I have a fault with my cambridge version 2 which I
wonder if any one else has experienced. I will try the agent but in between time .....? On a recent flight the speed to fly indicator played up showing full pull up advice with settings Mc 0 speed 45 knots and showing 2 down ! Before this it has been good for the two years I have had it It is 15 years old so maybe it has had its day ? [ like me ] Any ideas folks Brian K.G.C. Brian L-Smith Kent England Brian L-Smith |
Brian Laverick-Smith wrote:
I have a fault with my cambridge version 2 which I wonder if any one else has experienced. I will try the agent but in between time .....? On a recent flight the speed to fly indicator played up showing full pull up advice with settings Mc 0 speed 45 knots and showing 2 down ! Before this it has been good for the two years I have had it It is 15 years old so maybe it has had its day ? [ like me ] Any ideas folks Brian K.G.C. Brian L-Smith Kent England Brian L-Smith I had some intermittent problems with an L-NAV recently. Netto sometimes showed eight knots up sitting on the ground, winds aloft sometimes showed as extremely high, and of course the altitude required indication was way off. There are some connectors between boards that are tin-plated, and the processor chip was socketed with a socket having tin-plated pins. Not good design at all for an aircraft instrument. Took it apart, reseated everything including the processor, and also replaced the battery. Not sure which item fixed it, but works fine now. -Dave |
LNav 'goofiness' is almost always a depleted battery. --No, won't
help to use a 14 volt battery on it David :-) Larry "01" Zero One "David Kinsell" wrote in message : Brian Laverick-Smith wrote: I have a fault with my cambridge version 2 which I wonder if any one else has experienced. I will try the agent but in between time .....? On a recent flight the speed to fly indicator played up showing full pull up advice with settings Mc 0 speed 45 knots and showing 2 down ! Before this it has been good for the two years I have had it It is 15 years old so maybe it has had its day ? [ like me ] Any ideas folks Brian K.G.C. Brian L-Smith Kent England Brian L-Smith I had some intermittent problems with an L-NAV recently. Netto sometimes showed eight knots up sitting on the ground, winds aloft sometimes showed as extremely high, and of course the altitude required indication was way off. There are some connectors between boards that are tin-plated, and the processor chip was socketed with a socket having tin-plated pins. Not good design at all for an aircraft instrument. Took it apart, reseated everything including the processor, and also replaced the battery. Not sure which item fixed it, but works fine now. -Dave |
01-- Zero One wrote:
LNav ‘goofiness’ is almost always a depleted battery. The units have a low-voltage warning built in, so anybody should be able to tell if that's the problem. You can't really replace the battery without flexing the boards and renewing the connections, so it's a bit hard to separate the two. --No, won’t help to use a 14 volt battery on it David J I least I don't tell people that radios work just great on 8 volts :-) Dave Larry “01” Zero One "David Kinsell" wrote in message : Brian Laverick-Smith wrote: I have a fault with my cambridge version 2 which I wonder if any one else has experienced. I will try the agent but in between time .....? On a recent flight the speed to fly indicator played up showing full pull up advice with settings Mc 0 speed 45 knots and showing 2 down ! Before this it has been good for the two years I have had it It is 15 years old so maybe it has had its day ? [ like me ] Any ideas folks Brian K.G.C. Brian L-Smith Kent England Brian L-Smith I had some intermittent problems with an L-NAV recently. Netto sometimes showed eight knots up sitting on the ground, winds aloft sometimes showed as extremely high, and of course the altitude required indication was way off. There are some connectors between boards that are tin-plated, and the processor chip was socketed with a socket having tin-plated pins. Not good design at all for an aircraft instrument. Took it apart, reseated everything including the processor, and also replaced the battery. Not sure which item fixed it, but works fine now. -Dave |
Actually, I was speaking of the internal battery inside the LNav. It is
a small coin style battery used to retain settings. I have had mine go south and all sorts of weirdness were the result. Larry PS: Dave, maybe you need to run your radios on metric volts or something. :-) "David Kinsell" wrote in message : 01-- Zero One wrote: LNav 'goofiness' is almost always a depleted battery. The units have a low-voltage warning built in, so anybody should be able to tell if that's the problem. You can't really replace the battery without flexing the boards and renewing the connections, so it's a bit hard to separate the two. --No, won't help to use a 14 volt battery on it David J I least I don't tell people that radios work just great on 8 volts :-) Dave Larry "01" Zero One "David Kinsell" wrote in message : Brian Laverick-Smith wrote: I have a fault with my cambridge version 2 which I wonder if any one else has experienced. I will try the agent but in between time .....? On a recent flight the speed to fly indicator played up showing full pull up advice with settings Mc 0 speed 45 knots and showing 2 down ! Before this it has been good for the two years I have had it It is 15 years old so maybe it has had its day ? [ like me ] Any ideas folks Brian K.G.C. Brian L-Smith Kent England Brian L-Smith I had some intermittent problems with an L-NAV recently. Netto sometimes showed eight knots up sitting on the ground, winds aloft sometimes showed as extremely high, and of course the altitude required indication was way off. There are some connectors between boards that are tin-plated, and the processor chip was socketed with a socket having tin-plated pins. Not good design at all for an aircraft instrument. Took it apart, reseated everything including the processor, and also replaced the battery. Not sure which item fixed it, but works fine now. -Dave |
And the wierd stuff starts LONG before the battery
reaches the low voltage level that gives the warning! Pete |
Cambridge 302 & PDA -- Value of adding Cambridge 303? | V1 | Soaring | 5 | July 31st 07 03:51 AM |
Cambridge | Mark Hope | Soaring | 11 | November 25th 04 09:40 PM |
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 | Nathan Whelchel | Soaring | 4 | July 5th 04 11:22 PM |
Cambridge "V" | JJ Sinclair | Soaring | 0 | March 11th 04 02:01 PM |
FS Cambridge 302/303 | H201b | Soaring | 2 | December 21st 03 09:05 PM |
