safty finish at the 2007Sp.Nat's?
Old June 19th 07, 06:50 PM posted to rec.aviation.soaring
Udo
Default safty finish at the 2007Sp.Nat's?
It seem that the safety finish was rejected based on the revised
score sheet. What are the details?
Regards
Udo
Old June 19th 07, 07:00 PM posted to rec.aviation.soaring
Regards
Udo
Several pilots lost speed points because they were below the 1000ft
AGL minimum at the edge of the safety finish cylinder. All flights
claiming a safety finish are currently under review. A new scoresheet
will be posted when available.
2c
Old June 19th 07, 07:16 PM posted to rec.aviation.soaring
Karl Striedieck
There is no requirement to be at 1000 feet at the edge of the five-mile
safety finish cylinder. The requirement is to have at least one fix inside
the cylinder that is at or greater than a 20:1 slope to the finish point at
the field. The pilot can then retreat to a safer landing point of his/her
choosing. The speed from the most favorable fix in the cylinder to the
finish line is a fixed 60 mph.
KS
Regards
Udo
2c
Old June 19th 07, 07:25 PM posted to rec.aviation.soaring
KS
Regards
Udo
2c
My mistake. Its the 20:1 requirement that is being revisited.
2c
Old June 19th 07, 07:48 PM posted to rec.aviation.soaring
Regards
Udo
Actually the glide slope is not 20:1 it is 26.4:1. (200 ft per mile)
What happened on Day 6 of the Sports Nationals was that the version of
Winscore used at the contest did not automatically support the safety
finish rule. The scorer had to perform some manual steps to generate
scores and during that process some altitudes were misinterpreted and
finishes were incorrectly given to 3 contestants on the preliminary
scoresheet.
The logs were then more carefully reevaluated by the scorer and also
by an updated version of Winscore. Both evaluations showed that 3
contestants, while within the 5 mile horizontal bounds of the safety
cylinder, were below the required glide slope. The times and
distances of the remaining contestants who received safety finishes
will be rescored after a clarification of the safety finish rules.
Guy Byars
Warm spot for IFR finish-up Dave Reinhart Instrument Flight Rules 9 September 17th 05 01:37 PM
Finish lines Thomas Knauff Soaring 72 May 24th 05 06:09 AM
Finish Gate Accident no. 3 [email protected] Soaring 11 April 6th 05 12:56 AM
Finish Gate Accident no. 2 [email protected] Soaring 50 April 2nd 05 06:58 AM
Finish Gate Accident no. 2 Justin Craig Soaring 2 March 26th 05 03:11 PM
