Mixture--science vs witchcraft?
Old August 18th 07, 10:43 PM posted to rec.aviation.owning
Douglas Paterson
Default Mixture--science vs witchcraft?
Still getting to know my new baby (1990 TB-20, normally aspirated 250hp
Lycoming IO-540). I imagine my question here must apply to most non-turbo,
non-FADEC pistons (though I gather there's some sort of altitude compensator
on some airplanes' engines?). I live in Colorado, which means routine
high-elevation airport ops.
I'm looking for guidance on proper mixture setting for takeoff & landing at
high-elevation (with correspondingly high DA) fields. What's the best way
to achieve maximum power in these conditions?
The "book" answer, per the POH, of full rich for takeoff and landing is
clearly wrong--indeed, I stalled the engine on my first landing roll-out
back here (I was lean of full rich, but, obviously, not enough!). I'm
looking for some "science" to put behind this, instead of "mmm, about
*there*".... I've been tweaking the mixture for highest rpm during the
run-up (2,000 rpm), then looking for a couple of gph above the book's climb
fuel flow for the existing DA on takeoff roll. That seems to work OK for
takeoff, but, of course, I'm somewhat back to guessing for landing
(especially at a different field or if the DA has significantly changed).
Any suggestions or comments?
FYI, the field I'm basing from is 7,030' elevation, with 9 - 10K' DAs
typical; and we've been to Leadville (LXV)--elevation 9,927', North
America's highest municipal airport & highest paved runway, DA of 11,700'
when we visited. This is far more than just an academic discussion for me!!
Doug
"Where am I to go/Now that I've gone too far?" -- Golden Earring, "Twilight
Zone"
(my email is spam-proofed; read the address and make the appropriate change
to contact me)
Old August 18th 07, 11:16 PM posted to rec.aviation.owning
Matt Barrow[_4_]
"Douglas Paterson" wrote in message
non-turbo, non-FADEC pistons (though I gather there's some sort of
altitude compensator on some airplanes' engines?). I live in Colorado,
which means routine high-elevation airport ops.
at high-elevation (with correspondingly high DA) fields. What's the best
way to achieve maximum power in these conditions?
climb fuel flow for the existing DA on takeoff roll. That seems to work
OK for takeoff, but, of course, I'm somewhat back to guessing for landing
me!!
http://www.avweb.com/news/pelican/list.html (Start with #18 and go through
the entire "Engine-Related Columns" series)
Matt Barrow
Performance Homes, LLC.
Cheyenne, WY
Old August 19th 07, 04:43 PM posted to rec.aviation.owning
Douglas Paterson
"Matt Barrow" wrote in message
Matt, that was a great series, thanks for the pointer. I found #63, "Where
Should I Run My Engine? (Part 1)," to most closely address my question.
http://www.avweb.com/news/pelican/182179-1.html
However, I'm still disappointed. Deakin's advice still falls on the
"witchcraft" side of the equation, in my book, boiling down to "put the
mixture where it feels right. From that article:
The books are full of various techniques for this, but I find the
simplest and most effective is just add full throttle,
full RPM, then grab the mixture knob and move it aggressively from
full rich to whatever feels like "more power"
on the takeoff roll. You can't hurt the engine with momentary
mixture settings like this on normally aspirated
engines! Saw that mixture knob back and forth, and feel the power
change in the seat of your pants! At some
point as you pull the mixture out from full rich, you'll feel the
power first increase, then for a large part of the
movement you'll feel no power change at all, because the "best
power" mixture setting is very flat in that area. (In
other words, "best power" occurs over a fairly wide range of rich
settings, but not at full rich.) Go ahead, pull it a
bit too far, and you'll feel the power drop off from being not rich
enough. Push it back in to the point where you
first felt the best power, and forget it. It's quick, simple, and
very effective, and pinpoint accuracy is not necessary.
However well this may work (??), it hardly qualifies as "science." Anyone
have any suggestions on what "books" he may be referring to when he says
"the books are full of various techniques"?
A big take-away from these articles is that I'm probably wasting my time
tweaking for max power (rpm) during the runup. Also, reading between the
lines seems to indicate that using the climb fuel flow chart from the POH is
probably a decent starting point--though I'm not yet really convinced of
that. Thanks again for the discussion--I appreciate any & all insights!
Doug
Zone"
to contact me)
Old August 19th 07, 06:00 PM posted to rec.aviation.owning
Dennis Johnson
I believe that the best "science based" information about this topic is
available from the GAMI folks in ADA, Oklahoma
http://www.gami.com/frames.htm
They have perhaps the best instrumented piston airplane engine anywhere and
have collected lots of repeatable data that are the basis for their
recommendations. They have seminars that answer the kinds of questions
you're asking and now offer them online, too. Lots of graphs and tables. I
haven't attended yet, but I plan to.
In another message, you asked about the mixture setting for maximum power.
I think max power is in the vicinity of 25 - 50 degrees rich of peak EGT.
In cruise at altitude, pull the mixture out until the EGT starts decreasing,
push it back in until it peaks, then push it in some more to get 25 - 50
degrees less than peak. That procedure doesn't work on takeoff; the method
suggested by David Paterson in another post is a good one for takeoff.
Running full rich for takeoff at very high density altitude will put you way
too rich and you'll give up lots of horsepower when you need it the most.
Running full rich for low density altitude takeoffs is important because the
engine is producing at or close to maximum power, where cylinder cooling is
needed. The richer mixture effectively retards the timing, which causes the
peak cylinder pressure to occur later in the combustion cycle, which results
in cooler CHT.
Dennis
Old August 20th 07, 12:33 AM posted to rec.aviation.owning
Matt Barrow[_4_]
"Dennis Johnson" wrote in message
Agreed!!!!
Also, their sister company, http://www.advancedpilot.com seminar is about
the best thousand bucks you'll ever spend. It's paid itself back many times
over in terms of 100LL $$$ and maintenance (when I traded my 1800 hr TN
Bonanza 36, there was virtually zero lead buildup in the engine and
compressions were all still well into the 70's).
Old August 20th 07, 12:25 AM posted to rec.aviation.owning
Matt Barrow[_4_]
through the entire "Engine-Related Columns" series)
"Where Should I Run My Engine? (Part 1)," to most closely address my
question. http://www.avweb.com/news/pelican/182179-1.html
The old P&W series from the 40's and 50s.
I think, though, you're confusing his method of getting from rich to lean.
Given his copious charts and lengthy explanations of each, and discussion of
the "Danger Zone", lingering in the peak areas is, his points are in fact,
well documented. The part you mention above is, IIRC, how to do it without
proper instrumentation.
is probably a decent starting point--though I'm not yet really convinced
of that. Thanks again for the discussion--I appreciate any & all
insights!
Read his articles about the lunacy in most POHs.
You might find it helpful to print out his entire engine series and read
them slowly, trying to integrate all that he has to say. There is certainly
a load of information there and it's more difficult to grasp in that so much
of it goes contrary to what most all of us have been taught over the past
couple generations. (Think of the Enlightenment and Renaissance after the
Inquisition).
Good luck with your new bird!!
Matt Barrow
Cheyenne, WY
Old August 19th 07, 02:21 AM posted to rec.aviation.owning
Newps
250 HP needs about 20-22 gph for takeoff. After takeoff and throughout
the climb set mixture to achieve 1250-1300 EGT, any altitude. For
landing leave the mixture where it was for cruise. If you need to do a
go around then make sure to advance the mixture a little as you ease the
power in.
Old August 19th 07, 03:15 AM posted to rec.aviation.owning
Jim Carter[_1_]
-----Original Message-----
Posted At: Saturday, August 18, 2007 8:21 PM
Posted To: rec.aviation.owning
Conversation: Mixture--science vs witchcraft?
Subject: Mixture--science vs witchcraft?
throughout
a
power in.
The engine won't generate 250 HP at altitude will it? Isn't that a sea
level rating based on the pressure of the air available at sea level? So
the 20-22 gph would be for sea level wouldn't it?
At FL180 the pressure is 1/2 of sea level so we can interpolate that at
9000' the pressure would be only 3/4 of sea level, then factor in the
temperature for the density altitude the engine will really breathe.
Doesn't this mean that the normally aspirated engine in the OPs question
will produce significantly less than 250 HP? I'm not going to do the
math because I'm sure to get it wrong and there are many others on here
more qualified than I, so I'm only guessing that we might see 200 HP. If
that's the case then instead of 20-22 gph wouldn't we be looking for
around 16 gph?
Old August 19th 07, 09:53 AM posted to rec.aviation.owning
Thomas Borchert
Jim,
around 16 gph?
You're dead on.
Thomas Borchert (EDDH)
Old August 19th 07, 04:22 PM posted to rec.aviation.owning
Newps
You need that for proper cooling to make up for the little airflow
you're getting.
X-Prize is currently live on Discovery Science Channel Roger Halstead Home Built 50 October 10th 04 11:49 AM
TSA Rocket Science Judah Piloting 11 January 14th 04 11:59 PM
TALK OF THE NATION: SCIENCE FRIDAY EDR Piloting 0 December 11th 03 09:35 PM
Science, technology highlighted at hearing Otis Willie Military Aviation 0 July 23rd 03 10:30 PM
X-Plane in Popular Science Magazine Danay Westerlage Simulators 0 July 13th 03 07:04 PM
