PPL Written
Old August 21st 07, 01:21 AM posted to rec.aviation.piloting
Newps
Default PPL Written
What are you allowed to take with you to the PPL written test? Can you
bring an electronic E6B?
Old August 21st 07, 01:55 AM posted to rec.aviation.piloting
Jim Burns
Default PPL Written
Yes. They will make you remove the batteries to clear anything stored in
it's memory. Normally, there is also a version of the electronic E6B in the
computer testing software.
"Newps" wrote in message
Old August 21st 07, 02:05 AM posted to rec.aviation.piloting
Default PPL Written
An approved one; some are, some aren't.
Basically, if it is not programable, you can use it.
Same for calculators.
If it is in the Sporty's catalog, the catalog will tell you.
And don't forget spare batteries if you take something electronic.
Jim Pennino
Remove .spam.sux to reply.
Old August 21st 07, 01:12 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Default PPL Written
Yes. The proctor will ask that the batteries be removed and will keep
the instruction manual.
Old August 21st 07, 02:04 PM posted to rec.aviation.piloting
john hawkins
Default PPL Written
"B A R R Y" wrote in message
Thank God I have a real E6B ( no batteries required). The electronic version
on the test machine was ok but very limited.
Old August 21st 07, 04:49 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Default PPL Written
You get to put them back in, they only remove them to clear the memory.
For certain calculations, like the flight planning questions on the IFR
written, an electronic version is really handy. The Sporty's version
only requires to to enter changed values, remembering the others as
constants. The solution is displayed alongside the input parameters,
making double checking easy.
FWIW, I brought both versions, along with several plotters, to tests.
Why? Each plotter and the metal E6B has different information and
formulae printed on it.
Old August 22nd 07, 12:43 PM posted to rec.aviation.piloting
Ron Natalie
Default PPL Written
B A R R Y wrote:
version on the test machine was ok but very limited.
I'm not overly fond of the interface on either the Snortys or the ASA
calculator (anybody want a CX2 cheap). The last time I took my
instrument written I used the CX2. The first time I used an mechanical
E6 and a plain old four-banger calculator.
Old August 21st 07, 04:27 PM posted to rec.aviation.piloting
RST Engineering
Default PPL Written
ALmost. THe proctor will ask that the batteries be removed to clear memory
and then reinstalled so that you can use the calculator.
FAA Written Test Mike Soaring 13 August 18th 06 12:39 AM
Written Test W P Dixon Piloting 14 August 27th 05 02:09 AM
IFR written passed Jeff Bucchino Piloting 3 February 23rd 04 06:36 AM
Anyone took the ATP written with AllATPs? Shlomo Zelkine General Aviation 0 November 28th 03 06:07 PM
IFR written passed Tune2828 Instrument Flight Rules 3 August 12th 03 10:01 PM
