Enlarging a bushing hole?
Old August 28th 07, 01:42 AM posted to rec.aviation.homebuilt
Michael Horowitz
Default Enlarging a bushing hole?
I find myself having to enlarge a bushing's ID by 1/16ths to 3/8ths.
My concern is I don't know how to insure the 3/8" bit is aligned with
the axis of the hole. Centered is good, but I'm more concerned with
the alignment.
Suggestions? - Mike
Old August 28th 07, 01:51 AM posted to rec.aviation.homebuilt
Rich S.[_1_]
"Michael Horowitz" wrote in message
the alignment.
Suggestions? - Mike
Chuck a rod in the drillpress the same size as the existing hole. Slip the
bushing on the rod and clamp it to the table. Replace the rod with your new
drill or reamer. Make shavings.
Rich S.
Old August 28th 07, 11:29 AM posted to rec.aviation.homebuilt
mhorowit
On Aug 27, 8:51 pm, "Rich S."
Rich S.
Thank you Rich - Mike
Old August 28th 07, 05:30 PM posted to rec.aviation.homebuilt
Fred the Red Shirt
On Aug 28, 12:51 am, "Rich S."
the alignment.
Suggestions? - Mike
If it is a sintered bronze bushing machining will close off
the pores and prevent lubrication from reaching the shaft.
The people who make sintered busings say there is a
way to re-open them, but I never asked how.
If it is a solid metal bushing then no problem.
FF
Old September 13th 07, 12:43 PM posted to rec.aviation.homebuilt
Michael Horowitz
On Mon, 27 Aug 2007 17:51:37 -0700, "Rich S."
the alignment.
Suggestions? - Mike
Rich S.
And what if the hole is whollowed out such that rod or any drill bit
you have doesn't touch the bushing walls evenly? - Mike
Old September 13th 07, 04:07 PM posted to rec.aviation.homebuilt
Maxwell
the alignment.
Suggestions? - Mike
new
Rich S.
You can use a light weight rod and bend it slightly, so it traces the OD of
the hole, as the shaft rotates.
Machine shop supplies sell a "wiggler". It chucks in a drill or mill and has
a pointer about 2 inches long mounted on a ball. The ball fit allows you to
bend it easily, and many times over in daily use. But bending an 1/8 welding
rod will perform the same function, if you are patient with bending it.
Old September 13th 07, 11:20 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Depends on the style of bushing, and if it is installed in a larger
structure, at present.
If it is bushing with a flange, level the drillpress table, by chucking the
rod, then using a good square to get the table perpendicular in all
directions; then clam the bushing and drill.
If it is without flange, and rather tall, chuck up rod, get bushing clamped
so that the outsides of the bushing is parallel to the rod, and drill.
If you have access to a lathe, chuck the bushing, and tailstock drill it.
Jim in NC
Old August 28th 07, 03:59 AM posted to rec.aviation.homebuilt
John Ammeter
If you have a lathe or access to one it's simple. Just chuck the
bushing in the lathe with the drill bit mounted on the right side...
can't think of the name of that part..
John
the alignment.
Suggestions? - Mike
Old August 28th 07, 04:42 AM posted to rec.aviation.homebuilt
On Aug 27, 7:59 pm, John Ammeter
That'd be the Wifferdoodle. (Although some folks call it the Tail
Stock.)
-Bob
Worm Hole no Need for Black Hole Michael Baldwin, Bruce Products 2 May 8th 07 11:04 AM
Jackson Hole TFR [email protected] Piloting 24 August 23rd 06 04:35 PM
Even during sentencing, this guy is an a*hole H.P. Piloting 45 March 14th 06 11:36 PM
Hole Finder [email protected] Home Built 2 March 6th 06 02:32 PM
Rubber Bushing Replacement Boelkowj Home Built 8 December 12th 03 12:45 AM
