Usefulness of Oil Analysis
Old August 19th 07, 12:33 PM posted to rec.aviation.owning
Jim Carter[_1_]
Default Usefulness of Oil Analysis
From those that use it, I'm interested in the usefulness of starting an
oil analysis program on a big bore Continental that already has 850 SMOH
and 450 STOH on an 1100 TBO. Does it take so long to establish a
baseline and trend that it would be better to wait until OH or can an
individual engine be compared to the class as a whole?
Kindest regards,
James A. (Jim) Carter, ANS #8215
Rogers, Arkansas
Anyone can do the job when things are going right. In this business we
play for keeps.
- Ernest K. Gann
Old August 19th 07, 02:41 PM posted to rec.aviation.owning
Oil analysis is a very usefull tool for showing the status of the
inner workings of the motor. Your first sample will give you instant
results if there is something major failing, based on thousands of
other samples of like engines. At about the third sampling of your
perticular engine trends will develop showing the state of your
powerplant. Oil analysis is a inexpensive way to keep you safe, and at
about 15 bucks a shot a great value in aviation. Do it today....
Ben
www.haaspowerair.com
Kindest regards,
Rogers, Arkansas
play for keeps.
- Ernest K. Gann
Old August 19th 07, 11:47 PM posted to rec.aviation.owning
Dave[_3_]
Jim, I am part of the "Choir" here...
I have 2 large marine engines and one aircraft engine. (all 3 are
And.....
I depend on them !!!
I have used oil analysis for 25 years,- boat, heavy trucks, and now
on the plane.
Cheap "peace of mind cost".
It WILL turn up some problems in time for a minor fix, before it
becomes a catastrophic failure.
It will take about 3 tests to set a "normal" baseline for your engine
(s). After that, sudden changes are quickly detected.
We tore down an exhaust system last week, confident the antifreeze
leak was not in the block because if it was, the coolant would have
been detected in the oil. (there was none)
It is part of knowing you have taken EVERY reasonable precaution to
insure your safety flying behind that engine.
Dave
On Sun, 19 Aug 2007 11:33:22 GMT, "Jim Carter"
Kindest regards,
Rogers, Arkansas
play for keeps.
- Ernest K. Gann
Old August 21st 07, 07:12 PM posted to rec.aviation.owning
Jim Stewart
And.....
Who do you use for your aircraft engine?
Old August 21st 07, 03:10 AM posted to rec.aviation.owning
Dave[_1_]
Hi Jim!
I use...
Staveley Services
935 Sunshine Road
Kansas City KS 66115-1122
(800) 332-8055
http://www.staveleyfa.com/public/FLhome.asp
....Formally CTC..
I get the "spectrochemical analysis"' done each oil change.
Davce
On Tue, 21 Aug 2007 11:12:14 -0700, Jim Stewart
And.....
Old August 20th 07, 04:39 PM posted to rec.aviation.owning
Ross
Kindest regards,
Rogers, Arkansas
play for keeps.
- Ernest K. Gann
When I bought my airplane I started an oil analysis program right away.
I had about 400 hours to go to TBO. ( I was going to go longer, but that
is another story). Then I changed engines and continued the program. I
use Metal Check and get the kits right from the factory. They even now
put the results on the web and can show trend analysis. Something I was
doing on Excel originally.
Regards, Ross
C-172F 180HP
KSWI
Old August 21st 07, 02:59 AM posted to rec.aviation.owning
Jim Carter[_1_]
-----Original Message-----
Posted At: Monday, August 20, 2007 10:40 AM
Posted To: rec.aviation.owning
Conversation: Usefulness of Oil Analysis
Subject: Usefulness of Oil Analysis
....I
was
Regards, Ross
C-172F 180HP
KSWI
How about a URL or contact info. www.metalcheck.com apparently isn't the
right place.
Old August 21st 07, 05:29 PM posted to rec.aviation.owning
Ross
...I
was
Regards, Ross
C-172F 180HP
KSWI
right place.
Sorry about that. http://www.avlab.com/default.asp
It is from Aviation Labs.
Regards, Ross
C-172F 180HP
KSWI
Old August 20th 07, 06:07 PM posted to rec.aviation.owning
Robert M. Gary
If I hadn't been doing an oil analysis I wouldnt have known to look
for a busted up piston pin plug.
-Robert
Old August 22nd 07, 03:58 AM posted to rec.aviation.owning
me[_1_]
Robert,
For educational purposes could you please describe all of the indications
that helped you pinpoint the problem you found..
-Robert
Copper in oil analysis ? [email protected] Owning 8 August 22nd 06 12:31 PM
Regarding Analysis Nag Home Built 3 April 21st 06 11:02 PM
Oil Analysis PaulaJay1 Owning 3 March 16th 04 04:25 PM
Oil Analysis PaulaJay1 Owning 11 November 11th 03 01:29 AM
