avionics book reference and question
Old October 3rd 03, 01:54 AM
mah
Default avionics book reference and question
Been following several threads here in rec.av.mil and rec.av.mil.naval
on technology issues. Thanks to all those keeping the signal to noise
ratio in a correct balance.
Just finished reading Avionics Navaigation Systems by Myron Kayton &
Walter Freid. I'd recommend it to anyone who want to know the nuts and
bolts of how the diferent systems work. Be ready to do derivitive
calculus. (I hadn't realized how much I had forgotten). Got the book
as a response to the questions posed here by the contributors.
BTW - According to this text, pitot tubes measure the dynamic pressure
and have nothing to do with the type of engine installed.
MAH
Old October 3rd 03, 03:31 AM
B2431
MAH
Only one person ever to have lived has said otherwise.
Dan, U. S. Air Force, retired
Old October 4th 03, 05:32 PM
Tarver Engineering
"Gord Beaman" wrote in message
No pension, not retired.
I have to agree with you Dan...it's a once-in-a-lifetime
experience too isn't it?...
You don't have to agree with Dan, Gord, but I don't mind you playing the
fool.
Old October 4th 03, 09:11 PM
B2431
Tarver, prove it or stop repeating the same lies.
Oops, now you will call me names again.
Old October 4th 03, 09:21 PM
Tarver Engineering
"B2431" wrote in message
Why do you lie, Dan?
Old October 4th 03, 05:34 PM
Tarver Engineering
Only every airplane built proves otherwise, Dan.
Did you find that static temperature probe on the F-4?
Bwahahahahaha
Old October 4th 03, 10:53 PM
mah
Dan,
I know I'm a bad boy, putting a piece of raw meat over the side of the
bridge to see if something snaps at it.
MAH
Old October 4th 03, 11:23 PM
Tarver Engineering
"mah" wrote in message ...
Dan,
It's ok sock, we are acustomed to trolling idiots at ram.
Old October 5th 03, 01:17 AM
B2431
Dan,
MAH
Just watch, Tarver will now go on and on about P1T0 tubes, pitot tubes,
pitot-static tubes, that a pitot tube without static ports provides pitot,
static and temperature data, that the 2 pin electrical connector attached to a
heated tube is used to convey temperature data and that a pitot tube without
static ports is a "pitot port." You will also find he is the only person ever
born that uses the term "pitot port." Further the temperature, pitot and static
data derived from a single pitot tube provides data for TAS and the engine(s).
You will also find out recips didn't have pitot tubes, that jet aircraft didn't
have pitot or pitot-static tubes until one crashed or got lost or some other
BS. You will find he is convinced pitot tubes are also only good for mud wasps
to hide in which is why they "screened" over static ports.
If you ask him to provide proof or cite an independent source for anything he
says he will respond with personal insults and vulgarity instead. If you Google
or use any other search engine to see what he has said in the past you then
become a "Knoyle troll" for some inexplicable reason.
Try this one on him: IAW 1F-4E-06 the WUC for "pitot-static tube" is 511CA,
that 1F-4E-2-5, 1F-4F-2-13 and 1F-4E-4 also call it a "pitot-static tube." See
if he will say those T.O.s are all wrong too. I have a 1F-4E-06 and will be
more than happy to scan the page in question.
Now just watch, I didn't address this to him yet he will spew his usual filth
in my direction. He may even say I was thrown out of the Air Force after 12
years. I wonder why he chose that number. Actually I don't care. Yawn
I don't supposed you'd like to go meet him and see if he's like this in person,
would you?
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
