Chandelle, speaking of tight turns
Old June 29th 07, 07:58 PM posted to rec.aviation.piloting
Default Chandelle, speaking of tight turns
I had thought a chandelle was really half a loop followed by a half
roll to get right side up, but most describe it as a climbing turn
(almost like a wing over?).
It was a long time ago, but I seem to remember being in an Aerobat and
started a loop by diving and getting to maybe 140 kts before the pilot
pulled back. The question nagging at me is, if in something like an
Arrrow or a Mooney, if you were in a cruise at 140 knots would you
have enough speed to pull back into a half loop to make a fast 180
degree change in turn in a tight space?
I suppose I could calculate if one maintained 2 gs worth of
backpressure what would happen (it would be a funny half loop, turn
radius would get tighter and tighter as speed decreases and gravity
started pulling at the tail instead of at the wheels, but real life
experience is better than calculations, if anyone has such experience.
Old June 29th 07, 08:19 PM posted to rec.aviation.piloting
Steven P. McNicoll
You're describing an Immelmann.
Old June 29th 07, 08:25 PM posted to rec.aviation.piloting
Thanks!
On Jun 29, 3:19 pm, "Steven P. McNicoll"
Old June 29th 07, 08:29 PM posted to rec.aviation.piloting
Watson[_2_]
What you describe is an Immeleman. Front half loop followed by half roll to
upright. The opposite (half roll to inverted, followed by back half of
loop) is a split S.
Chandelle (a commercial maneuver, in the CPL PTS) is a climbing 180 deg
turn. First 90 deg of turn, establish 30 deg AOB, and begin pitching,
Second 90 deg of turn is slowly rolling wings level and increasing pitch
such that the a/c goes into stall warning. Recovery is accelerate straight
ahead (180 from initial heading) without losing altitude gained in the
maneuver.
Watson
Old June 30th 07, 02:40 PM posted to rec.aviation.piloting
Peter Dohm
straight
maneuver.
Watson
This is exactly as the Chandele was explained to me, except that it is
usually entered following a shallow dive to reach the approved entry speed.
I don't recall the specification for the roll-in, except that it is quite
specific. It is a a demonstration of proficiency in energy management in a
particular aircraft type (as currently loaded) and will not produce an
ususually tight turn.
Old June 29th 07, 11:00 PM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
The Visitor wrote:
I thought of it as a maximum performance climbing turn.
And it is.
mschnerdatcarolina.rr.com
Old June 29th 07, 11:16 PM posted to rec.aviation.piloting
Kyle Boatright
snip
I don't fly a Mooney or Arrow, but the answer is probably yes, assuming
we're talking about indicated airspeed, as opposed to true airspeed. I fly
loops beginning at 140-150 knots IAS in my RV-6 (fixed pitch) fairly often.
They require a 3.5 G initial pull, tapering off as the airspeed declines.
With full power the loop results in an 800' altitude gain at the apex with
about 80 knots of airspeed over the top of the loop.
The Mooney or Arrow's constant speed props would have advantages over my
RV's fixed pitch setup, although the RV has a higher power to weight ratio.
Those two factors probably net out as a wash...
By the way, this is a purely hypothetical answer. Don't try to prove or
disprove it with the real hardware.
KB
Old June 30th 07, 01:20 AM posted to rec.aviation.piloting
Maxwell
Assuming 140 knots and full power, I think most 4 place singles could
complete an eliptical loop. Your right, maintaining back pressure and
tighting the radius around the top would be necessary, but it could save
your butt in a box canyon or downtown NY.
I have actually done it in a 150, 172 and 182, no problem. But don't try it
without a real emergency or the proper training and equipment. It can also
kill some gyros.
Old June 30th 07, 01:38 AM posted to rec.aviation.piloting
when you did it, did you wait until manovering speed before pulling
all the way back? I'd worry, in the Mooney, if the pilot in command
(he loves being called that) pulled back to the stops at cruise. If
you kept your wits about you, I'd guess firm back until I think 130
knots, then to the aft limit in that airplane, would probably only
break a gyro or two, and not the backbone of the airplane. I don't
know if its gyros are rated for more than 60 degrees back or pitch.
I think the numbers would work out that we'd be well above stall at
the top still pulling positive gees, then a roll to upright, with
altitude in the bank. Be fun to try it in a simulator, but my personal
PIC would not do it in the airplane unless there was building in front
of him.
F-15C in a tight turn Tom Callahan Aviation Photos 1 April 16th 07 06:58 PM
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Tight Screw Causes Sea King Crash Shiver Me Timbers Rotorcraft 0 August 30th 04 04:12 PM
Fly tight for tight bomb patterns on the ground. ArtKramr Military Aviation 120 August 30th 04 08:42 AM
Tight patterns? Bob Martin Piloting 51 January 26th 04 08:42 AM
