July issue of AOPA pilot considered density altitude a major topic. I
have looked a bit around on the net and found formulas to compute exact density altitude from indicated altitude and weather data. (http://wahiduddin.net/calc/density_altitude.htm) Well, I implemented these formulas into a Google gadget. You can find it at http://airspace-v.com/ggadgets You can add it to Google, use it on http://www.airspace-v.com, or put it on your own web site. Of course, this also holds for other gadgets listed on this page. There is at least one more gadget interesting for flight preparation: The wind calculator to compute heading and flight time from TAS, course, wind speed and wind direction. Different units of measurement are supported. You may even mix them. virtuPIC P.S.: You have sauna experience? At altitude ? In ski holidays? Calculate the corresponding density altitude! I know why I am yawning in there. ;-) -- Airspace V - international hangar flying! http://www.airspace-v.com |
("Howie" wrote)
(http://wahiduddin.net/calc/density_altitude.htm) Well, I implemented these formulas into a Google gadget. You can find it at http://airspace-v.com/ggadgets P.S.: You have sauna experience? At altitude ? In ski holidays? Calculate the corresponding density altitude! I know why I am yawning in there. ;-) http://www.airspace-v.com/ggadgets/densityAltitude.htm Fun! ...I thought so anyway. 900 ft .....Elevation 110 F ....Temp 29.92 ....Barometer guess 90% ......Humidity 5,282 ft .....@ the Y.M.C.A. (What?? That's where the steam room is. g) Paul-Mont |
"Montblack" wrote in message ... snip 900 ft .....Elevation 110 F ....Temp 29.92 ....Barometer guess 90% ......Humidity 5,282 ft .....@ the Y.M.C.A. (What?? That's where the steam room is. g) Where does elevation come into it? temp, pressure and humidity defines the density of the air ( 1.083kg/m3 in this case) , which is then compared to the density of the standard atmosphere, which in my calcs gives 4140 ft as the density altitude. terry |
900 is where you start.
d&tm wrote: "Montblack" wrote in message ... snip 900 ft .....Elevation 110 F ....Temp 29.92 ....Barometer guess 90% ......Humidity 5,282 ft .....@ the Y.M.C.A. (What?? That's where the steam room is. g) Where does elevation come into it? temp, pressure and humidity defines the density of the air ( 1.083kg/m3 in this case) , which is then compared to the density of the standard atmosphere, which in my calcs gives 4140 ft as the density altitude. terry |
| density altitude calculator and wind calculator on web site and asGoogle gadget | virtuPIC[_2_] | General Aviation | 0 | August 4th 07 06:55 PM |
| VFR xcountry calculator/log (NEW!!!) | Cecilia Lang | Piloting | 0 | December 26th 05 11:45 AM |
| E6B calculator for IPAQ? | Paul kgyy | Piloting | 2 | May 14th 05 12:05 PM |
| Calculator | Phoebus_810 | Soaring | 0 | January 8th 05 05:36 PM |
| JSW Glide Calculator | snaproll59 | Soaring | 5 | November 7th 04 05:01 PM |
