WX1000+ Stormscope problem
Old August 5th 07, 08:09 AM posted to rec.aviation.owning
Kyprianos Biris[_2_]
Default WX1000+ Stormscope problem
I recently got an L3 Avionics (ex BFGoodrich) WX1000+ stormscope installed.
http://www.as.l-3com.com/products/wx1000.aspx
It is second hand but it got all the checks and forms by the avionics vender
including being sent to L3 avionics for re-certification papework just
before installation.
The Avionics shop which installed it in Europe is EASA Part 145 approved and
did very good work but its away from my country and I would have to fly the
aircraft there again for checks.
The problem is that the WX unit reboots on its own every few minutes (5~10)
displaying the intro. screen again.
No error reports, nothing, just a restart as if I had switched it off and on
again and then as soon as I choose the operation mode (120* or 360*) it
functions properly.
Has it happened to any of you that owns an aircraft with such a stormscope ?
Possible reason ?
Possible remedies ?
Old August 7th 07, 02:38 AM posted to rec.aviation.owning
installed. [...] The problem is that the WX unit reboots on its own
every few minutes (5~10) displaying the intro. screen again. No error
it functions properly.
Disclaimer: This is based on experience with ground vehicles and
equipment. I don't have an A&P (United States aircraft mechanic license)
or an aircraft mechanic license from any other country. Some of this may
not be allowable owner maintenance. Some of this may not be allowable on
a certificated aircraft.
My first guess would be a power problem. Either one of the power wires
(to the bus) or ground wires (to the airframe) for the stormscope has an
intermittent connection. Sometimes this is a break in the middle of a
wire but often it happens at the ends, where the wire attaches to a
switch, circuit breaker, connector, etc.
On the ground, you might switch on the electrical system and try
(gently!) tapping on the panel around the stormscope, tapping on the
breaker that controls power to it, etc, to see if you can make it fail.
Or, it might not show up until you start the engine and have the engine
vibration too.
It's also pretty easy to plug in a connector so it makes good electrical
contact, but to forget to tighten the screws or latches so it *stays*
plugged in. (Ask me how I know.) If there are any multiple-pin
connectors on the stormscope, you might make sure that the locking
rings, or screws, or latches that hold them to the stormscope are
tightened.
Another possibility is that the wiring is basically OK, but the voltage
in your electrical system is sometimes too high or too low. The
stormscope might reset itself if it sees the input voltage being too
low or too high. You would probably be noticing problems with other
equipment, but do you have a voltmeter in the plane? What does it say?
Matt Roberds
Stormscope Roland Instrument Flight Rules 10 December 4th 05 07:51 PM
ADF vs. StormScope antenna David Megginson Instrument Flight Rules 0 September 6th 03 10:03 PM
WX1000 Stormscope battery D. J. Gooding Owning 2 August 9th 03 02:25 AM
FS: WX-1000E Stormscope Lenny Sawyer Aviation Marketplace 0 July 1st 03 02:29 AM
FS: WX-1000E Stormscope Lenny Sawyer Owning 0 July 1st 03 02:29 AM
