Our club's PA32R-300 has an IO-540 with lots and lots of hours on it.
After 20+ years, at this year's annual the compression was down a few pounds on a couple of the cylinders, and the mechanic said he really has his doubts about it passing next year's annual. That might be significant, or it might not. Twice this year, while people have been flight training in it (I was doing a BFR this spring, another pilot was checking out in the plane for the first time a few weeks ago), the engine has been running fine and on rollout afterwards the engine died and couldn't be restarting. Both times it was after doing some air-work (stalls, steep turns, etc) and then a couple of touch and goes. Nobody has had any problems in a normal point to point flight, although we've had the normal problems with hot starting that's endemic to fuel injected aviation engines. The last time it happened, the engine died at the airport where our mechanic is based, and he pulled the plugs and said they weren't fouled and they were dry (so the problem restarting wasn't that he flooded it). Based on a suggestion here, I had them check the fuel pressure, and it seems fine. Could it be vapour lock? Any other suggestions? -- Paul Tomblin http://blog.xcski.com/ "Once you have an emergency, the airplane belongs to the insurance company. Concentrate on saving people on the ground, your passengers, and yourself, in that order. Saving the plane is not on the list." |
"Paul Tomblin" wrote in message ... Our club's PA32R-300 has an IO-540 with lots and lots of hours on it. seems fine. Could it be vapour lock? Any other suggestions? -- Paul Tomblin http://blog.xcski.com/ Yes...check the electric fuel pump? |
In a previous article, "Blueskies" said:
"Paul Tomblin" wrote in message ... Our club's PA32R-300 has an IO-540 with lots and lots of hours on it. seems fine. Could it be vapour lock? Any other suggestions? Yes...check the electric fuel pump? As I said in the post above: Based on a suggestion here, I had them check the fuel pressure, and it seems fine. It was 22psi with just the engine driven pump, and 23psi with the electric fuel pump on. -- Paul Tomblin http://blog.xcski.com/ "Belligerent Design: The theory that life was put on this planet by an external sentient force just to **** me off." - Lore Brand Comics |
Hey Paul,
Ask a guy who currently has 2 cylinders in the back seat of his Chevy Tahoe about low compressions #1 and #2 on our left engine were under 20 lbswhen we checked them this weekend after being in the mid 70's last year. JPI data didn't show anything significant during cruise, but we see some excessive EGT drop with major power reductions on the #1. Valves move well and look good, but there's plenty of buildup. So we'll send them in to have everything cleaned up, the seats ground, valves lapped, guide reamed, and what ever else they recommend. These are Lycoming nitride, what cylinders are on the club Lance? dieing on rollout. I've had this occur twice with the Aztec, it makes a twin fun to taxi. Both times it was the right engine after normal approach and landing on a very hot (+90) day. I asked a couple A&P's about it and they both said that if the rpms at idle are normal when the engine is warm, then suspect fuel pressure. No answers, just general questions. Do you normally turn the electric fuel pump on for maneuvers and leave it on for touch and goes? Can you discern any relationship between the electric fuel pump operation and the engine dieing, such as it dieing shortly after the pump is switched off while at low rpm? When was the last time the fuel pressure was checked on the electric pump? Any sign of fuel leaking from the mechanical pump's vent/drain? Could your mechanical fuel pump be weak? I've got a Lance manual in this PC somewhere. If you need any specs let me know. When I have a minute, I'll look at the troubleshooting sections. Jim "Paul Tomblin" wrote in message ... Our club's PA32R-300 has an IO-540 with lots and lots of hours on it. After 20+ years, at this year's annual the compression was down a few pounds on a couple of the cylinders, and the mechanic said he really has his doubts about it passing next year's annual. That might be significant, or it might not. Twice this year, while people have been flight training in it (I was doing a BFR this spring, another pilot was checking out in the plane for the first time a few weeks ago), the engine has been running fine and on rollout afterwards the engine died and couldn't be restarting. Both times it was after doing some air-work (stalls, steep turns, etc) and then a couple of touch and goes. Nobody has had any problems in a normal point to point flight, although we've had the normal problems with hot starting that's endemic to fuel injected aviation engines. The last time it happened, the engine died at the airport where our mechanic is based, and he pulled the plugs and said they weren't fouled and they were dry (so the problem restarting wasn't that he flooded it). Based on a suggestion here, I had them check the fuel pressure, and it seems fine. Could it be vapour lock? Any other suggestions? -- Paul Tomblin http://blog.xcski.com/ "Once you have an emergency, the airplane belongs to the insurance company. Concentrate on saving people on the ground, your passengers, and yourself, in that order. Saving the plane is not on the list." |
I saw the same behavior on my IO470's. Turned out the engine fuel pressure
needed adjustment at idle. |
In a previous article, "Jim Burns" said:
what ever else they recommend. These are Lycoming nitride, what cylinders are on the club Lance? I think they're nitride as well. Do you normally turn the electric fuel pump on for maneuvers and leave it on for touch and goes? Can you discern any relationship between the electric Yes. fuel pump operation and the engine dieing, such as it dieing shortly after the pump is switched off while at low rpm? No, in the case when I was flying, I'd touched down, was rolling out without touching the throttle, and when I turned off on the taxiway it just died. When was the last time the fuel pressure was checked on the electric pump? About 6 hours ago. Any sign of fuel leaking from the mechanical pump's vent/drain? No. Could your mechanical fuel pump be weak? Don't think so. When we tested the fuel pressure this morning, it was 22psi on the engine pump, 23psi on the electric fuel pump, and almost no variation at different throttle/mixture settings. -- Paul Tomblin http://blog.xcski.com/ "Faced with the prospect of rereading this book, I would rather have my brains ripped out by a plastic fork." - Charles Cooper reviews the new Gates book. http://zdnet.com.com/2100-1107-514105.html |
Paul Tomblin wrote:
In a previous article, "Jim Burns" said: what ever else they recommend. These are Lycoming nitride, what cylinders are on the club Lance? I think they're nitride as well. Do you normally turn the electric fuel pump on for maneuvers and leave it on for touch and goes? Can you discern any relationship between the electric Yes. fuel pump operation and the engine dieing, such as it dieing shortly after the pump is switched off while at low rpm? No, in the case when I was flying, I'd touched down, was rolling out without touching the throttle, and when I turned off on the taxiway it just died. When was the last time the fuel pressure was checked on the electric pump? About 6 hours ago. Any sign of fuel leaking from the mechanical pump's vent/drain? No. Could your mechanical fuel pump be weak? Don't think so. When we tested the fuel pressure this morning, it was 22psi on the engine pump, 23psi on the electric fuel pump, and almost no variation at different throttle/mixture settings. My IO-360 did this a while back. Needed the fuel servo overhauled. |
My IO-360 did this a while back. Needed the fuel servo overhauled. What is a fuel servo? |
On Mon, 27 Aug 2007 22:41:59 -0400, The Visitor
wrote: My IO-360 did this a while back. Needed the fuel servo overhauled. What is a fuel servo? Part of the distribution system in an injected engine. http://www.littleflyers.com/engserv/lycfuel.htm |
The Visitor wrote:
My IO-360 did this a while back. Needed the fuel servo overhauled. What is a fuel servo? I don't know exactly, but it has two thin discs that rotate against each other as you advance throttle. At least that is my memory of the problem. |
| Mystery Plane | [email protected] | Piloting | 8 | November 9th 06 02:30 PM |
| Mystery Airport - help ID please | Steve | Piloting | 2 | September 4th 05 12:44 AM |
| GPS Mystery | tony roberts | Owning | 5 | February 3rd 04 01:54 AM |
| Halifax mystery | Geoffrey Sinclair | Military Aviation | 0 | November 14th 03 03:39 AM |
| Pan AM 747 mystery solved! | Alan White | Simulators | 1 | July 18th 03 07:29 PM |
