Hobbs
Old July 2nd 07, 07:53 PM posted to rec.aviation.piloting
Larry R[_2_]
Default Hobbs
Ok, I am *almost* embarrased to ask this question, but here goes. Do
Hobbs meters ever "go bad"? No, this isn't a joke!
I recently took a flight from KLOU-KWWD-KLOU. It was IFR and I wrote
down my off and land times, which coorespond with the FlightTracking
times within a couple of minutes.
The hobbs time was 10.7. The flight time was 9.6. Not whining here,
but it was a little hard to believe that I had over an hour of taxi/
start time on this!
Just wondering..
--Man would that be some kind of AD-- LOL!
Old July 2nd 07, 08:00 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Default Hobbs
Sure, it's a mechanical device.
On two occasions over the last few years, my Hobbs has failed to move.
For this reason, I always note my tach time and time off. The extra
start numbers will help just in case I don't notice for a while that the
Hobbs isn't running, and I need to have a fuel consumption figure.
Old July 2nd 07, 08:31 PM posted to rec.aviation.piloting
Orval Fairbairn
Default Hobbs
Sometimes, unscrupulous owners will wire the Hobbs to the master switch,
so you get charges whenever the MS is ON.
I have hated Hobbs ever since I discovered them 40+ years ago, since you
pay full rate for taxi and hold times.
An air switch is available, but hardly anybody uses them.
Old July 2nd 07, 09:35 PM posted to rec.aviation.piloting
Peter R.
Default Hobbs
Isn't that true for the Hobbs installed by the aircraft manufacturer in newer
aircraft? I was taught that all the newer model C172s' Hobbs are wired to the
master, which results in about a 20% greater difference between their
readings and the tach.
Peter
Old July 2nd 07, 09:42 PM posted to rec.aviation.piloting
Peter Clark
Default Hobbs
On Mon, 2 Jul 2007 16:35:20 -0400, "Peter R."
The new 172,182,206 are all activated by oil pressure not the master
switch.
Old July 2nd 07, 10:06 PM posted to rec.aviation.piloting
Peter R.
Default Hobbs
switch.
Ah, OK, then I was taught incorrectly. But then again, it has been at least
five years since I actually cared about a Hobbs meter.
Peter
Old July 2nd 07, 10:18 PM posted to rec.aviation.piloting
Larry Dighera
Default Hobbs
wrote in :
master,
Usually there's an oil pressure switch in series with the Hobbs meter,
so that it is only energized when the engine is running. I have no
idea if that is true of the newer aircraft, but it should be.
Old July 3rd 07, 11:50 AM posted to rec.aviation.piloting
Ron Natalie
Default Hobbs
Bonanza's don't even have recording tachs anymore. All they have is the
hobbs. My plane is similar, but it's on the gear so I don't pay for taxi.
Old July 3rd 07, 02:59 PM posted to rec.aviation.piloting
Peter R.
Default Hobbs
Interesting. So Hobbs time is what gets logged in the aircraft/engine
logbooks?
Peter
Old July 2nd 07, 10:21 PM posted to rec.aviation.piloting
El Maximo
Default Hobbs
"Orval Fairbairn" wrote in message
news
It's not unscrupulous if you know about it up front.
Unscrupulous is when you go to rent a U-haul truck for $19.99 a day, but
they consider a day to be the calender day(s) you use it. Pick it up at 8:30
Friday night, drop it off at 8:00 Saturday night, and that's 2 days. The
best one was when they said the would charge me a $50 cancellation fee. I
drove down, picked up the keys, and returned the truck thirty seconds later.
cost me $19.99 for the 'day'.
fwd: For Hobbs Jack Soaring 9 November 26th 06 05:28 AM
Hampton Inn Hobbs, NM Kilo Charlie Soaring 5 July 10th 04 02:03 AM
Hobbs Day 5 7-08 # 711. TomnKeyLargo Soaring 2 July 9th 04 04:14 AM
Hobbs Day 2 7-05-04 TomnKeyLargo Soaring 0 July 6th 04 05:24 AM
LS8-18 FS after Hobbs (USA) SAM AND LEIGH ZIMMERMAN Soaring 1 April 5th 04 12:43 PM
