Recently, on a long cross country from Portland, OR to Wisconsin, we stopped
at Helena, MT for a gas and pit stop. Coming from the West with the winds calm, I chose the loc DME BC approach to runway 9. Even though it's the capitol (is it capital?) of the state, there is no radar coverage. First, I had to descend and intercept the DME arc. Once on the arc, we were in turbulence and IMC, and started picking up ice (my Baron had KI certification). Once on the loc BC, there are several step down fixes, but since we were given the approach clearance several thousand feet high, I had a hard time reaching the DME fixes at a low enough altitude. Of course, without radar, the tower was asking us to report position, and I had to keep telling him I was unable to reach the desired altitudes due to the excessive descent rate required. Finally, before the last fix we broke out into VMC, with the valley below and the airport in sight, still several thousand feet high. We circled once, and then landed without difficulty. It was a great learning experience, but I'm not sure what to have done differently. I already had the approach flaps out, and contemplated putting down the gear to help the descent, but hesitated doing this in icing conditions (what if I needed to pull up the gear again for some reason during the approach covered in ice?) I could have chopped the power (was already at 15 inches) and descending at over 1,000 fpm near Va, but I felt a stabilized approach in ice and in mountainous terrain was safer than making even more radical pitch and power changes. I felt like I was behind the eight ball from the start. Is there a better way to have handled the approach? |
"Viperdoc" wrote in message
... I felt like I was behind the eight ball from the start. Is there a better way to have handled the approach? Given your judgement, you did the best you could. I haven't looked at the approach, but based on your statement that you were put on the approach several thousand feet high, maybe you could have asked for a loop in a hold or descent to MEA before getting there. Did you go into the approach knowing that you would break out at an altitude that would allow comfortable circling? Otherwise, doing the necessary dive is what it takes. If the circumstances don't allow it, go somewhere else. You descended at a rate and configuration you were comfortable with - ready to go missed, if necessary. Sounds like you did all the right things (other than asking for lower before the approach) and you landed safely. Were you using the eFB? -- ------------------------------- Travis Lake N3094P PWK |
No EFB- paper all the way. The surrounding terrain is pretty intimidating,
with lots of red areas on the Garmin terrain page on either side of the approach. I was given the slam dunk approach by Center, but it certainly added a lot to the work load. Still carry the EFB as a back up in case we divert to an airport where I don't have paper. Recently travelled from Wisconsin to Portland, and then back, and the following week made a trip to Vermont. It's a lot of charts to buy and lug around, and it seems like fewer FBO's carry them these days. Of course, the trip ended up being right in the middle of a revision cycle, so this required even more paper. Still not comfortable using the EFB as a primary chart source. |
Viperdoc wrote:
Recently, on a long cross country from Portland, OR to Wisconsin, we stopped at Helena, MT for a gas and pit stop. Coming from the West with the winds calm, I chose the loc DME BC approach to runway 9. Even though it's the capitol (is it capital?) of the state, there is no radar coverage. /snip/ Do you have an approach certified GPS on board? If so, you might have chosen the GPS 9 instead. Since, like most GPS approaches, it's much simpler to accomplish than an arc to a Back Course, it might have at least lessened your workload during a bumpy, icy appraoch to an unfamiliar airport. Also, the initial approach fix, SCAAT, is over 20 miles from the runway, and has a published hold. Both of those features might have helped you get down easier. As for executing the BC, sounds like you did as best you could. That one leaves you up pretty high, to begin with. Happy Flying! Scott Skylane |
Actually have two certified GPS on board, a Garmin 530 and a 430, both with
WAAS. One was tuned to the inbound, and the other had the terrain page. It was a tricky approach, and the lack of radar didn't make it any easier. |
On Sun, 8 Jul 2007 06:47:17 -0500, "Viperdoc"
wrote: As a foreign (to the USA) pilot, I have the following questions: 1. The US Terps allows a maximum of 300 feet per nautical mile for both the the intial approach segment and intermediate segment, I believe. Did you require a lesser descent gradient because of icing? 2. I think you can call by a fix, but do not have to be at the charted minimum altitude, so no requirement to advise tower of that. Stan Once on the loc BC, there are several step down fixes, but since we were given the approach clearance several thousand feet high, I had a hard time reaching the DME fixes at a low enough altitude. Of course, without radar, the tower was asking us to report position, and I had to keep telling him I was unable to reach the desired altitudes due to the excessive descent rate required. |
"Viperdoc" writes:
Recently, on a long cross country from Portland, OR to Wisconsin, we stopped at Helena, MT for a gas and pit stop. Coming from the West with the winds calm, I chose the loc DME BC approach to runway 9. Even though it's the capitol (is it capital?) of the state, there is no radar coverage. Yes, Helena is the capitol of Montana. Visit the refurbished capitol building. Very casual atmosphere when the legislature is not in session. First, I had to descend and intercept the DME arc. Once on the arc, we were in turbulence and IMC, and started picking up ice (my Baron had KI certification). Once on the loc BC, there are several step down fixes, but since we were given the approach clearance several thousand feet high, I had a hard time reaching the DME fixes at a low enough altitude. Of course, without radar, the tower was asking us to report position, and I had to keep telling him I was unable to reach the desired altitudes due to the excessive descent rate required. Finally, before the last fix we broke out into VMC, with the valley below and the airport in sight, still several thousand feet high. We circled once, and then landed without difficulty. It was a great learning experience, but I'm not sure what to have done differently. I already had the approach flaps out, and contemplated putting down the gear to help the descent, but hesitated doing this in icing conditions (what if I needed to pull up the gear again for some reason during the approach covered in ice?) I could have chopped the power (was already at 15 inches) and descending at over 1,000 fpm near Va, but I felt a stabilized approach in ice and in mountainous terrain was safer than making even more radical pitch and power changes. I felt like I was behind the eight ball from the start. Is there a better way to have handled the approach? Ask for a couple of 360s somewhere to get down to a more reasonable altitude? You probably have the whole sky to yourself, so the controllers will probably accommodate you. |
There is no radar, and the final approach course is surrounded by mountains,
so I would think circling would have been outside of the protected area of the localizer. Also, circling in turbulence and icing is not a very appealing option. I was told by center to intercept the DME arc, but was not given final approach clearance until established on the localizer BC. The DME and altitude call outs to the tower were required because again, there was no radar. The step downs were all based on DME, and he wanted to know where I was on the approach. |
On Sun, 8 Jul 2007 20:50:31 -0500, "Viperdoc"
wrote: There is no radar, and the final approach course is surrounded by mountains, so I would think circling would have been outside of the protected area of the localizer. Also, circling in turbulence and icing is not a very appealing option. I was told by center to intercept the DME arc, but was not given final approach clearance until established on the localizer BC. Once you were established on the arc could you ask to descend to the published altitudes for the arc itself? |
Easiest and Hardest | [email protected] | Piloting | 13 | July 4th 06 02:39 PM |
Has anyone flown in here? | john smith | Piloting | 2 | October 2nd 05 11:36 AM |
Approach Question- Published Missed Can't be flown? | Brad Z | Instrument Flight Rules | 8 | May 6th 04 04:19 AM |
has anyone flown with these ? | Damian John Paul Brown | General Aviation | 0 | April 15th 04 04:26 AM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
