i live near a big airport in the nw all kinds of jumbo, extended, huge
planes landing all the time and every now and then you see a little single engine one landing what is the deal? a death wish or? can they just land if they want to? thanks bill |
Most likely is an air taxi from somewhere nearby. Or someone just dropping
off or picking up a passenger. I don't know how they handle TSA scrrening these days. The problem is not so much landing as it is leaving. Not only do you have to get ATC clearance, but the problem of getting sufficient separation to avoid wake turbulence can cause major delays. You can find yourself sitting in the grass waiting for a line of jets to clear. Wally been there done that |
In article zhs3b.286009$Ho3.39431@sccrnsc03,
"Wally Samuelson" wrote: Most likely is an air taxi from somewhere nearby. Or someone just dropping off or picking up a passenger. I don't know how they handle TSA scrrening these days. The problem is not so much landing as it is leaving. Not only do you have to get ATC clearance, but the problem of getting sufficient separation to avoid wake turbulence can cause major delays. You can find yourself sitting in the grass waiting for a line of jets to clear. Wally been there done that It is a "no brainer" to land at major airports. The big problem is uaually that FBOs and airport operators at the majors hate small planes and their pilots. To discourage thaem they often impose landing fees, ramp fees and exhorbitant fuel prices. -- To get random signatures put text files into a folder called ³Random Signatures² into your Preferences folder. |
to get ATC clearance, but the problem of getting sufficient separation to avoid wake turbulence can cause major delays. You can find yourself sitting in the grass waiting for a line of jets to clear. I just happened to post about that on another newsgroup yesterday, so I'll repeat it here with minor changes: I haven't found that getting in or out of big airports is a problem, except at rush hours, when everyone else waits in line, too. At DCA, the tower guys are sharp; they clear me to land my Chrokee on one of the two cross-runways while the big iron is landing or taking off on the long one (18-36). They get me out the same way, while the big jets suffer long waiting lines. One morning, after sleeping in the lounge because the thunderstorms had closed the field, I heard ATIS saying to expect a two-hour delay in departing. Ground cleared me to runway 3 and then the tower cleared me to take off between two jets taking off on 36. I was out of there about as fast as if I'd had the field to myself. Little guys are treated just as well as the big guys. Once I called Dulles approach and was cleared in. The next voice said, in a heavy accent, "Dooles Approach, thees ees Air Frawnce 224, landing Dooles." Dulles came back, "Air France 224, you're number two behind the Cherokee." Made my day! I always get "into the system" by requesting flight following long before I arrive at a big airport. (I do it on almost all flights, anyway.) That way, Approach Control is expecting me, I get handed off to them and it goes like clockwork. vince norris |
"vincent p. norris" wrote in message
At DCA, the tower guys are sharp; they clear me to land my Chrokee on one of the two cross-runways while the big iron is landing or taking off on the long one (18-36). This is really past tense, isn't it? DCA (National Airport) has been closed to general aviation aircraft without specific TSA waivers since 9/11. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
one of the two cross-runways while the big iron is landing or taking off on the long one (18-36). This is really past tense, isn't it? DCA (National Airport) has been closed to general aviation aircraft without specific TSA waivers since 9/11. Yeah, Tom, I suppose I should have added "ed" to that word "clear." But the tower cleared me that way a number of times, so I thought of it as an ongoing situation. Obviously I haven't landed there since 9-11. vince norris |
On Thu, 28 Aug 2003 18:58:39 GMT, "Wally Samuelson"
wrote: Most likely is an air taxi from somewhere nearby. Or someone just dropping off or picking up a passenger. I don't know how they handle TSA scrrening these days. The problem is not so much landing as it is leaving. Not only do you have to get ATC clearance, but the problem of getting sufficient separation to avoid wake turbulence can cause major delays. You can find yourself sitting in the grass waiting for a line of jets to clear. Wally been there done that When in the pattern at John Wayne International in a 172 the tower advised me to "increase speed or depart the pattern" as the DC-10 behind me was about to run over us :-) Landing can be an adventure. Al Minyard |
ok
thanks so it is not that unusual but i still think you kind of have to have very big gonads and be very very confident and knowledgable thanks bill |
very big gonads On the contrary. I'm an old pilot because I've always avoided being a bold pilot. and be very very confident and knowledgable Yes, you have to know what you're doing, and equally important, SOUND (on the radio) like you know what you're doing, to generate confidence on the part of the controllers that you can and will do what they clear you to do, and won't cause a disaster. vince norris |
very big gonads and be very very confident and knowledgable Gonads aren't at all necessary, but it certainly helps (in all flying, not just into large airports) to be confident and knowledgable. Especially knowledgable ![]() all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
| Thread Tools | |
| Display Modes | |
| "bush flying" in the suburbs? | [email protected] | Home Built | 85 | December 29th 04 12:04 AM |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 06:40 PM |
| Cessna Steel Landing Gears, J-3 Seat Sling For Auction | Bill Berle | Home Built | 0 | February 19th 04 07:51 PM |
| Cessna Steel Landing Gears, J-3 Seat Sling For Auction | Bill Berle | Aviation Marketplace | 0 | February 19th 04 07:51 PM |
| Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 05:35 PM |
