Is there a product that will allow me to
share one antenna with 2 COM radios or a COM and a handheld? |
There are a couple of ways of doing it, none of them particularly
inexpensive or practical. If you are asking if there is a product on the market that will do it, I believe that the answer is no. Jim -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown "Jim Stewart" wrote in message .. . Is there a product that will allow me to share one antenna with 2 COM radios or a COM and a handheld? |
Jim Stewart wrote:
Is there a product that will allow me to share one antenna with 2 COM radios or a COM and a handheld? Nothing as cheap, simple and reliable as installing another antenna. |
A 'cheap' way to share an antenna with a hand-held when the official com
goes belly up is to cut the coax where it is easily accessible during flight (like under the instrument panel near your knees) and installing the appropriate coax couplers to rejoin the cable (something like a double female bnc coupler and a couple of male bnc connectors on the two coax ends). You can connect an adapter coax between the hand held and the antenna side of the split coax for using the handheld in an emergency. One down side to such an arrangement is that you obviously don't want to accidentally plug your handheld into the wrong side of the split coax and transmit into the expensive com radio. And wasn't it Jim at RST who wrote an article in one of the homebuilt magazines about a panel plug in for attaching a hand-held to the com antenna? -- Best Regards, Mike http://photoshow.comcast.net/mikenoel It is not work that kills men; it is worry. Worry is rust upon the blade. "Jim Stewart" wrote in message .. . Is there a product that will allow me to share one antenna with 2 COM radios or a COM and a handheld? |
It was indeed Jim in Kitplanes March 2002 (Good memory, Mike) that used a
cheap 3.5mm "transistor radio" set of jacks to automatically disconnect the com radio when you plugged in the portable radio. Jim -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown "Mike Noel" wrote in message ... A 'cheap' way to share an antenna with a hand-held when the official com goes belly up is to cut the coax where it is easily accessible during flight (like under the instrument panel near your knees) and installing the appropriate coax couplers to rejoin the cable (something like a double female bnc coupler and a couple of male bnc connectors on the two coax ends). You can connect an adapter coax between the hand held and the antenna side of the split coax for using the handheld in an emergency. One down side to such an arrangement is that you obviously don't want to accidentally plug your handheld into the wrong side of the split coax and transmit into the expensive com radio. And wasn't it Jim at RST who wrote an article in one of the homebuilt magazines about a panel plug in for attaching a hand-held to the com antenna? |
http://www.rst-engr.com/kitplanes/KP0203/KP0203.htm
"Mike Noel" wrote in message ... A 'cheap' way to share an antenna with a hand-held when the official com goes belly up is to cut the coax where it is easily accessible during flight (like under the instrument panel near your knees) and installing the appropriate coax couplers to rejoin the cable (something like a double female bnc coupler and a couple of male bnc connectors on the two coax ends). You can connect an adapter coax between the hand held and the antenna side of the split coax for using the handheld in an emergency. One down side to such an arrangement is that you obviously don't want to accidentally plug your handheld into the wrong side of the split coax and transmit into the expensive com radio. And wasn't it Jim at RST who wrote an article in one of the homebuilt magazines about a panel plug in for attaching a hand-held to the com antenna? -- Best Regards, Mike http://photoshow.comcast.net/mikenoel It is not work that kills men; it is worry. Worry is rust upon the blade. "Jim Stewart" wrote in message .. . Is there a product that will allow me to share one antenna with 2 COM radios or a COM and a handheld? |
Gus Cabre wrote:
http://www.rst-engr.com/kitplanes/KP0203/KP0203.htm Thanks but no thanks. I think I have a proper Dow-Key coax relay in one my junkboxes and if I decide to go forward, I'll use it. "Mike Noel" wrote in message ... A 'cheap' way to share an antenna with a hand-held when the official com goes belly up is to cut the coax where it is easily accessible during flight (like under the instrument panel near your knees) and installing the appropriate coax couplers to rejoin the cable (something like a double female bnc coupler and a couple of male bnc connectors on the two coax ends). You can connect an adapter coax between the hand held and the antenna side of the split coax for using the handheld in an emergency. One down side to such an arrangement is that you obviously don't want to accidentally plug your handheld into the wrong side of the split coax and transmit into the expensive com radio. And wasn't it Jim at RST who wrote an article in one of the homebuilt magazines about a panel plug in for attaching a hand-held to the com antenna? -- Best Regards, Mike http://photoshow.comcast.net/mikenoel It is not work that kills men; it is worry. Worry is rust upon the blade. "Jim Stewart" wrote in message .. . Is there a product that will allow me to share one antenna with 2 COM radios or a COM and a handheld? |
My avionics guy (unsolicited, it's just one of those things he does)
put a BNC male to female fitting in the com cable and routed it just under the control yoke. All you have to do is reach up, disconnect the antenna cable from the wire to the comm radio and plug in your handheld. The only thing would have been nice was if he had told me he did it. I found it while under the panel for other reasons. |
And you think that relay, with operation measured in hundreds of
milliseconds, is going to protect tens of watts from frying your fractions of microvolts front end measured in tens of microseconds? What a maroon. Jim -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown "Jim Stewart" wrote in message .. . Gus Cabre wrote: http://www.rst-engr.com/kitplanes/KP0203/KP0203.htm Thanks but no thanks. I think I have a proper Dow-Key coax relay in one my junkboxes and if I decide to go forward, I'll use it. |
RST Engineering wrote:
And you think that relay, with operation measured in hundreds of milliseconds, is going to protect tens of watts from frying your fractions of microvolts front end measured in tens of microseconds? I have both an FCC commercial and ham license and have a passing knowledge of RF. The relay would be controlled by a manual switch and would connect one radio to the antenna and the other to a dummy load. What a maroon. Great way to treat a customer. I didn't complain when you took 4 weeks to send me an intercom kit. Now you insult me on the internet. Time to call it quits. Jim |
signal splitter | Tri-Pacer | Home Built | 2 | November 5th 05 09:47 PM |
fs: icom radios | [email protected] | Piloting | 0 | May 11th 05 03:10 PM |
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 06:22 AM |
Commercial - New Data Splitter for 2-Seat Gliders | John Giddy | Soaring | 3 | September 17th 03 06:01 AM |
TKM radios | Peter Gottlieb | Piloting | 5 | August 15th 03 02:44 PM |
