I just picked up a used U-2. It's quite a hoot to fly, but I'm having
some trouble. Maybe you can help me out. 1) When I go cruising above 60,000 ft I cancel my IFR clearance. Then I buzz around a bit. But how do I come back down legally? Obviously I need an IFR clearance to decend back down to FL 590, but Center does not have to grant my request for a sudden IFR clearance. I have limited fuel. What should I do? 2) While I'm up above FL 600, I'm self-seperating from the other traffic. But my friend also has a U-2 and we sometimes frequent the same airspace. It's nearly impossible to see another plane with a closure rate of 1,200 mph, and U-2s don't have TCAS. Can I request flight following at these altitudes, just for the help with separation? 3) I was right at 59,999 feet and requested a climb of two feet. The controller denied my request! Can he do that? It really wastes fuel to fly around so low! -Much Thanks -Charles Talleyrand, U2 pilot |
I think "You Two" need some help...
;O) Jay Beckman PP-ASEL Chandler, AZ (And so am I...) |
On Jul 28, 2:52 am, Charles Talleyrand wrote:
I just picked up a used U-2. It's quite a hoot to fly, but I'm having some trouble. Maybe you can help me out. 1) When I go cruising above 60,000 ft I cancel my IFR clearance. Then I buzz around a bit. But how do I come back down legally? Obviously I need an IFR clearance to decend back down to FL 590, but Center does not have to grant my request for a sudden IFR clearance. I have limited fuel. What should I do? 2) While I'm up above FL 600, I'm self-seperating from the other traffic. But my friend also has a U-2 and we sometimes frequent the same airspace. It's nearly impossible to see another plane with a closure rate of 1,200 mph, and U-2s don't have TCAS. Can I request flight following at these altitudes, just for the help with separation? 3) I was right at 59,999 feet and requested a climb of two feet. The controller denied my request! Can he do that? It really wastes fuel to fly around so low! -Much Thanks -Charles Talleyrand, U2 pilot 1. File a composite flight plan, IFR-VFR-IFR. 2. Request flight following but realize it's up to ATC to give it on a workload permitting basis. 3. If in contact with ATC, you must follow their instructions. Make your request but follow any instructions they give you. At least that's the way I do it ![]() |
On Jul 28, 12:52 am, Charles Talleyrand wrote:
I just picked up a used U-2. It's quite a hoot to fly, but I'm having some trouble. Maybe you can help me out. But how do I come back down legally? Obviously I need an IFR clearance to decend back down to FL 590, but Center does not have to grant my request for a sudden IFR clearance. Prefile. |
![]() "Charles Talleyrand" wrote in message oups.com... I just picked up a used U-2. It's quite a hoot to fly, but I'm having some trouble. Maybe you can help me out. 1) When I go cruising above 60,000 ft I cancel my IFR clearance. Then I buzz around a bit. But how do I come back down legally? Obviously I need an IFR clearance to decend back down to FL 590, but Center does not have to grant my request for a sudden IFR clearance. I have limited fuel. What should I do? Turn the transponder to the off position 2) While I'm up above FL 600, I'm self-seperating from the other traffic. But my friend also has a U-2 and we sometimes frequent the same airspace. It's nearly impossible to see another plane with a closure rate of 1,200 mph, and U-2s don't have TCAS. Can I request flight following at these altitudes, just for the help with separation? I believe the plane has radar. 3) I was right at 59,999 feet and requested a climb of two feet. The controller denied my request! Can he do that? It really wastes fuel to fly around so low! Who cares no one can catch you. -Much Thanks -Charles Talleyrand, U2 pilot |
In a previous article, Charles Talleyrand said:
1) When I go cruising above 60,000 ft I cancel my IFR clearance. Then Why? It's class E, you can stay on your IFR clearance. 3) I was right at 59,999 feet and requested a climb of two feet. The controller denied my request! Can he do that? It really wastes fuel to fly around so low! Request VFR Over The Top. You'll be responsible for separation, but you can fly your own altitude, but you'll still be IFR. -- Paul Tomblin http://blog.xcski.com/ "Mary had a little key,/She kept it in escrow/And everything that Mary sent/The Feds were sure to know." - Sam Simpson on sci.crypt |
![]() "Paul Tomblin" wrote in message ... Request VFR Over The Top. You'll be responsible for separation, but you can fly your own altitude, but you'll still be IFR. VFR over-the-top is a VFR operation. VFR-on-top is an IFR operation. |
![]() "Charles Talleyrand" wrote in message oups.com... I just picked up a used U-2. It's quite a hoot to fly, but I'm having some trouble. Maybe you can help me out. 1) When I go cruising above 60,000 ft I cancel my IFR clearance. Then I buzz around a bit. But how do I come back down legally? Obviously I need an IFR clearance to decend back down to FL 590, but Center does not have to grant my request for a sudden IFR clearance. I have limited fuel. What should I do? You would need an IFR clearance at FL 600. You're right that ATC doesn't have to grant your request for an IFR popup, but they'd have little reason to refuse. If that's a concern then don't cancel IFR when you climb above FL 600. 2) While I'm up above FL 600, I'm self-seperating from the other traffic. But my friend also has a U-2 and we sometimes frequent the same airspace. It's nearly impossible to see another plane with a closure rate of 1,200 mph, and U-2s don't have TCAS. Can I request flight following at these altitudes, just for the help with separation? Sure. 3) I was right at 59,999 feet and requested a climb of two feet. The controller denied my request! Can he do that? It really wastes fuel to fly around so low! Why did you waste his time with a silly request? |
Steven P. McNicoll wrote:
"Charles Talleyrand" wrote in message oups.com... 3) I was right at 59,999 feet and requested a climb of two feet. The controller denied my request! Can he do that? It really wastes fuel to fly around so low! Why did you waste his time with a silly request? Probably for the same reason that several of you have replied to this troll! :-) Matt |
![]() "Charles Talleyrand" wrote in message oups.com... I just picked up a used U-2. It's quite a hoot to fly, but I'm having some trouble. Maybe you can help me out. 1) When I go cruising above 60,000 ft I cancel my IFR clearance. Then I buzz around a bit. But how do I come back down legally? Obviously I need an IFR clearance to decend back down to FL 590, but Center does not have to grant my request for a sudden IFR clearance. I have limited fuel. What should I do? 2) While I'm up above FL 600, I'm self-seperating from the other traffic. But my friend also has a U-2 and we sometimes frequent the same airspace. It's nearly impossible to see another plane with a closure rate of 1,200 mph, and U-2s don't have TCAS. Can I request flight following at these altitudes, just for the help with separation? 3) I was right at 59,999 feet and requested a climb of two feet. The controller denied my request! Can he do that? It really wastes fuel to fly around so low! -Much Thanks -Charles Talleyrand, U2 pilot I just got my SR71 up and running so stay the hell out of my way. --------------------------------------------- DW |
New 18m Class ship - First Flight - The JS1 starts proving flight phase | [email protected] | Soaring | 2 | December 14th 06 02:06 AM |
Single Seat Aircraft: Flight Reviews and Flight Tests | Robert M. Gary | Piloting | 1 | August 17th 05 11:17 PM |
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown, New Jersey | Guy Elden Jr | Piloting | 0 | April 21st 05 04:37 PM |
FA: Vintage Textbook - FLIGHT MECHANICS - Vol 1 - Theory of Flight Paths | Richard | Aviation Marketplace | 0 | February 14th 05 01:56 PM |
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? | Scott Ferrin | Military Aviation | 0 | April 3rd 04 08:47 PM |
