Saw this posted to the Lycoming group, and it sounds like a pretty good idea. Anybody heard of it?
"A friend flying an IO-360 powered Glasair installed an oxygen sensor system that has an panel mounted indicator light to show when balanced combustion is reached. He simply adjusts mixture until the light comes on and knows he has complete combustion (his theory is that EGT is really just a good guess). He has had very good results from this system in terms of fuel economy and performance. I believe he purchased the system from Wag a few years ago. As I recall it was for experimentals only. They do not currently list such a system in their catalog. I have not found one at ACS&S or Chief either." |
![]() "Blueskies" wrote "A friend flying an IO-360 powered Glasair installed an oxygen sensor system that has an panel mounted indicator light to show when balanced combustion is reached. He simply adjusts mixture until the light comes on and knows he has complete combustion (his theory is that EGT is really just a good guess). He has had very good results from this system in terms of fuel economy and performance. How does it deal with the lead fouling issue? I had always thought that Oxy sensors were only used while the engine was at low power settings, and that once it was cranked up to full power, the engines ran in a closed loop system, ignoring the Oxy sensor. I would think a mass airflow sensor, and a programmed controller to set the mixture to the ideal settings would be more useful. I would be interested in seeing how much the mixture was changed, with the advice of the Oxy sensor setup. I have to admit that it does sound interesting. -- Jim in NC |
("Morgans" wrote)
I had always thought that Oxy sensors were only used while the engine was at low power settings, and that once it was cranked up to full power, the engines ran in a closed loop system, ignoring the Oxy sensor. My reading of his post suggests it's a "monitor only" O2 sensor. With the data from the O2 sensor, the pilot then controls the mixture manually. Montblack |
![]() "Montblack" wrote My reading of his post suggests it's a "monitor only" O2 sensor. With the data from the O2 sensor, the pilot then controls the mixture manually. I understood that to be the case also. My point is that in auto systems, the oxy sensor information must not be very valuable, since the computer ignores it at high power, which is where this system is attempting to function. Would the sensor/monitor have very much positive benefit, is my question. -- Jim in NC |
You have it backwards. When the car first starts it is in open loop ignoring
the O2 sensor. Once in closed loop the O2 sensor is used to control mixture and prevent pollution. Bad O2 sensor will burn out the Catalytic converter because of too much fuel in exhaust. "Morgans" wrote in message ... "Montblack" wrote My reading of his post suggests it's a "monitor only" O2 sensor. With the data from the O2 sensor, the pilot then controls the mixture manually. I understood that to be the case also. My point is that in auto systems, the oxy sensor information must not be very valuable, since the computer ignores it at high power, which is where this system is attempting to function. Would the sensor/monitor have very much positive benefit, is my question. -- Jim in NC |
... "Blueskies" wrote "A friend flying an IO-360 powered Glasair installed an oxygen sensor system that has an panel mounted indicator light to show when balanced combustion is reached. He simply adjusts mixture until the light comes on and knows he has complete combustion (his theory is that EGT is really just a good guess). He has had very good results from this system in terms of fuel economy and performance. How does it deal with the lead fouling issue? I had always thought that Oxy sensors were only used while the engine was at low power settings, and that once it was cranked up to full power, the engines ran in a closed loop system, ignoring the Oxy sensor. I would think a mass airflow sensor, and a programmed controller to set the mixture to the ideal settings would be more useful. I would be interested in seeing how much the mixture was changed, with the advice of the Oxy sensor setup. Yes, lead would be a problem - the sensor won't last long with av-gas. You can run closed loop at most loads (depending on the type of sensor, you can run closed loop even when you want to run rich for power) For the most common sensor, the output "switches" as you pass through the chemically correct mixture of air and fuel - but you get best economy at air fuel ratios leaner than that... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On Jul 2, 6:52 pm, "Morgans" wrote:
"Blueskies" wrote "A friend flying an IO-360 powered Glasair installed an oxygen sensor system that has an panel mounted indicator light to show when balanced combustion is reached. He simply adjusts mixture until the light comes on and knows he has complete combustion (his theory is that EGT is really just a good guess). He has had very good results from this system in terms of fuel economy and performance. How does it deal with the lead fouling issue? I had always thought that Oxy sensors were only used while the engine was at low power settings, and that once it was cranked up to full power, the engines ran in a closed loop system, ignoring the Oxy sensor. I would think a mass airflow sensor, and a programmed controller to set the mixture to the ideal settings would be more useful. I would be interested in seeing how much the mixture was changed, with the advice of the Oxy sensor setup. I have to admit that it does sound interesting. -- Jim in NC Jim, You have it backwards. EFI uses pre-programmed settings until the engine reaches operating temperature. Then the system enters "closed loop mode" and uses output from the O2 sensor to provide "fuel trim" data which offsets the preprogrammed values for minimum emissions. Some later model cars have electrically heated O2 sensors to allow for closed loop mode quicker (EPA lower emission requirements). When used with 100LL the O2 sensor will slowly become contaminated and cease to work. Gary also in NC |
![]() "Gary" wrote Jim, You have it backwards. EFI uses pre-programmed settings until the engine reaches operating temperature. Then the system enters "closed loop mode" and uses output from the O2 sensor to provide "fuel trim" data which offsets the preprogrammed values for minimum emissions. Some later model cars have electrically heated O2 sensors to allow for closed loop mode quicker (EPA lower emission requirements). Do you know of any web pages that discuss this type of thing? I would like to read more. -- Jim in NC |
![]() "Gary" wrote in message ps.com... On Jul 2, 6:52 pm, "Morgans" wrote: "Blueskies" wrote "A friend flying an IO-360 powered Glasair installed an oxygen sensor system that has an panel mounted indicator light to show when balanced combustion is reached. He simply adjusts mixture until the light comes on and knows he has complete combustion (his theory is that EGT is really just a good guess). He has had very good results from this system in terms of fuel economy and performance. How does it deal with the lead fouling issue? I had always thought that Oxy sensors were only used while the engine was at low power settings, and that once it was cranked up to full power, the engines ran in a closed loop system, ignoring the Oxy sensor. I would think a mass airflow sensor, and a programmed controller to set the mixture to the ideal settings would be more useful. I would be interested in seeing how much the mixture was changed, with the advice of the Oxy sensor setup. I have to admit that it does sound interesting. -- Jim in NC Jim, You have it backwards. EFI uses pre-programmed settings until the engine reaches operating temperature. Then the system enters "closed loop mode" and uses output from the O2 sensor to provide "fuel trim" data which offsets the preprogrammed values for minimum emissions. Some later model cars have electrically heated O2 sensors to allow for closed loop mode quicker (EPA lower emission requirements). When used with 100LL the O2 sensor will slowly become contaminated and cease to work. Gary also in NC I have been told that they slow down, but may not cease to work in the absolute sense. In other works, they will become useless for the closed loop control that an automotive ECM requires, but might remain quite useable in the manner that a pilot might use them. As to a comparison between an O2 sensor and EGT, I just don't know; but I am quite curious. BTW, it is probably usefull to think of the Open Loop Mode of the automotive ECM at Wide Open Throttle as being analogous to the enrichment valve feature of an aircraft carburetor. As soom as you no longer tramp the accelerator firmly to the floor, the ECM will return to best economy (or possibly least emissions) mixture--at least that is the impression which I received from the limited litterature I read. Peter (Awaiting correction from any with real bench experience.) |
"Peter Dohm" wrote in message
... ... BTW, it is probably usefull to think of the Open Loop Mode of the automotive ECM at Wide Open Throttle as being analogous to the enrichment valve feature of an aircraft carburetor. As soom as you no longer tramp the accelerator firmly to the floor, the ECM will return to best economy (or possibly least emissions) mixture--at least that is the impression which I received from the limited litterature I read. Least emissions - it's all about the care and feeding of the three way catalyst (Oxidizes CO and unburned HC, Reduces NOx (NO and NO2)). At best economy (lean), the catalyst can't reduce the NOx. With a wide band (or "universal") oxygen sensor, you can stay closed loop even during power (or catalyst temperature protection) enrichment - but those sensor cost $15-$20 more (at OEM prices) so they are less common. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Knock sensor circuit? | Jerry Wass | Home Built | 0 | May 17th 07 05:18 AM |
carburator temp sensor | Philippe Vessaire | Home Built | 0 | May 14th 06 04:35 PM |
New Thermal sensor | [email protected] | Soaring | 4 | February 1st 05 02:07 PM |
Westach 720-4a sensor | Ira Rampil | Home Built | 1 | June 21st 04 03:41 AM |
temperature sensor | Philippe Vessaire | Home Built | 2 | March 3rd 04 03:37 AM |
