![]() This weeks AW&ST has an article on a new UCAV that Lockheed is working on that would be launched from an F-22. It would have a range of a thousand miles, landing gear etc. etc. It would weigh about 7500 pounds and each fighter would carry two. My question is this: The published information I've seen lists the F-22's pylons as being rated at 5000lbs so how would it carry a 7500lb munition? Would they just severly restrict it's G loading when carrying it? Use some kind of adapter that attaches to BOTH hardpoints on a wing and carry it in the middle? Or would they beef up the wing? |
Scott Ferrin wrote: This weeks AW&ST has an article on a new UCAV that Lockheed is working on that would be launched from an F-22. It would have a range of a thousand miles, landing gear etc. etc. It would weigh about 7500 pounds and each fighter would carry two. My question is this: The published information I've seen lists the F-22's pylons as being rated at 5000lbs so how would it carry a 7500lb munition? Would they just severly restrict it's G loading when carrying it? Use some kind of adapter that attaches to BOTH hardpoints on a wing and carry it in the middle? Or would they beef up the wing? Are you sure it said "launched," and not "controlled from?" If it really meant "launched," maybe they mistyped "750 pounds." -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
On Mon, 22 Sep 2003 03:14:39 GMT, Chad Irby wrote:
In article , Scott Ferrin wrote: This weeks AW&ST has an article on a new UCAV that Lockheed is working on that would be launched from an F-22. It would have a range of a thousand miles, landing gear etc. etc. It would weigh about 7500 pounds and each fighter would carry two. My question is this: The published information I've seen lists the F-22's pylons as being rated at 5000lbs so how would it carry a 7500lb munition? Would they just severly restrict it's G loading when carrying it? Use some kind of adapter that attaches to BOTH hardpoints on a wing and carry it in the middle? Or would they beef up the wing? Are you sure it said "launched," and not "controlled from?" If it really meant "launched," maybe they mistyped "750 pounds." ". . .The low-observable, 7,500-lb. unmanned aircraft will be physically small enough that one can be carried under each wing. The initial concept of operations is that a two-ship formation would launch and control four UAVs. Since F/A-22s have only one crewman, it's likely that one pilot would monitor the UAVs while the other maintained situational awareness of threats on the airborne battlefield. Nonetheless, the pilot workload is expected to be less than that required for an AIM-120 air-to-air missile launch. Minion is to have a range of up to 1,000 naut. mi. so it can fly back to a forward operating base where it alights on its own retractable landing gear. Each UAV is to have a weapons bay large enough to carry four 220-lb., precision-guidance, small-diameter bombs. . ." |
Scott Ferrin wrote: ". . .The low-observable, 7,500-lb. unmanned aircraft will be physically small enough that one can be carried under each wing. That's... interesting. Especially since the Minion is 3/4 the size of the X-45. That "use two pylons" idea from the first post is probably right, then. Or maybe they're going to make a special rig to replace the pylons with a single release point? We definitely need pictures. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
On Mon, 22 Sep 2003 04:28:27 GMT, Chad Irby wrote:
In article , Scott Ferrin wrote: ". . .The low-observable, 7,500-lb. unmanned aircraft will be physically small enough that one can be carried under each wing. That's... interesting. Especially since the Minion is 3/4 the size of the X-45. That "use two pylons" idea from the first post is probably right, then. Or maybe they're going to make a special rig to replace the pylons with a single release point? We definitely need pictures. It's wings fold like those on the JASSM. I'd think that if they wanted to do it with no modifications they'd use a bracket that attached to the two hardpoints on each wing and then attach the UCAV to the center of that. Depending on clearances they could probably do something similar on the F-35- barely. |
