Dream as if you'll live forever. Live as if you'll die today." --James Dean |
On Jun 18, 2:49 pm, "RST Engineering" wrote:
I thought I had this compressor power thing down to a pretty good science until they started screwing around with "rated watts" and "peak power" and all that crap that makes their compressor look really good until you go to use it. Back when we were using "real" horsepower I used a figure of 750 (to make it easy to calculate, I believe 746 is the actual number) watts per horsepower and an efficiency factor of 85% so that a one horse motor would take 860 watts to do the actual work. But then you multiplied that times two for "starting" wattage for a couple of seconds to give 1725 watts under start and then times three for starting under some volume of air left in the compressor reservoir or about 2600 watts. That presses my 2200 watt continuous duty (2800 watts peak) fairly close to the load limit, but certainly gives a margin for error that seems reasonable. Before I tell elebendy bazillion Kitplanes readers that the Harbor Freight Subaru 2200 watt generator will drive the Sears 1 horse compressor (and even worse, buy the Sears compressor only to not have it work), will somebody please do a reality check on me for horsepower/watts for this lashup. (Note ... convert watts to amperes by dividing watts by 120 volts). 860w=7a 1725w=14a 2600w=21a Sears and Harbor Freight are damned near clueless about this sort of stuff. If anybody has a source I can reference for running/starting/starting under load for air compressors it would be well received. I'd LIKE to buy a 3/4 horse compressor but they go from the kiddie's 1/4 horse toy straight to one horse with darned little in between. Jim -- "Dream as if you'll live forever. Live as if you'll die today." --James Dean Have you ever noticed that in the horsepower place on the motor dataplate it says something like "SPL"? The motor mfg doesn't want to be complicit on the out right lying done by the compressor mfgs, who never heard that 750 watts = 1 hp. Charletons. BH |
On Mon, 18 Jun 2007 14:53:30 -0700, "
wrote: Have you ever noticed that in the horsepower place on the motor dataplate it says something like "SPL"? The motor mfg doesn't want to be complicit on the out right lying done by the compressor mfgs, who never heard that 750 watts = 1 hp. NOTHING beats Shop-Vac HP ratings. 6HP from a 15 amp 120v outlet! Awesome! G |
B A R R Y wrote:
On Mon, 18 Jun 2007 14:53:30 -0700, " wrote: Have you ever noticed that in the horsepower place on the motor dataplate it says something like "SPL"? The motor mfg doesn't want to be complicit on the out right lying done by the compressor mfgs, who never heard that 750 watts = 1 hp. NOTHING beats Shop-Vac HP ratings. 6HP from a 15 amp 120v outlet! Awesome! G Good golly, I hadn't noticed that before! 15 amps at 120 V is 1800 watts Roughly 746 (100% efficiency) watts per HP 750 x 6 = 4476 watts Less than 1/2 the claimed power! I wonder if I could take it back and exchange it for a REAL 6 hp vac??? |
"B A R R Y" wrote in message
news ![]() On Mon, 18 Jun 2007 14:53:30 -0700, " wrote: Have you ever noticed that in the horsepower place on the motor dataplate it says something like "SPL"? The motor mfg doesn't want to be complicit on the out right lying done by the compressor mfgs, who never heard that 750 watts = 1 hp. NOTHING beats Shop-Vac HP ratings. 6HP from a 15 amp 120v outlet! Awesome! G 240% efficiency is very impressive--for a single phase motor! The last time that I wandered through the tool department at Sears, I saw what appeared to be the same compressor that I used to own. Mine could manage about 2CFM at 40PSI, and claimed to be 2HP on the aforementioned 120V circuit--IIRC with a continued draw of about 10A. The new ones were claiming either 4 or 6 CFM, and I believe that the pressure may have been higher as well, on the same electrical power. So the problem is not new, but it is getting much worse. Peter (In the future, tools will be rated like sound systems.) |
Peter Dohm wrote:
(In the future, tools will be rated like sound systems.) Let's hope the tradition doesn't extend to airplane power plants. G |
B A R R Y wrote:
Let's hope the tradition doesn't extend to airplane power plants. G Oh don't worry, it will. |
B A R R Y wrote:
Peter Dohm wrote: (In the future, tools will be rated like sound systems.) Let's hope the tradition doesn't extend to airplane power plants. G Well, there was the 150 horse Franklin. And the 60 horse VW. |
On Mon, 18 Jun 2007 13:49:59 -0700, "RST Engineering"
wrote: and then times three for starting under some volume of air left in the compressor reservoir or ... That SHOULD not be an issue. A properly designed compressor will start "unloaded" so that only the motor inrush, assumed at 4-8 times running for an industrial motor, less for the capacitor start single phase units, is an issue. Before I tell elebendy bazillion Kitplanes readers that the Harbor Freight Subaru 2200 watt generator will drive the Sears 1 horse compressor (and even worse, buy the Sears compressor only to not have it work), will somebody please do a reality check on me for horsepower/watts for this lashup. (Note ... convert watts to amperes by dividing watts by 120 volts). 860w=7a 1725w=14a 2600w=21a Sears and Harbor Freight are damned near clueless about this sort of stuff. If anybody has a source I can reference for running/starting/starting under load for air compressors it would be well received. I'd LIKE to buy a 3/4 horse compressor but they go from the kiddie's 1/4 horse toy straight to one horse with darned little in between. Based on the units with bigger motors, the HP is a marketing game, not real. Industry assumes ... ASSUMES ... about 4 cfm (to 100 psi) per horsepower. Small units will be less efficient ...maybe 3 cfm. Large (50 hp+) units will be a little better, perhaps 4.4 or so. It is often missed that capacity is INLET air. From what I've read and seen, trying to do calculations, most CFM ratings are 30% to 100% unrealistic. Most horsepower ratings are 50% to 300% unrealistic. Look at it this way ... 2 HP is 1500 watts ... throw in single phase efficientcy of maybe 65%, you are at 2200 watts in for 2HP out ... about 20 amps on 120V. It would be my OPINION that the 2200 watt generator would start and run a 1HP motor with little trouble. There is a guy (a lawyer, darnit) who has done some research in this; I understand that he was involved in a complaint against the wild numbers used in advertising ... take alook at http://users.goldengate.net/~kbrady/motors.pdf for some interesting info. |
("GeorgeB" wrote)
There is a guy (a lawyer, darnit) who has done some research in this; I understand that he was involved in a complaint against the wild numbers used in advertising ... take alook at http://users.goldengate.net/~kbrady/motors.pdf for some interesting info. Very interesting. Good info. However, I must take exception with this observation: "Since most people find mathematics to be about as fascinating as watching a guy making a weiner dog out of balloons, I'll keep the calculations simple." I would like to go on record as being one person who loves watching balloons get made into wiener dogs. Paul-Mont |
| Air Compressor Horsepower/Wattage/Amperage | RST Engineering | Owning | 32 | June 30th 07 01:47 AM |
| more horsepower | T-Bone | Piloting | 11 | March 20th 06 11:56 PM |
| Lycoming Horsepower Calculation? | Mark Doble | Home Built | 1 | June 20th 05 11:46 PM |
| Thermals and Horsepower | Ken Kochanski (KK) | Soaring | 14 | January 9th 05 06:50 PM |
| Horsepower | Andre | Home Built | 3 | July 18th 03 11:50 AM |
