Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II)
Old August 22nd 03, 04:49 AM
ArtKramr
Default Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II)
Subject: Long-range Spitfires and daylight Bomber Command raids (was:
Date: 8/21/03 7:27 PM Pacific Daylight Time
I'll disagree here. You want two pilots so they can take turns flying tight
formation. For night ops it was no big deal to put the a/c on george and
have
On our missions the guy in the left seat flew formation all the way .
Hmmm, we're assuming here that tight combat boxes are the only way to
go. Whilst I haven't looked at it in depth, I reckon that with
sufficient long range fighter escort, smaller, loser formations might
We flew loose boxes on the way and would tighten for the bomb run. Flying tight
meant burning more gas since it called for non stop throttle jiggling for the
guys in the back to hold their place in the formation.. Also tight formations
were exhausting. You can see the loose formation in my website by clicking on
"B-26 in formation" (pre D-Day) and for a very tight bomb run formation click
on "stipes in Formation" (D-Day) These two photographs are a good example of
just what loose and tight formations looked like.
A more loose formation is going to have a bunch of problems. It's
harder to escort, attampts at evasive action by aircraft within the
formation will at best break the
Not true. It is easier in loose formation.
cells, meaning that teh formation appeared as a single. more diffuse
blip. You'd also lose jamming cover, too. Many B-17s adn B-24s were
carrying Noise Jammers to use on the flak radars, and they were quite
The trick is to make your evasive action totally random.
ou also get a much less concentrated bomb pattern
Bombing in loose formation is out of the question In the USAAF anyway. The
tighter the better.
Arthur Kramer
Visit my WW II B-26 website at:
http://www.coastcomp.com/artkramer
Old August 27th 03, 05:26 AM
Peter Stickney
(ArtKramr) writes:
(Peter Stickney)
have
I'll take a look. (Haven't checked in a while) There's loose, and
then there's loose, too. The RAF idea of a heavy bomber formation was
apparantly loose enough to allow that Corkscrew manaeuver that they
used at night. That would have to be very loose.
I'll agree that a tight formation can be fatigueing for a long flight
- I've flown a few cross-country glider deliveries, where formation
distance was about as fixed as it could get - one towline's length,
and the glider was flying about 20 mph (About 17% of its total speed
range) faster than it could be trimmed for. Let loose foa a second
asn it popped up like a cork. 4 hours is a long time at Mach Nix.
How much evasion did you do, when the flak came up? Was it individual
airplanes, or by flights?
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old August 27th 03, 11:06 AM
John Halliwell
In article , Peter Stickney
writes
The original daylight air fighting tests for the Lanc (late '42 or early
'43) were based on three ship formations. Possibly a 'Vic' or line
abreast. The two outer ships were to corkscrew in opposite directions,
and the central one was to porpoise in sequence with them.
Apparently the manoeuvre gave the bomber gunners good shots and very
poor deflection shots for the attacking fighter.
A look at some photos of Lancs operating in daylight shows predominantly
long, thin formations basically made up of vics that overlap slightly
(rough plan view below; lead on left):
John
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 03:04 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
