Helicopter gun at LONG range
Old August 12th 03, 05:56 AM
Gordon
Default Helicopter gun at LONG range
Can I ask why..? Just curious as to where this info is heading.
Such work has been done, in some cases, in front of me.
v/r
Gordon
====(A+C====
USN SAR Aircrew
"Got anything on your radar, SENSO?"
"Nothing but my forehead, sir."
Old August 12th 03, 04:25 PM
John Hairell
On Tue, 12 Aug 2003 00:20:34 -0400, "Charles Talleyrand"
Has anyone used a helicopter cannon at LONG standoff range. By long range I mean
a range where the gun must shoot significantly above the straight line to the target
rather like a howitzer.
To do something like that you'd have to angle the cannon up through
the blades.
My vision is a helicopter standing off for safety and firing at an area. I'm assuming
if an AH-64 unloaded it's magazine at me from 10 miles away I would experience
a hail of shells all around me that would chew up every soft target including
any anti-air batteries.
The current cannon doesn't have the range, and it would take a pretty
big cannon to fire 10 miles. And why use helicopter-borne cannon fire
when you can call in longer-ranged arty?
It would take some sensor to measure range accurately (laser rangefinder) and some
software to compute tragetories, but these things need not be heavy or very expensive.
Has anyone ever even experimented or studied such an idea?
There is a solution for this problem: it's called a "missile". ;-)
John Hairell )
Old August 12th 03, 05:07 PM
John Mullen
"John Hairell" wrote in message
range I mean
the target
the blades.
Not necessarily a problem I would have thought?
I'm assuming
experience
including
Wouldn't recoil be quite a major problem as well?
and some
very expensive.
Yep.
John
Old August 13th 03, 03:21 AM
Charles Talleyrand
"John Hairell" wrote in message ...
the blades.
I don't think the angle need exceed 45 degrees, and that should clear the
blades with ease. If not, please select a lower angle.
I don't know any numers, but recall that the helicopter is firing from above
the horizon and might have a forward velocity, both of which might help.
If ten miles is extreme, what would seem reasonable.
Remember that the gun can fire two miles without a substancial arc,
so the range with upward firing must be substancial.
Missiles often cost more than the target.
Also, simply having the option might help the attack even if this is
not the first option for every attack. Options almost always help.
Old August 13th 03, 03:59 AM
Bill Silvey
"Charles Talleyrand" wrote in message
This is a poor warfighting methodology that will only lead to tears. Yes,
yes. A single Hellfire costs more than a half-company of chinese T-55
knockoffs. So you do what then - don't shoot it? Wait for a different
asset to attack with a more economical munition and hope you - or people on
the ground - don't die waiting?
Nonsense. If it kills the target, it paid for itself. There's no point in
trying to play accountant as well as CP/G. Missile expensive? You bet!
But guess what? There's a plant in California that'll make *all of them you
want*. Heck, I can promise you a Hellfire costs more than most cars - yet a
Hellfire was used to destroy a car-full of al-Qeda terrorists a year or so
back. Should the UAV pilot have waved off and not killed 'em?
http://www.delversdungeon.dragonsfoot.org
Remove the X's in my email address to respond.
"Damn you Silvey, and your endless fortunes." - Stephen Weir
I hate furries.
Old August 13th 03, 09:28 AM
Keith Willshaw
"Bill Silvey" wrote in message
om...
on
Indeed comparing cash values like that is nonsense.
The real issue is that a maverick is a hell of a lot cheaper than
the airplane and pilot you need to hazard to put him in
gun range.
Keith
Old August 13th 03, 01:02 PM
Bill Silvey
"Keith Willshaw" wrote in message
om...
Yes, yes. A single Hellfire costs more than a half-company of
chinese T-55 knockoffs. So you do what then - don't shoot it? Wait
for a different asset to attack with a more economical munition and
hope you - or people on the ground - don't die waiting?
gun range.
Keith
Further example: I don't think the pentagon was counting pennies when they
first used LGBs in Vietnam to drop a bridge that had withstood conventional
bombardment for the better part of a decade...
I hate furries.
Old August 14th 03, 05:03 AM
Charles Talleyrand
"Bill Silvey" wrote in message om...
I believe this argument when taken to extremes will have negative result.
If every target deserves the most expensive munition then many targets
will have no munitions. And of course excessive cheapness taken to
extremes will also have negative results. Cannot we both agree that
somewhere in the middle is the correct answer?
want*.
Hm. I was under the impression that the Pentagon had a limited budget,
and could not in fact afford all the missiles it wanted.
Of course not. The correct comparision is not the cost of the missile
vs. the cost of the car. The correct comparision is the cost of the missile
vs the lives of the "car-full" of terrorists and the damage they would
likely do us.
Old August 13th 03, 03:16 AM
Charles Talleyrand
"Gordon" wrote in message ...
I've been reading about the A-10 and it seems most attack profiles
lead it to fly over (or near) the target. A more survivable approach
would be to stand off, but that reduces accuracy.
Eventually these thoughts lead to the idea of a stand-off attack.
Since the A-10 requires it's gun to follow the nose, I was considering
platforms that could aim the gun separately from the vehicle. This leads
one to a helicopter, or to an A-10 with a helicopter turret mounted on
the nose.
Which lead to my question....
I would love to hear about the work in front of you. I'm not asking
you to violate your oaths and offer military secrets, but instead just tell
me what you can tell me.
Does it work?
What are the main obsticles to overcome?
-Thanks
Old August 13th 03, 05:48 AM
Les Matheson
Perfect weapon system exists, the AC-130H or U. 40 and 105MM guns on target
for a long time.
Les
F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret)
the nose.
tell
Does it work?
-Thanks
Long range Wx Paul kgyy Instrument Flight Rules 4 December 31st 04 04:25 PM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
Musings of a Commercial Helicopter Pilot Badwater Bill Home Built 6 February 27th 04 09:11 AM
To Steal an F-86 Dudley Henriques Military Aviation 19 August 1st 03 02:26 AM
